Solgt
Kategori: Køb og salg
Forumnavn: Køb, salg, bytte
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=151529
Udskrevet den: 06-Maj-2024 kl. 21:20
Emne: Solgt
Skrevet af: DVDO
Emne: Solgt
Skrevet den: 03-Juni-2017 kl. 13:16
Skrevet af: DVDO
Skrevet den: 05-Juni-2017 kl. 08:53
Skrevet af: DVDO
Skrevet den: 09-Juni-2017 kl. 07:46
Skrevet af: DVDO
Skrevet den: 11-Juni-2017 kl. 09:26
Skrevet af: DVDO
Skrevet den: 16-Juni-2017 kl. 07:19
Skrevet af: Champ100
Skrevet den: 16-Juni-2017 kl. 08:38
kan den afspille x265 filer
------------- Sony 55w828b sony str-dn1080 Oppo 203 bluray/UHD Vifa bluespark front/center baghøjtaler system audio SA 205
Skrevet af: DVDO
Skrevet den: 16-Juni-2017 kl. 09:24
Processor: RTD1186 - 750Mhz - 512MB SLC Flash - 512MB DDR3 SDRAM Video Fomats Supported: AVI/BDMV Light/BDISO Light/MKV/TS/TP/TRP/M2TS/MPG/MP4/MOV/M4V/VOB/ISO/IFO/DAT/WMV/ASF/RM/RMVB/FLV resolution up to 720p/1080i/1080p Video Codecs Supported: MPEG-1-2/MPEG-4 SP/ASP/AVC (H.264)/XviD/WMV9 (VC-1)/RealVideo 8/9/10 (up to 720P) 3D Video: Full 3D/3D BD ISO/Side By Side/Top & Bottom/Frame Sequential/Frame Packing MAX 1920x1080. Audio Codec Supported: MP3/MP2/OGG Vorbis/PCM/LPCM/AAC/RA/Dolby True HD - DTS MA Passthrough on HDMI/AC3 - DTS 5.1/Flac up to 24bit 192Khz/WAV/WMA Standard (DRM & Advanced Profile not Supported) Photo format Supported: JPEG/BMP/GIF/TIFF/PNG File System Supported: FAT32/NTFS/HFS+ (MAC) Video Output Resolution: NTSC/PAL/480P/576P/720P/1080i/1080p/1080p 24Hz/Auto Frame Rate Output: HDMI 1.4/Component Video/Composite Video/ Stereo RCA/SD/SDHC/Sony Pro Duo Card Slot/SPDIF Optical/Co-Ax Digital/Slave Port USB 3.0/Host USB USB 2.0 x2/IR Jack Optional WiFi: MED10WFB or MED20PCIE (Wifi is optional unless otherwise stated on the packaging) Optional Hard Drive: Internal Hard Drive is optional unless otherwise stated on the packaging Contents: MED1000X3D-BLK/RC/2x AA Batteries/AC Adapter/ HDMI 1.4 Cable/AV Cable/USB3.0 Cable/HDD Securing Screws. Specifications subject to change without notice, DTS, DTS-HD the symbol & DTS or DTS-HD and the Symbols together are registered trademarks of DTS, Inc ©DTS Inc. All Rights Reserved
Skrevet den: 16-Juni-2017 kl. 11:18
øv
Skrevet af: DVDO
Skrevet den: 19-Juni-2017 kl. 18:37
Skrevet af: DVDO
Skrevet den: 21-Juni-2017 kl. 20:20
