Side 123 12> |
Forfatter | ||
kfcofir ![]() Guld medlem ![]() ![]() Oprettet: 19-Juni-2006 Sted: Holbæk Status: Offline Point: 635 |
![]() Sendt: 30-Oktober-2009 kl. 19:58 |
Citat .. DvICo Update M-6600: Here's the new firmware for M6600. Please download the file at below link. This is the latest update in a series of betas that improve quite a lot and brings on the features we know from the earlier models and more... With this latest release, also the PC side NFS is included...
http://demod.dvico.com/Beta/tvix_6600_1.9.1_b2.zip The new NETSHARE software which enables NFS functionality on your PC, is also available, and please download it at below link. http://demod.dvico.com/down/tvix/TViX_NetShare_2.12.zip Release Notes for Rev 1.9.1 since Rev 1.8.7 (last sample release). [Changes] [ Multimedia Player/ System] 1. Supports universal jukebox - Supports HDMV and ISO file format. - You can pop-up the native menu by pressing ¡°MENU¡± button. - Supports playback of universal jukebox thru network (NFS/ SAMBA) including ISO format - Supports external subtitles on universal jukebox. (HDMV/ ISO) - Supports resume/bookmark functions on universal jukebox 2. Supports NETWORK LIVE FIRMWARE UPDATE - From Rev 1.9.1 - Please make sure that M6600 is connected to Internet, then go to SETUP - SYSTEM - AUTOMATIC FW UPDATE. - It only shows official firmware list, but you can list beta firmware as well if you press 2-3-8-2 (¡®b¡¯-¡®e¡¯-¡®t¡¯-¡®a¡¯) then FUNC button at SETUP. 3. Improves file browsing/ setup/ GOTO/ INFO user interface - Improves the browsing/ scrolling speed a lot. - Fixes the problem of hidden part of upper and lower items of highlighted item at file browser. - SETUP icons/ some colors of UI are changed - New INFO window by pressing ¡°INFO¡± button - more neat & simple - More intuitive GOTO window by pressing ¡°GOTO¡± button 4. Supports new BOOKMARK function. - Previous bookmark function is changed to ¡°RESUME¡± - TO ADD BOOKMARK : Press ¡°BOOKMARK¡± button when file playback - TO JUMP BOOKMARK position at file browser : Press ¡°BOOKMARK¡± button at file browser and select ¡°BOOKMARK¡± tab. - TO JUMP BOOKMARK position when playback : Press ¡°GOTO¡± button and move to ¡°BOOKMARK¡± item by right arrow key. 5. Improves ZOOM function - You can adjust zooming/ scrolling by magnitude or percentage. - VOLUME +/- buttons will change zoom magnitude by 1x~9x - CH +/- buttons will change zoom percentage by 0%~180% progressively - Arrows buttons - scrolling the zoom screen - This function only applies on video. New ZOOM function is not supported yet on PHOTOs. 6. Adds new ASPECT RATIOs (by pressing ASPECT(16:9/4:3) button) - ZOOM1 : stretching 21:9 aspect ratio to 16:9 - ZOOM2 : retaining 4:3 aspect ratio on 16:9 TV 7. Improves text subtitle - Adds shadow effect on text subtitle to improve the readability. - Adds smart line-breaking when wraparound happens 8. Adds the VIDEO/MENU SCREEN POSITION ADJUSTMENT - You can setup the VIDEO SCREEN POSITION (left/ right/ up/ down) as well as UI MENU position - In the SETUP - SYSTEM - SET SCREEN POSITION 9. Adds the SCREEN-SAVER ENABLE TIME - In the SETUP - MISC. You can adjust it by 1min~60min 10. Fixes YOU-TUBE rebooting problem - Fixes just the rebooting problem. YOU-TUBE is not supported yet, we¡¯ll support it shortly 11. Fixes stopping problem of transport stream playback when you select audio changes by ¡°AUDIO¡± button [PVR PART] 10. Supports BACKGROUND EPG UPDATE by dual tuner - Always gathers EPG information when second tuner is idling. - Shows EPG of all channels always, even though you did not actually zap that channel. 