Bumtious/AV-Forums og Panasonic 50VT50
Forumnavn: TV
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=111841
Udskrevet den: 23-Maj-2024 kl. 11:07
Emne: Bumtious/AV-Forums og Panasonic 50VT50
Skrevet af: Hother
Skrevet den: 31-Maj-2012 kl. 09:05
Bumtious fra AV-Forums, er i mine er én af de mest vidende om plasma TV. Bumtious har gennemgået Panasonics nye VT50 serie. Og her er hans "Dom"
Guys, I have tried to ensure this makes sense and spelling and grammar is correct. This is a long post.
I had a 50”VT50 on loan for a few days. It’s a brand new out of the box production line set.
I ran it for 50 solid hours with out of the box settings on using THX normal preset just watching normal TV via Sky HD. During the “evaluation” I have just been watching Sky broadcast content and with the exception of the calibration to set the panel up properly, I have not run or been watching test patterns. I did not look at Blu Ray content or 3D. I’m not going to get technical, I’m not going to show measured results, because they don’t always translate to what you actually see. (The Panasonic 20 range was a classic example of this, They were the sets used on an ISF course that I was on with Mark, and although the CIE gamut charts were spot on, red was not correct and everyone there could see this it was orange, it was not until an external processor was used that things got nearer to correct, but that caused purple snakes!!!!) Last year’s sets quite frankly were a disaster too.
AND YES I’m comparing The VT50 to my personal and benchmark set, a KRP 600a, for me that was the whole point of this exercise and it’s what I do with every set or piece of equipment I’m potentially interested in purchasing to replace an existing component of my personal setup.
I want to try and make this clear, I don’t take what any reviews conclude from anywhere as gospel, I respect them all and take on board the opinion of the reviewer, but don’t always agree with their conclusions, neither should you. Nor should you take what I found as gospel either. I adopt the same view with anything else such as HIFI or cars.
With AV/HIFI, I always evaluate in my home with my setup. Its personal and I know how I prefer things to look and sound, and like anything you use for a long time you get to know it and get used to it. Sure listen to the opinions read owners experiences and views, read the reviews. It is then your personal choice how they wish to use the information. I would suggest armed with this information you go look for yourself and trust your own judgement. NO ONE ELSE HAS YOUR EYES, EARS OR POCKETS (or your other halfhopefully)
All I’m doing is sharing my personal opinion of my own evaluation. I have certain boxes I want to tick. Above all, I want to engage with what I’m watching or listening to, in the case of a TV I can’t if I’m being distracted by performance issues. (I personally can’t engage with 3D as I quickly get agitated and fatigued, I choose not to watch 3D presentations even at the cinema).
I’m looking primarily for an accurate image as I know how it should look as I’ve been doing this since I was 9 (Learning how to set up CRT’s in the mid 70’s). I require a set to have the ability to achieve good colour accuracy, good low black level and a stable image with no visible voltage capping, all sets are capped but sets that do this well are not noticeable, the last two ranges from Panasonic were a joke. I pick up easily on any sort of flickering or “wrong” colour. An experienced musician knows when something is out of tune. I’m the same with a TV.
Again let’s be clear, there is NO such thing as the PERFECT TV, certainly at domestic level, there never has been and I doubt there ever will be, grade 1 level professional monitors cost many thousands (23”Sony’s cost £20k plus) so your £2000 hokey cokey 2000 with 3D and smart TV along with baby changing facilities certainly is not going to perfect, let alone a £1000 or a £500 set. I would make the suggestion that some people’s expectations need to be more realistic.
(Day one) First thing on opening the well packaged VT50 is the build quality. Vastly superior to last year’s VT30, the silver trim was badly finished and the joins could be seen at did not meet up properly, not so here and I think its looks gorgeous.
Firing it up, it wakes up really quickly, and is again rapid going though the easy setup, switching into home mode and then into onto Sky, first thing I noticed is how green the image is, (normal preset) this is usual for a Panasonic set, look at them in showrooms compared to the others. Most others look blue, Panasonics push towards green (They are tuned for the Japanese market). Remember I have this next to a correctly set up benchmark KRP.
Next thing that stood out is the ability of the filter, ITS GOOD, really good. And the MLL level is very low enough for superb dark detail, it is NOT krp level but certainly 5090 level, and that is plenty good enough, especially with the right amount of light applied in the room. Done properly YES the black IS at a level where it blends with the bezel and looks stunning. Repeat, stunning. Now again the filter is not quite as effective in daylight as the KRP but is one of the best out there and next to an ST and GT in a showroom you can see what a positive advantage it gives the VT over these other sets in the range. A good filter will prevent the image washing out in brighter ambient light. Panasonic sets when they had glass on them used to be appalling with this. Not the VT50.
Putting the set into THX mode, to my eye it looks wrong, far too green (it’s fixable) and I will talk about this later, so I put it into pro1, with default settings. It is obvious this preset luminance is too low and seems to be uneccesarily tuned to work in a particular way, sadly it makes makes the image look flat, so I put into normal mode. Now in normal mode the image gains a decent amount of luminance though colour is wrong, far too much blue and green. It does look kind of OK, sort of safe, but for me irritatingly wrong. And in normal mode the image has much more noise in the image, a mixture of dithering and PWM noise and IS worse than my KRP. All other modes (except dynamic) are cleaner. There IS more dithering in this year’s sets but NOTHING to worry about and nothing that should not be considered normal. Dithering is being applied to create better colour gradation and reduction in false contouring. For the short run in period, I settled on the normal THX preset.
