Hey recordere,
Jeg sælger min Integra DTR 40.4 Reciever. Den fungerer upåklageligt og eneste årsag til at jeg sælger er fordi jeg vil have noget mere kompakt :-)
Jeg har desværre ikke kvitteringen liggende længere, men garantien er også udløbet, så det gør næppe den store forskel tænker jeg.
Pris ide: 3.000 kroner, men kom med et bud.
Den befinder sig i 7800 Skive.
Se flere detaljer nedenfor eller via linket:
http://www.integrahometheater.com/Products/model.php?m=DTR-40.4&class=Receiver&source=prodClass" rel="nofollow - http://www.integrahometheater.com/Products/model.php?m=DTR-40.4&class=Receiver&source=prodClass
The Integra DTR-40.4 takes streaming web or PC audio and delivers it with dynamism and power. Combined with the latest home theater features and renowned Integra build quality, it makes for a stunning mid-range receiver.
Distribute powered audio throughout the home, or immerse yourself in seven-channel movie soundtracks with the DTR-40.4, which boasts 4K video upscaling and Audyssey DSX® for vivid, realistic entertainment. ADVANCED FEATURES • THX® Select2 Plus™ Certified • HDMI Support for 3D, Audio Return Channel, DeepColor™*, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC • HDMI® Video Upscaling to 4K with Qdeo™ Technology by Marvell • MHL (Mobile High-Definition Link) for Smart Phone Content on HDTV • Picture-in-Picture Input Source Preview with InstaPrevue™ Technology • Direct Digital Connection of iPod/iPhone via Front-Panel USB Port • TI Burr-Brown 192 kHz/24-Bit DACs for All Channels • Three-Stage Inverted Darlington Circuitry • Fully Discrete Output Stage Circuitry • PLL (Phase Locked Loop) Jitter-Cleaning Circuit Technology • Audyssey DSX® and Dolby® Pro Logic® IIz for Expanded Surround Channels • Overlaid On-Screen Display (OSD) with Quick Set-Up and Home Menu • Playback of Audio Files Through Local Network (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, LPCM, Dolby True HD, DSD)*4 • Internet Radio and Cloud Music Streaming Service Connectivity (MP3tunes, Spotify, AUPEO!, vTuner)*1 • Supports Integra Remote Apps for iPod touch®/iPhone®*2 and Android Phone*3 • Compatible with Optional UWF-1 Wireless LAN Adapter • Compatible with Optional UBT-1 Bluetooth USB Adapter • Certified with Windows 7 and DLNA Version 1.5 • 8 HDMI Inputs (1 Front/7 Rear) and Dual HDMI Outputs (Simultaneously Active Capable) • 4 DSP Modes for Gaming: Rock, Sports, Action, and RPG • Hybrid Standby Function to Reduce Power Consumption • Bi-Amping Capability *1 Availability of services depends on region. Some services may require a firmware update. Availability of thirdparty services advertised here is accurate at the time of printing, but may be subject to change without notice. *2 Compatible with iPod touch (3rd generation or later) and iPhone 3GS or later. All models require iOS 4.2 or later. *3 Requires Android OS 2.1 or later. *4 Not all servers or players support all formats. OTHER FEATURES • 110 W/ch at 8 Ω, 20 Hz–20 kHz, 0.08% THD, 2 Channels Driven, FTC; 185 W/ch at 6 Ω, 1 kHz, 1%, 1 Channel Driven, JEITA • WRAT (Wide Range Amplifier Technology) • H.C.P.S. (High Current Power Supply) Massive High Power Transformer • Discrete Output Stage Circuitry • Linear Optimum Gain Volume Circuitry • Advanced 32-Bit Processing DSP Chip • Advanced Music Optimizer for Compressed Digital Music Files • 2 USB Ports (1 Front/1 Rear) • Direct Mode • Audyssey 2EQ® for Room Acoustic Correction • Audyssey Dynamic EQ® for Loudness Correction • Audyssey Dynamic Volume® to Maintain Optimal Listening Level and Dynamic Range • Independent Crossover Adjustment for Each Channel (40/45/50/55/60/70/80/90/100/ 110/120/130/150/200 Hz) • A/V Sync Control (Up to 800 ms in 1 ms Steps) • Colour-Coded, 7.2 Multichannel Pre Outs (Including 2 Subwoofer Pre Outs) • HDTV-Capable Component Video Switching (2 Inputs and 1 Output) • Analog RGB Video Input (D-sub, 15 pin) for PC • 5 Composite Video Inputs and 1 Output • 5 Digital Audio Inputs (2 Optical and 3 Coaxial) • 7 Analog Audio Inputs and 1 Phono Input • Tone Control (Bass / Treble / Balance ) for Front L/R Channels • Display Dimmer (Normal / Dim / Dimmer) • 40 FM/AM Random Presets • Firmware Updates via Ethernet and USB • Preprogrammed RI (Remote Interactive) Remote Control with On-Screen Setup, Mode-Key LEDs, and Macro Presets for Four Activities *Front-Panel HDMI does not support DeepColor. CUSTOM INTEGRATION FEATURES • Bi-Directional Ethernet and RS232 Port for Control • Powered Zone 2/3, Zone 2 Video Out, and Zone 2/3 Pre/Line-Outs for Distributed Audio Playback in Multiple Rooms • Independent Zone 2 Bass/Treble/Balance Controls • Max & Power On Volume Settings for Main Zone, Zone 2 and Zone 3 • Whole House Mode • Smart Grid Ready • Dealer Settings Memory Store & Recall with Lock / Unlock • Permanently Stored Settings • 2 IR Inputs and 1 Output • 3 Programmable 12 V Triggers (with Adjustable Delay) • Optionsl Rack Mount Kit Available (IRK-155-3C) • RIHD (Remote Interactive over HDMI) for System Control* *Compatibility depends on respective model.
