højtalere til hybrid rørforstærker
Forumnavn: Hi-Fi
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=103049
Udskrevet den: 24-Maj-2025 kl. 06:23
Emne: højtalere til hybrid rørforstærker
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 12:36
hej
jeg overvejer at købe et par højtalere til min forstærker (link: http://www.mav-audio.com/base/product/tube_magic_a1/hardware_a1 - http://www.mav-audio.com/base/product/tube_magic_a1/hardware_a1 )
min max pris er 3000-4000 kr for et sæt
jeg vil foretrække at de har en lidt varm lyd så man kan holde ud at høre knap så gode indspilninger/mp3 filer
jeg skal kunne høre dem inden jeg køber dem, så det betyder at det kun kan være i hifiklubben (sønderborg)
brugt er ikke en mulighed
edit: det er til et stereo setup kun til musik
edit2: gulv højtalere er ikke muligt, da jeg ikke har plads Ouch
edit3Wink:
det er ikke nødvendig at de kan spille voldsomt højt
citat: ang forstærkeren: " next up was the speaker output. I was a little wary hooking my speakers up, as I knew the power rating on the A1 was a little low, but a quick check with my speaker manuals revealed they would be driven safely, though barely, with wattage this low. So with that in mind, not expecting much, first up I hooked up my pair of Infinity Entra Ones, a mid-range pair of bookshelfs, via SignalCable Ultra Speaker Cables. I put on John Cougar Mellencamp's Scarecrow album first, and found myself quickly reaching for the volume knob. Not up - but down! In near-field listening, I found that my 89db bookshelfs were more than comfortable at around 9-10 o'clock on the volume knob. Getting results like these, I started to think this is what the A1's speaker outputs, I believe, were meant for: near-field or small room speaker listening. The imaging was just alright, and the sound signature was quite similar to headphone output, but I quickly realized that my speakers were the weak link in the chain here.
I decided to hook up my JBL 4311b studio monitors up next. I figured it was time for something heavier, so I put on Powerslave by Iron Maiden. Now these are some hefty speakers, it takes a decent amp to drive these to a level befitting of Maiden. I shouldn't have been so skeptical, Aces High blew me away. Raw power, the true sound signature of the A1 really shone through on the JBLs. The A1 was able to drive the JBLs to far more than adequate levels, needless to say I was speechless.  I think the A1 really sounded excellent on this album, the sweet midrange really shone through - distorted guitars sounded incredible. Sadly, the bass, though it had the weight, still sounded a bit loose, it just wasn't quite as tight as I felt it could have been. Now with speakers like these, i'd say the A1 would perform suitably in even a moderately large room - I didn't feel like power was an issue with high sensitivity speakers (91db) like these. Trust me, I drove this amp hard during Rime Of The Ancient Mariner, all the way up to 12-2 o'clock - more than enough for me, and I didn't hear any noticeable clipping, maybe the very smallest amount of soft clipping - or perhaps it was the sound of the picture frames rattling against the walls! ." fra head-fi og
"Easily drives Insignia NS-B2111 with plenty of output power remaining" også fra head-fi
har i nogle gode bud?
Skrevet af: db89
Skrevet den: 18-Oktober-2011 kl. 12:45
Av-connection har da vist også en stor butik nede ved sønderborg.
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 12:48
ja det er da også rigtig Embarrassed så er den butik også en mulighed
Skrevet af: Irenicus
Skrevet den: 18-Oktober-2011 kl. 12:52
Med en rør forstærker vil jeg anbefale højttalere med høj følsomhed, gerne et godt stykke over 90dB, her er Concept tættest på hos HFK, gerne deres gulvmodeller.
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 13:02
ok takSmile men nu er min forstærker en hybrid, både rør og solid stage, gælder det samme så?
jeg glemte at skrive at gulv højtalere, ikke er muligt, da jeg ikke har plads Ouch
Skrevet den: 18-Oktober-2011 kl. 13:10
Den leverer ikke meget power, så høj følsomhed er nok et must.