I Watched the set all night, caught up with 4 episodes of Fringe AND FINALLY, Panasonic seem to have cracked it, a rock solid stable panel. No floating blacks, no jumping contrast, no gamma shifts, just rock solid and Panasonic are to applauded for this because NO other domestic set since the pioneers have been able to achieve this level of image stability and integrity, when I made any adjustments to contrast and brightness they were smooth and showed no sharp jumps or drops. (I definitely agree, reference level). Repeat, no other brand of sets currently on the market achieves this performance. Last sets to achieve this was 8G and 9G Kuro, and this is what I have meant in other posts when referring to picture integrity critical to good distraction free viewing. The ST, and GT are almost as stable however when I have tested these with a greyscale bar pattern these sets still show some colour tinting in some of the bars. The VT does not.
The only things that did raise their heads that was distracting was flickering and false contouring. Panasonic sets have always suffered from this as it’s simply the way the panel is driven; however, it is not a problem for everyone. It has been dramatically reduce this year and bothered me less and less as the set ran in, and was worse with the normal preset. Finally retention, I fell asleep on my sofa around 2am watching Comedy Central HD, when I woke up at 5am and turned over the logo was there in all its glory. It did disappear just watching normal TV after a day and I expect this to be a non issue once the set has hours on it. This happened with a GT50 in the store that lent me the set and that set after watching BBC news but that set now does not suffer with any retention.
The set in my moderately lit living room during the day in THX mode is bright enough but colour does not seem to be tracking consistently. The effect is that sometimes skin tones look awesome, other times people look jaundice and oversaturated. Trying pro1 is the same it’s far too dim. Pro1 at night is ok, but your room has to be lit with care to ensure the luminance is enough. I have 2 of the Ikea tall floor standing Chinese style paper lamps either side of my set up. (Usually I use just 1 of them).
(Second day, 50 hours use). Time to calibrate and see how it looks against the KRP.
Measurements taken using a Quatum data 780 signal generator, Klien K10 and Calman Pro V4.
Using the THX out of the box preset, the measurements against the target were ok but the image looked too green and just wrong. Gamma at 2.2 gave reading of 2.0, 2.4 was almost spot on, just a little low at 30 and 70IRE points. I measured my KRP, and all ok so the measuring kit was functioning correctly, I calibrated pro1 on the VT.
Panasonic has certainly fixed the mess that was the VT30. The set seemed responsive, changing the values seemed to do what they are supposed to do. They still interact with other values but nothing that could not be sorted, just a bit annoying, but no cms within domestic Tv’s are perfect as the chips used are cheap $2 or so (see later).
Once done, greyscale looked spot on and a check with grey bars confirmed this and was identical to the KRP with no signs of colour tinting contamination. Gamma was near enough and gamut was hitting all the right points. (Bear in mind this set will be a demo set for the retailer that kindly lent it to me, and I will be calibrated properly once settled in their showroom). So back with Sky, sometimes the set looked really good, other times colour looked wrong, green and flat.
I Used normal viewing content to test calibration, I used HD versions of Coronation Street, the last episode of Fringe, Dexter, Hawaii 5-0, Kung Fu Panda2, Champions league final, Waterloo Road, last week’s Graham Norton, The Chase (ITV quiz show 5.15PM), 2 and a Half Men, Friends, along with SD versions of the same shows, as well as Sky News HD, Sky Sports News HD. There is also no complaint from me with the way the set handles SD. However, if your settings are too aggressive then it can become noisy. Sometimes skin tones looked stunning, but not consistently enough and that has always been a problem for me with Panasonic TV’s, on too many occasions as mentioned earlier there is too much green. Skin tones looked correct at some of the time but looked jaundice and oversaturated at others.
I was also very aware of false contouring especially in dark scenes and seem to be a mixture of the 50Hz bug and looking worse because of the excessive green push as purple and green are the colours that stand out with false contouring if skin tone is wrong. There is also some non defeat able sharpening of static images going on, if you watch some football, as the camera moves around then stops then starts again you can see this engaging and disengaging on the crowd and looks like a quick flicker. I also noticed these occasional vertical lines when watching football but is far less obtrusive than Pioneers infamous dirty screen which never bothered me as that is a small price to pay for everything else that the Pioneer does well. Again I looked at the content on the KRP and it all looked awesome and correct, with little false contouring.
http://www.avforums.com/forums/newreply.php?do=newreply&p=17043587 - Quote |
Yesterday, 11:20 PM |
# http://www.avforums.com/forums/17043594-post52.html - 52 |
Part 2
So first I set about trying to fix the colour tracking, and what I was seeing seemed to point to gamma and colour not tracking properly. The following “quoted” text advice is taken from the Gamut measurement section of Calman4.
“Getting good results from Color Management System (CMS) calibration requires understanding the goals. Without knowing which variables are the most important to optimize, it is all too easy to perform a calibration which produces good looking charts and terrible looking pictures.
For primary colors, the absolute luminance is of critical importance. (Much more important than the precise location of the primary on the CIE gamut chart.) Delta L of all primary colors should be reduced below 3, and the absolute luminance of the primary colors should match one another as closely as possible. Particularly avoid the situation where one primary is far brighter than the others.
For secondary colors, hue is critical. Your first goal in calibrating secondaries is to reduce Delta H to the minimum possible.
Then work with the CIE chart to get the primaries and secondaries as close as you can, without ever sacrificing the two main goals above".
