fjernbetjening (logitech Harmony virker med key opsætning fra internet) + kode 0413
info for opsætning her:
Logitech Harmony:
- Add LG TV in Harmony remote configuration
- Connect to Logitech Harmony website with Login/Password : http:// members.harmonyremote.com
- Go to : http:// members.harmonyremote.com/EasyZapper/Infrared/ShowInf¬rared.asp
- Click on "Manual >"
- In "Data Value" zone, copy/paste this Philips Pronto code :
0000 006d 0022 0002 0157 00ac 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0689 0157 0056 0015 0e94
- Click on "Process >" : message "Converted from Pronto format successfully!"
- Click on "Next >"
- Click on "Select an active device"
- Choose device for your LG "TV"
- Enter command name "EZ Adjust", for example
- Click on "Add >"
In remote software, you can now assign command "EZ Adjust" to any button.
