This is the new firmware 60126A for LG RH-7x00 harddisk recorders. The firmware has been released by LG Electronics Nordic. It can be used for the following LG RH-7x00 models (according to the earlier http://test.pier.dk/dvd/LG%20RH-7xxx/Firmware/50617A/50617A_FW.html - version 50617A description ): RH-7500, RH-7800, RH-7800H and RH-7900H
! Update with/to this firmware at Your OWN RISC ! I am NOT to be held responsible, for any damages or faulty updates to Your recorder !
! VERY IMPORTANT ! 1) NEVER switch off the recorder during an update. 2) Wait for the update to finish successfully (when the Firmware-CD has been ejected after the update). 3) After the update has finished, please remember to switch the recorder off, and then on again - for the new firmware to load, and fixes to work.
http://test.pier.dk/dvd/LG%20RH-7xxx/Firmware/60126A/ - The firmware 60126A can be downloaded here. User: recordere Password: dk
Also be sure to check my http://www.recordere.dk/links/Goto.asp?ResourceID=732 - firmware-update guide , for making / burning the firmware-cd with Nero (with screen-shots), as well as updating the recorder. User: recordere Password: dk
Before You start the update, check Your current firmware to see whether this firmware is older or newer, than Your current one.
For checking Your current Firmware-/Loader- info on RH 7x00: Press ("Setup", "Lock icon", "7", "8", "8", "9").
It should look something like this (versions on Your recorder may vary): SET: Ver=60126A Cware=prod045 BSP=23 FME IO: Ver=R02(D17), Loader: v.30
The Loader version is NOT affected by this firmware-update, nor is Your recorder's current settings or channel-tunings.
Features / issues addressed in firmware 60126A:
- Timer recording stops after 4 minutes and 1 second, if harddisk is almost full. Corrected in firmware 60126A.
- Remember subtitle setting, for XviD/DivX movies, e.g. LATIN-2. Corrected in firmware 51214A.
- .srt / .sub subtitle bug in XviD / DivX movies (no end time). (e.g. subtitles in XviD / DivX, are no longer displayed permanently). Corrected in firmware 51214A.
- Rewind / Fast forward when playing XviD/DivX movies. (NOT to be confused with goto/search by time). Will not be corrected by this, nor future firmwares / software, according to factory - hardware issue / hardware bound. (Info from LGE Nordic).
- Fast DUBBING to DVD of edited material. (e.g. FAST copying to DVD, after commercials have been cut away). Will not be corrected by this, nor future firmwares / software, according to factory - hardware issue / hardware bound. (Info from LGE Nordic).
- Using the recorder, while a timerbased/programmed recording is running. Will not be corrected by this, nor future firmwares / software, according to factory - hardware issue / hardware bound. (Info from LGE Nordic).
- Having to switch off the recorder, for a timerbased/programmed recording to start. Will not be corrected by this, nor future firmwares / software, according to factory - hardware issue / hardware bound. (Info from LGE Nordic).
- Erasing DVD+RW data discs. As stated on page 5 in the RH 7500 / RH 7800 manual, at the buttom: "If a DVD-RW/DVD+RW discs is recorded using a personal computer or other DVD recorder, you cannot format the disc using this recorder." So You will have to re-format the disk, with the same program/dvd-writer, as You did the first time You formated the disk.
- Better frame accurate editting. (e.g. cutting away commercials). Not tested yet.
- High Definition DivX / XviD support (1280 x 720 @ 30 fps), according to: http://www.divx.com/certification/technical.php - http://www.divx.com/certification/technical.php . Not tested yet.
--> Please do NOT post in this thread, as it is only meant for linking to the thread containing the 60126A Firmware. <--
You can follow the firmware-discussion in this thread: http://www.recordere.dk/forum/forum_posts.asp?TID=8295&P N=1&TPN=100 - http://www.recordere.dk/forum/forum_posts.asp?TID=8295&P N=1&TPN=100
/Anders
------------- Regards, Anders Pier.
SAMSUNG UE46ES5505 • APPLE TV (GEN. 3) • Xbox Logitech Harmony 600