Se evt. på Klipsch som AV Connection fører, de benytter horn som er noget mere effektivt, og deres mindste standerhøjttaler har en effektivitet på 91dB, hvilket måske kunne gå.
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 13:20
dem kan jeg ikke finde?
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 13:32
i skal nok lige læse min første post igenWink
Skrevet den: 18-Oktober-2011 kl. 13:54
Det er denne http://www.av-connection.dk/?PGr=5237&ML=1888 - http://www.av-connection.dk/?PGr=5237&ML=1888
Der nævnes at den virker med de 89dB til near field, eller i et småt rum, hvilket miljø skal du benytte dem i?
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 13:56
et lille værelse 6- 8 m2 tror jeg
Skrevet den: 18-Oktober-2011 kl. 15:00
Jeg havde antaget noget i stue størrelse.
I den størrelse tror jeg ikke at du behøver at tænke ALT for meget på følsomheden. Så er det vel bare ud og lytte hos HFK og AVC. Køb evt. forstærkeren først, og lån de højttalere du er interesseret i med hjem.
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 15:01
ok Smile jeg har allerede forstærkeren
nogle modeller du synes jeg skal lytte til?
Skrevet den: 18-Oktober-2011 kl. 15:18
Hos HFK er det nok B&W der har den mørkeste klang, Dali er noget lysere, et sæt 686 koster også 3000,- og er en fremragende HT, Argon kender jeg ikke.
Hos AVC kender jeg System Audio, som jeg ville kalde slank og lyd i lyden, Dynaudio er meget neutral, graver dybt i sangene og er svære at drive, så disse 2 vil nok ikke være hvad du leder efter. De andre mærker har jeg ikke haft fornøjelsen af endnu, men er meget nydgerrig efter at høre Elac, Audiovector og Monitor Audio.
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 17:25
ok mange takSmile
Skrevet af: pnhh
Skrevet den: 18-Oktober-2011 kl. 17:42
 Focal Chorus 706 kunne også være et bud.Men så skal du en tur til Esbjerg.
Oppo 93. Lg 55 b6
Hegel 80. Clear Audio Concept. Hjemmebyg
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 17:47
det kan jeg måske godt komme. har du et link?
Skrevet af: pnhh
Skrevet den: 18-Oktober-2011 kl. 17:52
http://hifi-freaks.dk/webshop//index.php?cPath=99_103 -  http://hifi-freaks.dk/webshop//index.php?cPath=99_103
Oppo 93. Lg 55 b6
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 17:55
takSmile
Skrevet den: 18-Oktober-2011 kl. 18:35
Mindes i øvrigt at HiFi Freaks kommer på hjemmebesøg :)
Skrevet af: hks777
Skrevet den: 18-Oktober-2011 kl. 21:31
jeg tvivler på de kommer til sønderborgWink
Skrevet af: pnhh
Skrevet den: 18-Oktober-2011 kl. 22:13
 Sådan som jeg læser det kører de over hele landet.Så de kommer garenteret også til sønderborg.
Oppo 93. Lg 55 b6
Skrevet af: hks777
Skrevet den: 19-Oktober-2011 kl. 11:27
ja det ser sådan ud.Smile
andre som har nogle inputs til nogle højtalere jeg skal lytte til?
Skrevet den: 19-Oktober-2011 kl. 11:48
Hvis vi forestiller os at du ikke er låst til Sønderborg, vil jeg også anbefale DLS, Rega og engelske mærker i det hele taget.
Skrevet af: hks777
Skrevet den: 19-Oktober-2011 kl. 11:56
tak det prøver jeg at kigge på, jeg kan komme rimeligt omkring i sydjylland
Skrevet af: hks777
Skrevet den: 25-Oktober-2011 kl. 07:38
andre som har nogle inputs?