Now as I’ve hinted, I own a Lumagen Mini processor, this has advanced deinterlacing and scaling capabilities as well as extensive colour management, with differing selectable greyscale parameter adjustment up to 21 points and advanced gamma controls along with a raft of other controls to fine tune the image. The chips used in these products are over $100 just for cms. This is only handling processing and colour management yet costs more than a 50” GT50, (just to put it into prospective)
I wanted to see if I could fix this colour issue without the processor and I can confirm the controls on the set can unlike previous ranges which could not. With much experimenting with the gamut, manipulating the red, green, cyan and yellow points using saturation, hue and luminance controls skin tones can be made to look more natural and not jaundice looking. It’s very hard to explain but when its right, its right and conversations with another experienced calibrator confirmed he was having trouble fixing this also. The charts don’t always tell the full story. Fixing this almost totally eradicated false contouring being a distraction In fact it was on par with the KRP. (You will never clear it with plasma)
Having got colour right, what could be done to get extra luminance out of the panel. Compared to the KRP, the image was still dull, it’s fine at night with the right sort of lighting in the room, during the day in even the slightest amount of day light the panel is just not bright enough.
This is going to be hard to explain but here goes. If you use a white windowed pattern, you fill around 25% of the screen, taking a measurement at 100ire in each of the presets I got the following readings:
Pro1 95, Game 101, THX Day 170, THX Cinema 105, Cinema 101, Normal 162, Dynamic 202. (cd/m2)
Then using a full white raster I got the following:
Pro1 69, Game 70, THX day 71, THX cinema 69, Cinema 69, Normal 71, Dynamic 71. All the readings from all presets are basically the same.
You can easily test this, freeze an advert with a bright white background and change presets, brightness does not budge.
Freeze a dimly lit scene, change presets and see what happens, easy to see the differing brightness levels. Now this is about dynamic range, you can almost describe it like differing gear ratios with a car and it’s acceleration response. Using that analogy with the pro1 preset 1st second and third gears acceleration/torq are set too low, its sluggish to respond to get to decent cruising speed.
It is just acceptable in a dimly lit room but during the day even in a fairly dark room, the light output is too low, especially compared to the KRP. You can’t fix the other presets, advanced CMS and gamma is not available. It was possible to manipulate the CMS to give extra luminance, but you have to balance it carefully and consistently across all the colour points but there is only so far you can go.
This is where I introduced the processor. Placing the set into 1080p direct, keeping all the settings on the VT I adjusting the white level (correct name for contrast) this TOTALLY dealt with and basically looking at the KRP and the VT I saw the same image. Both looked AWESOME. In fact at times it was better than the KRP and I have to say it seemed to have the warmth and dynamics of a good CRT.
Forgetting the processor for a moment, The VT set up correctly and used in isolation is quite simply the best domestic set Panasonic has ever produced and YES in my honest opinion it is a match and maybe even betters 9GLX Kuro. There are pros and cons and I will give my opinions shortly.
I have spent hours working on 9G Kuro’s. Looking at the 50”VT50 I had I can safely say the MLL levels (with the hour meter at 65 hours) betters 9GLX. I don’t need to see that side by side, I’m confident of that. The VT will not go as bright using the preset that matters, pro1 but everything else that really matters to giving a great image is present.
MLL is better on the KRP but not by much and as I will never recommend watching a TV in a completely blacked out room, (unless watching 3D, then IMHO it’s the only way to watch 3D) using my Ikea lamp MLL on both looked identical. That is dark enough to provide outstanding proper black levels that no other brands TV’s currently on the market in the UK (other than Panasonics own GT50 and ST50), can provide.
Using the processor with the VT you have the ability to raise luminance tracking to the same level as the KRP. You then have an undoubted equal in terms of critical picture performance criteria. You can also calibrate the other presets as well as the pro1/2 presets as you would use the processor to do the calibration and would be even more accurate.
Some Pro’s and cons VT50 vs 9GLX. Pro’s Sleek design Smart TV capability 3D Freeview HD Freesat HD Less dithering with bright colours so looks cleaner
Con’s Harder to calibrate correctly More dithering in darker scenes Brightness levels Flicker (if you are prone to it) False contouring 50Hz bug Non defeatable static image edge enhancement.
Equal MLL level Colour accuracy when set up correctly Image stability and integrity
KRP vs VT50. The differences are the same apart from MLL and the filters ability to reject ambient light. The KRP is better. But it is close and if you do not have the sets side by side the performance of the VT is outstanding and from what I have seen so far, nothing gets close to the VT.
I could list more but you get the idea, it’s up to you to look at the differences and decide.
For me all I can say is “it’s about time”. As a standalone product my advice to 9GLX and KRP owners is that quite frankly the VT with all that it has to offer is a set worthy of consideration if you want to change to a set with more facilities as the important aspect of picture quality with 2D is now taken care of. For the areas of performance that I know set the Pioneers apart against Panasonic sets I would suggest that you ask yourself the following “can live with it” questions.
Look closely at is the light output from the VT in the only modes that can bet set up correctly for colour accuracy, pro modes. False contouring is more pronounced against the Kuro’s but can be controlled with correct set up. 50hz issue. And flickering, only you can decide on this one and it seemed to lesson as the hours racked up, maybe I just got used to it, but different presets were worse than others with Normal being the worse.
Using the Lumagen the above issues to fix can be made almost non issues. It cleans up 50Hz motion but does not completely eradicate it, but it became acceptable to my eye. False contouring with correct colour tracking was only distracting if I went close up to the set and the light output became a total non issue. It makes a superb VT absolutely awesome. You can even manipulate the edge enhancement to be a non issue as you have controls for horizontal, vertical and diagonal sharpness and texture.
To sum up, it’s a great TV, there are pros and cons, go look for yourself. The risk for me is how will the set change as the hours rack up, every year the past 5 years the aging management process has been all wrong and performance rapidly drops off after 500 or 1000 or 2000 hours. Hopefully that has been sorted.