11. Adds SKIP - CHANNEL- SCANNING function - You can skip several channels scanning by pressing ¡°NEXT¡± button - This will reduce channel scanning time. 12. Adds EIT (DVB-T) / ETT (ATSC) information on EPG 13. Adds CABLE/ AIR selection pop-up when no channel scanning done before in ATSC 14. Fixes rebooting problem of channel switching when dual recording. 15. Fixes 15 seconds skipping problem at time-shifting. [ Network/ UPnP] 16. Enables SAMBA/ NFS server browsing function. - Go to SETUP - NETWORK - SETUP NETWORK DISK, then new browsing window will pop-up. - NFS: Can browse all NAS/ NETSHARE servers/ folders, don¡¯t have to input the IP or share-folder-names. - NFS: Should use NETSHARE 2.12 or later for this NFS browsing capabilities in the PC. - SAMBA: Can browse all shared folders if GUEST account is available on that server. [Known Issues] [Limitations & Known issues of current firmware Rev 1.8.5] [Player part] - You cannot hear the sound or pass-thru of DOLBY TRUE-HD audio embedded transport stream yet. - MKV chapter function is not stable on some MKV files. (This problem will be fixed soon) - If you playback video after trying to playback the unsupported audio (APE/ WMA lossless), you may experience rebooting. - Some jukebox title contains VC1 codec may cause problem during MENU and TITLE switching. (This will be fixed shortly) - Preview mode playback of jukebox ISO files may cause problem. (This will be disabled shortly) - Skip duration selection is not implemented yet (This will be fixed shortly) [PVR part] - French HD channels may be stopped sometimes during live playback. - Switching channels may cause problem on some New Zealand channels. - Dual recording will stop on ATSC if recording time is more than 2 hours each. (DVB-T is O.K.) [Network part] - If you have problem to get the I.P. address of wireless AP, please use WEP 64bit mode or WPA mode. - YOU-TUBE is not supported at this moment. It will be fixed shortly. Here¡¯s the summary of current firmware status. [Comparison with 6500] [New features over 6500] - New design with aluminum top, minimal look. - Dual tuner H264 HD PVR (both DVB-T/ATSC) with time-shifting/ dual RF recording/ watching one channel + recording the other (T341 is dual DVB-T tuner/ T321 is dual ATSC tuner) - New ergonomic HDD exchange, very cool & quiet unit with utilizing premium grade FAN. (Never been easier to exchange the HDD) - 802.11N embedded model (6600N) with NFS, SAMBA SERVER/CLIENT protocol support - Supports uPnP natively. This will ease much of the network configuration headache. - Supports IMS (Internet Media Service) functions. - You can enjoy YOU-TUBE, PICASA, etc. - Supports RMVB-HD, .FLV video format - Booting time is much faster than 6500 (less than 30 seconds) - Upgrading firmware is much faster than 6500. (less than 1 minute) - Supports OGG/ FLAC audio tracks in MKV - Supports PREVIEW/ THUMBNAIL/ LIST mode (by setup) - Supports JPEG/ BMP/ TIFF/ GIF/ PNG image format - Supports 9 different transition effects of slideshow. - Supports ISO type UNIVERSAL JUKEBOX over NFS. [Same features as 6500] - Supports universal jukebox - Supports thumbnail view for photo supported (by pressing ¡°FUNC¡± button) - Supports music play list creation function. - Supports MKV chapters/ embedded subtitles. - Supports setting each audio type of RAW/PCM output selection. [Still not supported compared to 6500] - Not support APE music format yet. - Not support NATIVE RESOLUTION yet - Not support TTF font loading yet (It will be fixed shortly) __________________
vil forsøge at teste den.. men hvis nogen er hurtigere er det ok med mig ![]() Redigeret af kfcofir - 30-December-2010 kl. 20:16 |
En masse HiFi ( Bip biiiip) jeg ikke har tid til at sætte mig ind i :O(
Fakker ![]() Super bruger ![]() ![]() Oprettet: 13-April-2008 Sted: Aarhus Status: Offline Point: 315 |
Det var da ellers en ordentlig kaél af en opdatering.
