<b>Forside</b> Forside > Recordere, afspillere og foto > Medier
  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Dual layer kompatibilitet tests
Emne lukketDual layer kompatibilitet tests
MichaelS Se dropdown menu
Tidl. redaktør recordere.dk
Oprettet: 11-Marts-2004
Point: 2062
Direkte link til dette indlæg Emne: Dual layer kompatibilitet tests
    Sendt: 15-Juli-2004 kl. 14:37
CDRinfo tester DVD brændere til PC'er og tester også om skiverne efterfølgende kan afspilles.
Jeg har samlet lidt data om to brændere og om de DVD+R Dual layer skiver de har brændt også er kompatible med gængse afspillere.
CDRinfo skriver selv "For our compatibility tests, we used the two burned DVD+R DL discs with DVD-Video content ("Gladiator Movie - Special Edition" Disc1), PowerDVD v5.0 and Windows Media Classic.
We played our DL media at all supported reading speeds on the following drives.The results are shown below:"
Link til Philips test Link til BenQ test  Link til Sony test
Her er resultatet samlet i tabelform:
Testet af CDRinfo.com
Brændt på
Philips DVDRW885K BenQ DW1600A DL Sony DRU 700A
PC Drive
Firmware
DVD-ROM Booktype DVD-ROM Booktype DVD-ROM Booktype
BenQ DW822A vB3HC Not recognized Not recognized Not recognized
BTC BDV-316B v0.47 Playback is perfect Playback is perfect Playback is perfect
LG DV8600 ? Not tested Playback is perfect Not tested
LiteOn LDW-811S vHS0Q Playback is perfect Disc size recognized under CDSpeed but not disc contents under Windows Disc size recognized under CDSpeed but not disc contents under Windows
LiteOn LTD-163D vGH5S Playback is perfect Playback is perfect Playback is perfect
LiteOn LTD-165H vCH11 Playback is perfect Playback is perfect Playback is perfect
LiteOn SOHC-5232K vNK07 Playback is perfect Playback is perfect Playback is perfect
LiteOn SOHW-812S vUSOJ Playback is perfect Playback is perfect Playback is perfect
NEC 2500A v1.07 official Playback is perfect Playback is perfect Playback is perfect
NEC 2510A v2.15 Not tested Playback is perfect Not tested
Optorite DD203 v2.25 Playback is perfect Playback is perfect Playback is perfect
Optorite DD405 v1.50E Playback is perfect Playback is perfect Playback is perfect
Panasonic LDF-511 vA112 Playback is perfect Playback is perfect Playback is perfect
Philips DVDR824P vP1.2 Not recognized Not recognized Not recognized
Pioneer A06 v1.07 Playback is perfect Playback is perfect Playback is perfect
Pioneer A07 v1.12 Not recognized Not tested Not recognized
Pioneer DCR-111 v1.26 Playback is perfect Playback is perfect Playback is perfect
Pioneer DVD-106S/2 v1.22 Playback is perfect Not tested Playback is perfect
Pioneer DVD-116/S2 v1.22 Playback is perfect Not tested Playback is perfect
Pioneer DVD-500M v1.02 Not recognized, drive makes noises Not tested Not recognized, drive makes noises
Plextor PX-712A v1.01 Playback is perfect Playback is perfect Playback is perfect
Plextor PX-712SA v1.02 Not tested Playback is perfect Playback is perfect
Ricoh 5308D v1.B2 Playback is perfect Not tested Playback is perfect
Ricoh MP5125A v1.27 Playback is perfect Not tested Not tested
Ricoh MP5308D v.1.B2 Playback is perfect Not tested Not tested
Samsung SH-W08A v1S30 Not recognized Not recognized Not recognized
Sony DVP - NS330 ? Not tested Playback is perfect Not tested
Sony DVP - NS730P ? Not tested Playback is perfect Not tested
Sony DVP - PQ2 ? Not tested Playback is perfect Not tested
TEAC DV-516E v2.01 Not tested Not recognized Not recognized
TEAC DV-516E v2.01 Not recognized Not tested Not tested
Toshiba SD-1502 v1012 Playback is perfect Playback is perfect Playback is perfect
Toshiba SD-1612 v1004 Playback is perfect Playback is perfect Playback is perfect
Toshiba SD-1712 v1004 Playback is perfect Not tested Playback is possible, several skips
Toshiba SD-1802 v1034 Playback is perfect Not tested Recognizes disc size under CDSpeed but not disc contents under Windows
Waitec DVD-X4 ? Not tested Disc recognized, playback is jerky Not tested
Waitec Vision-HR ? Not tested Disc recognized, playback is jerky Not tested
Good in %   81% 75% 67%
Players
Kiss DP-1504   Disc isn't recognized Not tested Disc isn't recognized
LiteON LVW-5001   Playback is perfect Not tested Playback is perfect
LiteON LVW-5005   Playback is perfect Not tested Playback is perfect
Philips DVD-720SA   Playback is perfect Not tested Not tested
Philips DVD-763SA   Playback is perfect Not tested Not tested
Philips DVD-963SA   Playback is perfect Not tested Not tested
Pioneer DV-370   Playback is perfect Not tested Not tested
Pioneer DV-454   Playback is perfect Not tested Not tested
Pioneer DV-464   Playback is perfect Not tested Not tested
Pioneer DV-656A   Playback is perfect Not tested Not tested
Pioneer DVR-7000   Playback is perfect Not tested Not tested
PS2 SCPH-5004 series   Playback is perfect Not tested Playback is perfect
Waitec DVD-X4   Disc recognized, playback is jerky Not tested Disc recognized, playback is jerky
Waitec Vision-HR   Disc recognized, playback is jerky Not tested Disc recognized, playback is jerky
Good in %   79%   50%
Vi kan altså konkludere at de nye skiver ikke er 100 % kompatible.
Det bemærkes specielt at Pioneer A06 kan afspille dem og den nyere model A07 ikke kan. Mystisk!
20.7.04 Sony tilføjet
Hilsen
Michael Sørensen
Redigeret af MichaelS
mvh MichaelS
papabear Se dropdown menu
Oprettet: 29-Marts-2004
Point: 181
Direkte link til dette indlæg Sendt: 15-Juli-2004 kl. 19:25
Jaeeeehhh..... er det ikke en lidt hurtig/entydig konklussion?
En anden konklussion kunne være, at en del DVD-læsere ikke er kompatible og/eller ikke er af en god nok kvalitet.
Det benyttede medies kvalitet har naturligvis også stor indflydelse, og det er næppe tilfældigt at meget få producenter endnu har frigivet disse skiver.
Ja, det er en værre en.
by PapaBear
(- som mangler afsnit 2 og 19 af 'Allo 'Allo samt BlackBooks afsnit 2 - anyone??)