The VT’s performance on its own is superb, with the Lumagen, which I already own, it’s awesome AND the fact that I will be soon moving in with my new girlfriend I need a smaller set (55”). As wonderful and understanding as she is my 600a is too big for the room. With the Lumagen I would actually say the VT equals the KRP in quite a few areas and surpasses it in others TO MY EYES.
The Lumagen will add £1300 plus and needs setting up properly on top of that. So is likely to make a 50”VT50 cost around £3400 (still £100 less than a LX508 was by the way). But with the Lumagen it truly is a reference performer . I have a 55VT50 waiting for me and my beloved KRP600a is available as of now in the classified section. So will my 4280 as need a smaller set in the bedroom.
Skrevet af: bantam
Skrevet den: 05-Juni-2012 kl. 18:49
Altid godt at læse gennemgang af et TV fra en entusiast. Jeg har læst indlægget med stor interesse, specielt fordi Bumtious har nogle passager om dynamic false contouring (DFC), som jeg mener er det største udestående Panasonic har på deres plasma-TV.
Jeg er forbavset over, at Bumtious postulerer, at DFC-problemet kan mindskes vha. CMS'en, hvilket ikke virker troværdigt, hvis man forstår, hvordan DFC opstår (i sub-field-drive). Man kan selvfølgelig skrue så meget ned for grøn (eller farverne) at problemets synlighed reduceres (men det giver alt andet lige andre problemer). Han siger også, at DFC kan mindskes ved brug af en Lumagen videoprocessor - men det giver heller ikke helt mening, da denne jo ikke har nogen indflydelse på sub-field-drive-implementeringen i TV'et.
Jeg vil eksperimentere med dette selv, for at få en fornemmelse af, hvor langt man kan komme med CMS'en. I hvertfald vil jeg forsøge at se lidt nærmere på den omtalte green push.
Bumtious modsiger http://www.hdtvtest.co.uk/news/panasonic-tx-p50vt50b-p50vt50-201204101757.htm?page=Calibration - HDTVtest's gamma-målinger , idet HDTVtest mener at indstillingerne af gamma stemmer overens med det målte, mens Bumtious måler en lavere gamma, end indstillingerne indikerer. Det er en anden snak, hvordan dette sker og hvem, der har ret - men det kan have noget at gøre med APL-funktionen i TV'et (altså hvordan lysudbyttet mindskes med øget panelbelastning) i samspil med de anvendte testmønstre.
En anden interessant vinkel er i øvrigt, at man tilsyneladende vil kunne få et bedre billede (mht. farvegengivelse og lysstyrke) ved at bruge ISFccc-interfacet på TV'et (men det er Bumtious ikke inde på her). Til dette kan anvendes ControlCal - men det er ikke gratis. Jeg tænker stadig over, om det kan betale sig at kaste pengene efter den nødvendige ControlCal-profil for at efterprøve dette.
I mellemtiden er jeg i gang med at undersøge, om vi kan finde en metode til at dokumentere eksistensen og omfanget DFC, da det er noget, der ikke træder frem i kolorimetriske målinger i f.eks. reviews.
------------- /lars
Skrevet af: bantam
Skrevet den: 06-Juni-2012 kl. 18:00
Jeg fortsætter lige min monolog her i tråden, efterhånden som jeg bliver klogere på nogle af de spørgsmål, der er rejst ovenfor:
Det er på VT30 ikke muligt at reducere DFC vha. CMS'en eller andre indstillinger i TV'et brugermenu. DFC er væsentligt mere udtalt i THX-mode end i PROFESSIONEL1/2 og BIOGRAF. NORMAL er værre end THX og det er DYNAMISK (som forventet) også. Uanset hvad man rører ved i PROFESSIONAL1/2-indstillingerne, er forbliver DFC på samme niveau: Det bør heller ikke kunne ændres, da DFC stammer fra sub-field drive-algoritmen (et samspil med bevægelsesanalyse og pulsbreddemodulation af subpixels).
Jeg vil teste tilsvarende på VT50: Det kan være det er anderledes (men jeg forventer det ærligt talt ikke - men så er der jo plads til at blive positivt overrasket).
Det er indtil videre lykkedes at fotografere fænomenet - noget som ikke er lykkes tidligere - men nyt fotoudstyr og ændret metode har faktisk kunnet dokumentere fænomenet på en måde som stemmer ganske godt overens med det, som min makker Humperdink og jeg ser.
Vi skal arbejde lidt mere med metoden og sammenligne med foto af andre TV (samme metode og udstyr ellers), for at synliggøre forskellen.
EDIT: Rettet slåfejl omkring sammenligning mellem THX og PROFESSIONAL1/2 mht. mængden af DFC.
------------- /lars
Skrevet af: Hother
Skrevet den: 06-Juni-2012 kl. 18:37
Jeg må erkende, at jeg ikke helt er bekendt med alt det du beskriver Lars, og mere spændende bliver det, når mit indtryk af VT50 er, at det er et aldeles fremragende TV
Skrevet af: hopgreve
Skrevet den: 06-Juni-2012 kl. 18:57
Det er da godt nok lidt indviklet...Så er anbefalingen vel at bruge THX indstillingen ?. Rasmus Larsen ( Flatpanels ) benytter jo ellers Pro 1-2 for lige at få det sidste ud af tvèt..... MVH
------------- PANASONIC 55CX725 | Pioneer VSX832 | TP TUBE 500/200/160 | PANASONIC BD220 | ATV4K
Skrevet af: bantam
Skrevet den: 06-Juni-2012 kl. 18:59
Jeg har jo så kun testet på VT30, ST50 og GT50 - og der er ikke nogen synderlig forskel. Om VT50 er anderledes vides ikke. Problemet med DFC er, at det ikke kan forklares ret godt, og det er svært at fotografere, da det er en dynamisk billed-artefakt.
