V/S Denon AVR 2808
Kategori: Køb og salg
Forumnavn: Køb, salg, bytte
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=150285
Udskrevet den: 26-April-2024 kl. 22:02
Emne: V/S Denon AVR 2808
Skrevet af: ZABBI4000
Skrevet den: 12-Februar-2017 kl. 14:59
Jeg har sådan en fin Denon Surround forstærker. Har været brugt er par gange om måneden i den tid jeg har haft den. Spiller og fungere 100℅ der medfølger mikrofon så mange kan sætte den op. OBS den originale remotes er væk men jeg har fået en ny og bedre Logitech Harmoney 650 remotes som kan styrer mange apparater samtidigt.
Hvad skal den koste? Er åben for bud hvis nogen søger.
OBS den står i Roskilde og man kan komme og høre den.
110 watts x 7 into 8 ohms (20-20,000 Hz) at 0.05% THD Dolby® True HD, DTS-HD™ Master Audio, Dolby® Digital Plus, DTS-HD™ High Resolution Audio, Dolby® Digital EX, DTS-ES™, Pro Logic® IIx, and DTS Neo:6 decoding Audyssey Laboratories' MultEQ XT six-point auto setup and room calibration system (microphone included) XM Satellite Radio Ready (requires XM subscription and optional XM Mini-Tuner package) Neural Surround decoder for XM's HD Surround channels iPod® integration (requires optional Denon ASD-11R) Compressed Audio Restorer for better sound with compressed music sources AL24 Processing Plus for stereo and multichannel digital sources three-room/three-source output: powered and line-level stereo audio output with volume, balance and tone control for 2nd room (using powered 2nd room stereo output allows 5.1 home theater in main room) line-level stereo audio output with volume, balance, and tone control for 3rd room conversion of optical or coaxial digital signals to analog audio output for 2nd and 3rd rooms (PCM signals only) high-current, low-impedance amp design Pure Direct modes switch off all unused circuitry for the cleanest possible sound 192kHz/24-bit DACs for all channels learning/multibrand touchscreen electro-luminescent remote basic remote for 2nd or 3rd listening room (requires remote control extender system, not included) 17-1/8"W x 6-3/4"H x 16-15/16"D warranty: 2 years Our 60-day money-back guarantee Connections:
1080p-compatible HDMI digital video switching (2 in, 1 out) analog-to-HDMI video upconversion (up to 1080p) with Faroudja DCDi™ video processing and scaling HDMI version 1.3 component video switching (3 in, 2 out) component video conversion (composite to S-video, or composite and S-video to component) digital audio inputs: 4 optical (including 1 front panel), 3 coaxial digital audio outputs: 2 optical 7 audio/video inputs, including: 1 front-panel input with composite and S-video 6 rear-panel inputs with composite and S-video 2 audio-only inputs (including phono) 7.1-channel analog audio preamp input 7.1-channel analog audio preamp output RS-232C port for automated control systems 1 set of main speaker outputs back surround speaker channels re-assignable for bi-amping front left and right speakers
Skrevet af: JakobSkaarup
Skrevet den: 12-Februar-2017 kl. 15:03
Skrevet af: LasseKilde
Skrevet den: 13-Februar-2017 kl. 13:49
Kunne måske være interesseret hvis den kommer til salg.
------------- TV: Philips 70PUS6724, Afspiller: Xbox One S 4K, Forstærker: Sony DN-1080, Front:System Audio 2050, Atmos: Jamo Monitor One, Bag:Gale 3060B, Ceneter: System Audio 510AV, Sub: System Audio SE175
Skrevet den: 13-Februar-2017 kl. 20:41
Den er hermed sat til salg.
Skrevet den: 17-Februar-2017 kl. 06:29
Hej Lasse.
Havde du interesse i min Denon AVR 2808?
Vh
Skrevet af: startrix
Skrevet den: 17-Februar-2017 kl. 12:08
Kunne også sagtens være interesseret.
Skrevet den: 19-Februar-2017 kl. 06:52
Startrix jeg har sendt dig et pm
