1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: 24: 25: 26: 27: 28: 29: 30:
Changes: fixes: - better preview of bad I-Frames, and some rare resolutions - exception at older JRE when saving preview frame with DAR option - wrong assoziation at ac3 header look-up - exceptions when decoding RDS-data from mpeg frames - ttx-pagematrix info erased at process completion - dvb subicture, page id 0 wasn't accepted - ...
changes: - omits padding packets in TS private streams - mpv ES demux, omits data from seq.end to seq.start - more error and processing logs - re-scan when changing stream type assignment - ac3.bin incl. 192kbs 2/0 frame - ...
new: - subpicture, 2nd export format accessible - dvb subpicture, new entry for mtv adria - export RDS-data stream 0xDA (e.g. video EPG) - optional pre-read buffer (1MB, for special access acceleration), thx to Artemis1121 - optional creation of cuttermaran project file (info-xml >=1.61), thx to Arnaud - italian language file, thx to mfsav - modif. idct sources for OS2, thx to Ronald - pes demux, check for errors in pes_extension (probs with some vdr-plugins) - ttx, enhanced parity check (drop lines with more than x parity errors); iniKey only, std: SubtitlePanel.maxParityErrors=2 (0..40) - mpa decoding, wav/aif export with optional fade-in/out; iniKey only, std: AudioPanel.fadeInOutMillis=2000 (1..5000) - ... |