Her er http://cafe.postech.ac.kr/papers/iconference/2006_Reducing%20Motion%20Artifact%20of%20PDP%20Using%20Motion%20Information.pdf - et link til et dokument, der fortæller lidt om problemet og forslår en løsning (bemærk i øvrigt, at det er et dokument fra LG). Endnu en forklaring og et forslag til en løsning findes i dette http://www.es.ele.tue.nl/~dehaan/pdf/54_Sid_pdp_mc.pdf - dokument fra Philips.
Den korte udgave af problemstillingen kan udtrykkes således: Hvis betragterens øjne følger en bevægelse i billedet, som er hurtig nok til, at de pixels, som synet fejer hen over, ikke er tegnet fuldstændigt færdige (altså med andre ord: indenfor et field) vil lysinformationerne fra disse pixels blandes sammen og derved skabe forkerte farver. Hvis man holder blikket stift rette mod et punkt på skærmen og ikke følger panorering/bevægelse af objekter på billedet, ses fænomenet ikke.
Dette billede er taget ved at panorere (kan ses på teksten i billedet) med en passende lukketid på VT30 i THX-mode (PAL):
Billedet svarer ret præcist det, som jeg og Humperdink oplever. Det sker i kort tid - men specielt i dette klip og et par andre, som vi har fundet og gemt, er det et vedvarende fænomen, som alle, som vi har vist det til, kan se.
Vi vil førsøge at forbedre fotometoden og lave sammenligninger med Pioneer 9G og etv. et par andre plasma-TV (og et LCD for en god ordens skyld - selvom det principielt ikke må optræde der, da LCD-paneler er analog teknologi modsat plasma-paneler, der er digitale).
Uanset om vi kan systematisere dataindsamlingen og vise forskellene mellem forskellige TV, er billedet ovenfor repræsentativt for det, som vi ser på de ovenfor nævnte TV.
------------- /lars
Skrevet af: bantam
Skrevet den: 06-Juni-2012 kl. 19:00
My bad - skrev forkert.
Skulle være: THX er værre end PROFESSIONAL1/2.
Retter straks.
Problemet med PROFESSIONAL1/2 er så, at disse indstillinger er ret lyssvage (ligesom BIOGRAF) i forhold til THX. Dette kan som nævnt _måske_ løses gennem ISFccc-interfacet.
------------- /lars
Skrevet af: Hother
Skrevet den: 06-Juni-2012 kl. 19:10
Jeg kan så berette, at faktisk det du beskriver, har jeg checket ret meget for ifm min artikel om 55VT50, og fandt ikke de problemer du beskriver omkring hurtige panoreringer - godt nok med et lidt andet formål, end det du beskriver.
Kan det tænkes, at problemet opleves forskelligt fra menneske til menneske - lidt ala crosstalk
Edit: så lige din rettelse, jeg benytter Pro 1 og 2
Skrevet af: Stereolab
Skrevet den: 06-Juni-2012 kl. 19:16
Overstående billede af DFC minder mig lidt om regnbue-effekten på single chip DLP projektorer.
Skrevet af: bantam
Skrevet den: 06-Juni-2012 kl. 19:17
@Hother:
Problemet opleves ganske givet forskelligt fra person til person. Jeg kan sende dig nogle klip - men lad være med at se dem, hvis du er i tvivl om du kan se det... de kan ændre dit liv for altid...
Det er i øvrigt ikke nødvendigvis hurtige panoreringer, der er problemet: Det er bevægelser generelt - og specielt i hudfarver ses problemet som vist ovenfor (grønne og magenta slanger og skygger). Tager omkring en Pana-forhandler en af dagene og tester på VT50.
------------- /lars
Skrevet af: bantam
Skrevet den: 06-Juni-2012 kl. 19:19
Stereolab skrev:
Overstående billede af DFC minder mig lidt om regnbue-effekten på single chip DLP projektorer. |
Ja - men det ser alligevel anderledes ud: Der er mere tale om specifikke regnbuer med RGB-indhold. Problemet kan iøvrigt tænkes at eksistere på 3-DLP, da billeddannelsen i den type displays minder om den måde, som plasma-paneler laver billedet på (men jeg har aldrig set det selv).
------------- /lars
Skrevet af: Hother
Skrevet den: 06-Juni-2012 kl. 19:24
bantam skrev:
@Hother:
Det er i øvrigt ikke nødvendigvis hurtige panoreringer, der er problemet: Det er bevægelser generelt - og specielt i hudfarver se problemet som vist ovenfor (grønne og magenta slanger og skygger). Tager omkring en Pana-forhandler en af dagene og tester på VT50. |
Takker for tilbudet Lars omkring clips, det tør jeg ikke kigge på efter din beskrivelse
Så vil jeg hellere vente på resultatet af dine observationer, eller leve i lykkelig uvidenhed, for jeg har ikke observeret det som jeg mener, at du er inde på. Jeg har godt nok læst nogle ting omkring ureglmæssigheder i hudfarve, men mener nu heller ikke, at jeg har set disse fænomener
Skrevet den: 06-Juni-2012 kl. 19:30
Er det ikke signal afhængigt ? har da engang imellem set det du har taget et billede af , fex liebhaverne på TV2. Det er lige som om at det er signalet fra enkelte kameraer på en tv station , men ved andre indslag er der ikke nogen problemer....Eller er det en helt anden problematik ?..... MVH
Skrevet af: SVP03
Skrevet den: 06-Juni-2012 kl. 19:37
Tænkte lidt det samme. Kameraet ved optagelserne, eller Har Pana ikke altid et eller andet motion, hvad ved jeg, slået til. Gælder det også BD film i 1:1 pixel.
