"The Maxtor Shared Storage II (MSS 2) runs the Linux Operating System (ARM little
endian).
TwonkyMedia simple installation on Maxtor Shared Storage II
1. Make sure that you have telnet access to the MSS II, probably through a
firmware upgrade.
Flashing firmware is a straight-forward procedure. However, there is always
the possibility that something could go wrong and damage your NAS in
the process. Flashing unofficial firmware will probably void your warranty.
2. Make sure that you have created a shared folder "public" on the MSS 2.
3. Unzip all files from this package (preserving subfolder structure!)
into a folder on your PC, start NASSetup.exe and follow the instructions.
After the trial period is over, the server needs to be registered.
For an automatic registration the server must be able to contact
twonkyvision.com, i.e. the domain name server (DNS) and the default gateway
must be configured well. Otherwise, automatic registration will fail and you
have to register manually."
kris