Har ikke fået fat i den Tvix 6600 endnu, (Har 6500) men det kommer måske. Glæder mig til, at høre jer andre, ang denne opdatering, hvad i synes ![]() Redigeret af Fakker - 30-Oktober-2009 kl. 20:15 |
Smed den i roden af en USB Pen, klikkede OK på filen og ca 1½ - 2 min senere, så hed firmwar'en 1.9.1 her.. viker fino her.. Tester vidre |
claust ![]() Super bruger ![]() Oprettet: 28-November-2005 Sted: Denmark Status: Offline Point: 372 |
Så mangler vi bare mulighed for at smide Covers ind i filbrowseren, så mine unger selv kan finde de film de vil se :-)
Håbede godt nok at det var med denne gang... |
BSoD ![]() Bruger ![]() Oprettet: 12-December-2008 Sted: Denmark Status: Offline Point: 51 |
Jeg er meget tilfreds - mest mht net delen - jeg kunne under ingen omstændigheder få NFS til at virke med den gamle firmware - nu køre det som en drøm! Jeg har også optaget lidt via tuneren og det virker også fint.
tipsen ![]() Guld medlem ![]() Oprettet: 29-August-2005 Sted: Odense, Denmark Status: Offline Point: 3722 |
Er det pvr-udgaven du har? hvad er det for noget tv der kan optages (hvad understøttes), hvor smidigt er det og er der mulighed for time-shifting? |
Jeg har købt en TViX 6000 + en harddisk og en tuner T441 : http://www.dustinhome.dk/pd_5010331361.aspx på den måde bliver det måske i praksis den samme som PVR modellen. Det er i hvert fald meget nemt at samle og anvende. Jeg har dog kun leget med tuner med den nye firmware. Den har 2 tunere så man kan optage et program og set et andet - og den kan time-shift'e - der er faktisk et menupunkt der sætter den til autoamtisk at timesifte, men jeg har ikke prøvet hvordan det virker - har kun leget med den en enkelt dag, hvor meget andet skulle testes |
Så er der en version 1.9.1 b5
http://www.tvix.co.kr/ENG/boards/MyAQ.aspx?bserial=15&act=RD&pg=1&id=16566 Redigeret af claust - 04-November-2009 kl. 15:45 |
Flash ![]() Ny bruger ![]() ![]() Oprettet: 10-Maj-2007 Sted: Denmark Status: Offline Point: 13 |
Jeg har selv set på den som erstatning for min gamle video.
Hvor langt ud i fremtiden kan den times til DR og TV2? (kan kun gøres via epg efter hvad jeg forstår) Kan den times til flere optagelser? Går den i stand by før og efter optagelsen? Mener du den er velegnet til timeroptagelser? |
Panasonic TH-50PX70E
Marantz DV7001 Marantz SR8001 Audio Pro A.100DC, A.20DC & Allroom sat |
Ups! spørgsmålene skulle være her. Jeg har selv set på den som erstatning for min gamle video. Hvor langt ud i fremtiden kan den times til DR og TV2? (kan kun gøres via epg efter hvad jeg forstår) Kan den times til flere optagelser? Går den i stand by før og efter optagelsen? Mener du den er velegnet til timeroptagelser? |
claussøe ![]() Ny bruger ![]() Oprettet: 09-November-2009 Status: Offline Point: 1 |
Jeg har en Tvix 6600 på godt og ondt.
Den kan timer optage via EPG
Den kan timer optage manuelt med dato,start, slut, gentag / once m.m. det kan den vist sættes til langt ude i fremtiden. Jeg ved ikke om der er begrænsninger på hvormange scheduler man kan lave
Den kan optage 2 forskellige kanaler samtidig
Den kan kun optage hvis der er interne disk i.
Min indlæser ikke hele EPG, kun til midt på dagen på de forskellige kaneler, irreterende.
Den optager / viser ikke de undertekster som ikke er brændt ind i billedet, i testen her på forumet er det bekrevet lidt utydeligt, men en del TV2 og noget fra DRHD vises ikke med tekster. Håber de løser det. (har ikke prøvet at tjekke med den beta der ligger for den fik min tvix til at crashe en del)
Den vågner og går fint i stand by før . efter optagelser.
Men den er jo ikke 100% ligeså let at bruge som en gammeldavs HD optager.
Tak for informationerne.
Efter hvad jeg har kunnet finde, er dette som du skriver ikke helt optimalt, men måske den bedste løsning på nuværende tidspunkt. Jeg har bestilt en med 1.5 TB HD som kommer en af dagene. Så håber jeg at der kommer opdateringer så den kommer helt i top ![]() |
Side 123 12> |