Men i har nok allerede overvejet de muligheder.
------------- SVP03
Skrevet af: Sigida
Skrevet den: 06-Juni-2012 kl. 19:42
Jeg har lige fået udstillet 65vt50 i fona køge, nogle der ved hvorfor den kan hakke ved tennis, måske en der kan hjælpe med indstillinger ;) den står i thx mode.
------------- Samsung 65HU7505
Pioneer VSX-LX50
SVS 5 satelite SVS SB2000
JVC HD750
Sony PS4
Skrevet af: Hother
Skrevet den: 06-Juni-2012 kl. 19:52
Sigida skrev:
Jeg har lige fået udstillet 65vt50 i fona køge, nogle der ved hvorfor den kan hakke ved tennis, måske en der kan hjælpe med indstillinger ;) den står i thx mode. |
Næh, men prøv at sætte panelet på PRO 1, her er næsten alt unødvendigt slået fra
Skrevet af: Sigida
Skrevet den: 06-Juni-2012 kl. 19:56
synes skærmen bliver for mørkt i pro1, husk den står i oplyst lokale og pro1 er mørkere end thx som er ret mørk. samsung es8005 havde ikke dette problem men stod så generelt meget ringere med alt andet. troede også man havde slået alt fra i thx.
Pioneer VSX-LX50
JVC HD750
Sony PS4
Skrevet af: JeTex
Skrevet den: 06-Juni-2012 kl. 20:45
IFC ( Intelligent Frame Creation ) kan være slået til, dette skal frakobles. I øvrigt kan jeg så berette, at der ikke ses nogen form for hakken i billedet på mit tv.
Skrevet af: JeTex
Skrevet den: 06-Juni-2012 kl. 20:52
bantam skrev:
@Hother:
Jeg oplevede DFC i stor grad på VT20, men i langt mindre grad på VT30 ( meget meget sjældent ). Min opfattelse af problemet, syntes jeg hang sammen med dårligt signal/lav opløsning. Nu har min VT50 kun kørt i 15-20 timer, og her har jeg endnu ikke oplevet DFC.
Skrevet af: Sigida
Skrevet den: 06-Juni-2012 kl. 20:53
Nej det var slået fra men prøvede at aktivere det da der stod det modvirkede rystelser men kunne ikke se den store forskel. Det er ikke altid det hakker, det var ved bestemte sekvenser at den gjorde det. men kan det være at thx mode er mere lavet til film end sport.
Pioneer VSX-LX50
JVC HD750
Sony PS4
Skrevet af: fredtoft
Skrevet den: 06-Juni-2012 kl. 22:16
@Bantam
Super billede. Det er rigtig godt lykkedes jer at dokumentere lige præcis hvordan DFC ser ud (når det er værst). Det må have taget noget tid at få den til at sidde lige i skabet.
Der er i øvrigt ingen tvivl hos mig om at VT50 lider af DFC, omend i mindre grad end VT30.
Og så er vi i øvrigt enige om at det er noget mærkeligt vrøvl at man skulle kunne udbedre det med CMS. Jeg er (som du) naturligvis instillet på at blive belært om det modsatte, men kan simpelhen ikke finde nogen logisk sammenhæng som skulle kunne udbedre DFC med CMS. Og så hjælper det vel heller ikke at man kan afhjælpe noget med et CMS, hvis vi antager at det betyder at CMS skal indstilles til andet end Rec 709.
I øvrigt burde man vel kunne tilgå ISFccc interface med CalMAN uden at betale for en ControlCAL profil til VT50? Det er i hver fald min plan når VT50 dukker op.
------------- Branchemedlem - THX og ISF certificeret kalibrering http://www.av-blog.dk/ - AV Blog - strøtanker om kildetro gengivelse af lyd og billede
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 08:09
Så vil jeg hellere vente på resultatet af dine observationer, eller leve i lykkelig uvidenhed, for jeg har ikke observeret det som jeg mener, at du er inde på. Jeg har godt nok læst nogle ting omkring ureglmæssigheder i hudfarve, men mener nu heller ikke, at jeg har set disse fænomener |
Helt fint, John - målet er jo heller ikke at "lære" dig at se problemet - jeg har bare været irriteret over det, siden jeg rigtigt kom til at være opmærksom på det sidste år i forbindelse med test af en G30'er: Det har været svært at forklare problemet, så andre kan relatere til det - men nu har vi fundet en metode, der i det mindste viser, hvad vi ser.
Man ser som sagt tydeligt problemet i de testklip vi har (der "lever" slangerne i flere sekunder ad gangen), men i langt den største del af tiden optræder DFC som "glimtvise slanger" - specielt i ansigter (som magenta/grøn) og i mere pastelagtige og gråtoner som gule/blå skygger (Hvis man skruer helt ned for FARVE, vil man se DFC i ansigtsklippet ovenfor som gule/blå slanger).
Det overordnede håb med omtale af DFC i offentligheden er, at Panasonic bliver så opmærksom på problemet, at de afsætter ressourcer til at forbedre kommende produkter i et højere tempo end det sker for tiden. I mine øjne er det stort set det største enkeltproblem ved deres high-end plasma-TV som skal udryddes, før vi kan være tilfredse (så kan de bagefter arbejde med at få den kunstige skarphed væk (evt. blot som en feature, man kan slå fra) og lidt mere lys på PROFESSIONEL1/2).
------------- /lars
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 08:14
MVH |
Nej - det er ikke indtrykket, at det er kildeafhængigt - men det ses måske mere på lavere opløst materiale. Man kan naturligvis sige, at det er kildeafhængigt på den måde, at det ikke er i alt materialer, man ser DFC. Hvis der er anvendt hård kompression og forkert gamma i forhold til TV'et, vil det måske kunne forstærke problemet - men så kan problemet også være til stede i still-billeder.
