Disse er indenfor mit budget:
http://www.hifipriser.dk/Listproducts.asp?ID=189&Parent=&Sort=&Gallery=&Producent=0&Rating=0&Max=16000&Soegeord=&Direction374=2&Sorted374=40&Equal159=&Check30984=175454&True28311=&Trueval28311=112409&True28310=&Trueval28310=112408&Direction1026=2&Sorted1026=&Direction728=2&Sorted728=&Direction821=2&Sorted821=&Direction1528=2&Sorted1528=&True28554=&Trueval28554=114990&Direction719=2&Sorted719=&True28550=&Trueval28550=114318&True28551=&Trueval28551=114320&True28549=&Trueval28549=202057&True27529=&Trueval27529=106519&True27528=&Trueval27528=106536&True28208=&Trueval28208=111822&True27530=&Trueval27530=106530&True27749=&Trueval27749=108037&True28490=&Trueval28490=113603&True28552=&Trueval28552=114321&Submit.x=17&Submit.y=9 - http://www.hifipriser.dk/Listproducts.asp?ID=189&Parent= &Sort=&Gallery=&Producent=0&Rating=0&Max =16000&Soegeord=&Direction374=2&Sorted374=40& ;Equal159=&Check30984=175454&True28311=&Trueval2 8311=112409&True28310=&Trueval28310=112408&Direc tion1026=2&Sorted1026=&Direction728=2&Sorted728= &Direction821=2&Sorted821=&Direction1528=2&S orted1528=&True28554=&Trueval28554=114990&Direct ion719=2&Sorted719=&True28550=&Trueval28550=1143 18&True28551=&Trueval28551=114320&True28549=& ;Trueval28549=202057&True27529=&Trueval27529=106519& amp;True27528=&Trueval27528=106536&True28208=&Tr ueval28208=111822&True27530=&Trueval27530=106530& ;True27749=&Trueval27749=108037&True28490=&Truev al28490=113603&True28552=&Trueval28552=114321&Su bmit.x=17&Submit.y=9
Hvilket ville i vælge?
Måske et helt andet?
