  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Pioneer  VSX-919 A-H receiver DTS Display
Emne lukketPioneer VSX-919 A-H receiver DTS Display
Roger-Strutton Se dropdown menu
Oprettet: 05-Juli-2009
Point: 1
Direkte link til dette indlæg Emne: Pioneer VSX-919 A-H receiver DTS Display
    Sendt: 05-Juli-2009 kl. 10:55
Hi,
Sorry for the English.
I  have a Sony Bravia TV, a Sony BDP-S550 Blu-ray player, and a Pioneer VSX-919 A-H receiver.
I  have acepted the defaults on my player:
BD Audio Setting=MIX (other choice Direct.)
Film "Slumdogs" DTS HD Master Audio (Lossless.)
Pioneer displays PCM + PLI x MV.
All connections with HDMI 1.3c cables.
Should a DTS signal be displayed instead?
My previous receiver showed a red DTS Logo when playing normal DVDs.
Regards,
Roger
Direkte link til dette indlæg Sendt: 05-Juli-2009 kl. 11:27
If your player outputs a decoded signal (PCM), there will be no DTS logo but only the PCM or Multichannel.
But if you change the settings in the player to BITSTREAM (DIRECT), you will have a DTS HD MA in your reciever display.
Redigeret af Kampus - 05-Juli-2009 kl. 16:15