Det interessante er, at man ikke ser det på f.eks. Pioneers 9G (DRIVE MODE 1, kan ses svagt i DRIVE MODE 2) og de LG + Samsung plasma-TV (har ikke fluekn*ppet deres indstillinger), som jeg har været i nærheden af (jeg bliver ved at med at teste: Vi har lavet en billedserie for Pioneer 9G også og vil gå VT30 efter i PROFESSIONEL1/2 ASAP, da THX er værre end PROFESSIONEL1/2 (billedet på forrige side er taget i THX-mode).
Vi håber at komme omkring et topmodel Samsung plasma-TV fra 2011 snarest.
------------- /lars
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 08:19
Men i har nok allerede overvejet de muligheder. |
Vi er klar over fejlkilderne med kameraet og slår alle "bevægelsesforbedringer" og den slags fra før optagelsen. Det er også klart, at et kamera ikke fungerer som vores øjne, da det integrerer lyset over et endeligt tidsrum (der åbnes, der opsamles lys, der lukkes), modsat vore øjne som integrerer kontinuerligt.
Tricket i metoden er, at vil ønsker at reproducere og formidle det, som vi selv ser - uden at det sker på et helt uredeligt grundlag.
Ingen af TV'et indstillinger (ud over skift mellem forskellige billed-tilstand (THX, BIOFRAF, PROFRESSIOEL1/2 etc.) er i øvrigt i stand til at ændre væsentligt på forekomsten af DFC: Selv hvis man sætter FARVE=0 optræder det stadigt, bare i andre farver. Overscan FRA/TIL har heller ikke nogen betydning.
------------- /lars
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 08:21
Sigida skrev:
synes skærmen bliver for mørkt i pro1, husk den står i oplyst lokale og pro1 er mørkere end thx som er ret mørk. samsung es8005 havde ikke dette problem men stod så generelt meget ringere med alt andet. troede også man havde slået alt fra i thx. |
Jeg er enig - men det er ellers i PROFESSIONEL1/2 (og BIOGRAFT) af DFC-problemet er mindst (men stadig til stede). Desværre rækker lyset ikke i et oplyst lokale - der er THX dog bedre.
------------- /lars
Skrevet af: SVP03
Skrevet den: 07-Juni-2012 kl. 08:43
Nu får jeg et 50Vt50, så skal jeg se om jeg kan se det.
Hvilke specifikke klip er bedst at se det i.
------------- SVP03
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 09:07
Nu har min VT50 kun kørt i 15-20 timer, og her har jeg endnu ikke oplevet DFC. |
Som nævnt ovenfor, synes DFC ikke at være afhængig af materialet som sådan (når vi ser bort fra frameraten knytet til materialet: 60[Hz] håndteres absolut bedst (sådan er det også på Pioneers 9G plasma-TV)).
Der er dog et andet fænomen knyttet til kompression og forkert gamma (min anden kæphest), som kan lave tilsvarende magenta og grønne skygger i hudfarver - men i dette tilfælde, er der tale om et statisk fænomen, der kan fanges på et still-billede (modsat DFC, som kun ses i bevægelser). Jeg filosoferede lidt over det for længe siden http://forum.recordere.dk/forum_posts.asp?TID=101601&PID=1034195 - her .
------------- /lars
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 09:17
Hvilke specifikke klip er bedst at se det i. |
Jeg har jo mine egne klip - men vi diskuterer lige nu, om det er muligt at lægge dem ud til download et sted.
Ellers kan du bruge dette klip som jeg har omtalt tidligere i en anden tråd i forb. med VT30:
Et eksempel, der fremprovokerer dynamic false contouring, kan findes i filmen " http://www.imdb.com/title/tt0450340/ - ": Helt i starten (allerførst) panoreres der over en scene med skyer. I de tydeligste/skarpeste overgange mellem lyse og mørke områder vil der optræde tydelig dynamic false contouring (der viser sig som grønne og magenta bånd/slanger i visse farveovergange), hvis man ikke kører skærmen i 60[Hz], enten via 3:2-pulldown eller via IFC=MAKSIMUM.
------------- /lars
Skrevet af: kennethbrdk
Jeg har hentet en isf day og isf night indstilling ovre på avforums til vt50. Jeg er klar over, at det ikke præcist kan bruges til andre paneler end det det er foretaget på MEN der er to andre,der har brugt dem og som synes det har givet et bedre billed end THX cinema bl.a. skulle hudfarver være bedre.Mit spørgsmål er, kan man selv lave to indstillingerpå VT50hvor man kan sætte ISF day og ISF night ind eller kræver det mere end som så....... kan man f.eks. bruge prof 1. og prof 2. og ændre profilen til de indstillinger som angivet i de to ISF profiler....
Skrevet af: Hother
Skrevet den: 07-Juni-2012 kl. 09:23
kennethbrdk skrev:
Jeg har hentet en isf day og isf night indstilling ovre på avforums til vt50. Jeg er klar over, at det ikke præcist kan bruges til andre paneler end det det er foretaget på MEN der er to andre,der har brugt dem og som synes det har givet et bedre billed end THX cinema bl.a. skulle hudfarver være bedre.Mit spørgsmål er, kan man selv lave to indstillingerpå VT50hvor man kan sætte ISF day og ISF night ind eller kræver det mere end som så....... kan man f.eks. bruge prof 1. og prof 2. og ændre profilen til de indstillinger som angivet i de to ISF profiler.... |
Den har jeg ledt efter længe - ku du ikke lige copy - paste indstillingerne i denne tråd
Skrevet af: Hother
Skrevet den: 07-Juni-2012 kl. 09:32
Altså for at svare på dit spørgsmål - som jeg forstår det:
Så er ISFcc opdelt i netop en day and night indstilling, nemlig i Pro 1 og 2. Og sidder godt nok på job, men Pro 1 mener jeg er day indstillinger og Pro2 er night indstillinger. Og du kan godt lægge indstillingerne ind i din opsætning. Nu ved jeg jo ikke hvor omfattende de indstillinger du har fra AVForum er, for der er jo rigtigt mange muligheder for at indstille de forskellige parametre i ISFcc menuerne
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 09:33
Lad os se indstillingerne - så kan vi se, om de kræver ControlCal eller CalMAN for at lægge dem i TV'et.
------------- /lars
Skrevet af: Hother
Skrevet den: 07-Juni-2012 kl. 10:03
bantam skrev:
Lad os se indstillingerne - så kan vi se, om de kræver ControlCal eller CalMAN for at lægge dem i TV'et. |
Det er muligt at det er disse settings der omtales:
http://new.avsforum.com/t/1410156/the-official-panasonic-vt50-settings-thread - http://new.avsforum.com/t/1410156/the-official-panasonic-vt50-settings-thread
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 10:11
Hvis det er dem, som Hother nævner, skal man f.eks. bruge ControlCal: Der er nogle indstillinger, som ikke findes i brugermenuen på TV'et. Hvis man piller dem ud, fordi man ikke bruger ISFccc-interfacet (via. f.eks. ControlCal), kan man lige så godt bruge PROFESSIONAL1/2. ISFccc-interfacets ekstra muligheder skulle angiveligt give flere mulighed for f.eks. mere lys/punch i billedet.
Til ControlCal-programmet skal man have en profil, som jeg mener koster i omegnen af 50USD.
------------- /lars
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 10:28
Det er ikke helt ligetil - og det kræver et kamera med fast lukketid samt en hel masse forsøg. Hvis man fortsætter længe, har vi indtil videre kunnet fange noget, der er repræsentativt for det, som vi ser.
fredtoft skrev:
I øvrigt burde man vel kunne tilgå ISFccc interface med CalMAN uden at betale for en ControlCAL profil til VT50? Det er i hver fald min plan når VT50 dukker op. |
Jo - det har du nok ret i. Jeg er bare lidt fedtet - og ControlCal + profil er så vidt jeg kan se væsentligt billigere end CalMAN. Ved du om CalMAN understøtter alle de samme settings som ControlCal?
------------- /lars
Skrevet af: humperdink
Skrevet den: 07-Juni-2012 kl. 11:08
Jeg har lagt et af de klip som vi har benyttet til download her: http://dl.dropbox.com/u/3156172/DFC/DFC_American_Idol.mpg -
Det er et glimrende klip til at afsløre DFC, da det er en længerevarende panorering over en række ansigter.
Prøv med forskellige indstillinger af "Intelligent Frame Creation" og i forskellige billed modes (Normal, THX, Pro1 etc.) for at se effekten.
------------- Alt for meget grej at opgradere på.
Skrevet den: 07-Juni-2012 kl. 11:31
http://new.avsforum.com/t/1410156/the-official-panasonic-vt50-settings-thread - http://new.avsforum.com/t/1410156/the-official-panasonic-vt50-settings-thread |
Det er disse indstillinger og de kan lægges ind via ControlCal men håbede også at man kunne lægge dem ind manuelt, men det kan jeg forstå på Bantam ikke er muligt med alle indstillingerne Jeg har nemlig skrevet hele l..... ned i håb om, at man kunne lægge det ind selv Er det nemt at bruge det ControlCal....
Skrevet den: 07-Juni-2012 kl. 11:38
Du fandt dem selv kan jeg se længere nede i tråden
Skrevet af: Hother
Skrevet den: 07-Juni-2012 kl. 11:59
kennethbrdk skrev:
Du fandt dem selv kan jeg se længere nede i tråden |
Vist vist, jeg er så god til at vente - jobskade
Skrevet den: 07-Juni-2012 kl. 14:05
Til ControlCal-programmet skal man have en profil, som jeg mener koster i omegnen af 50USD. |
Jeg tror ikke ControlCal er nødvendigt. Alle de nævnte indstillinger er tilgængelige i brugermenuen på de amerikanske VT50. Jeg mener dog ikke der er meget mening i at benytte amerikanske indstillinger til et europæisk VT50. Panelerne er de samme, men firmware er væsentlig forskellig, eksemplificeret ved at CATS og panel brightness slet ikke er tilgængelige på europæiske modeller. Medmindre VT50 er noget helt specielt, så går de amerikansek menuer også til 100, mens vores går til 60.
Skrevet den: 07-Juni-2012 kl. 14:14
Jeg tror ikke ControlCal er nødvendigt. Alle de nævnte indstillinger er tilgængelige i brugermenuen på de amerikanske VT50. Jeg mener dog ikke der er meget mening i at benytte amerikanske indstillinger til et europæisk VT50. Panelerne er de samme, men firmware er væsentlig forskellig, eksemplificeret ved at CATS og panel brightness slet ikke er tilgængelige på europæiske modeller. Medmindre VT50 er noget helt specielt, så går de amerikansek menuer også til 100, mens vores går til 60. |
Hmm ok - det er jo positivt, hvis man selv kan indtaste alle oplysninger, men negativt hvis der er forskel på værdierne i forhold til de angivet og dem jeg kan indtaste. Tak for den oplysning
Skrevet af: Rod83
Skrevet den: 07-Juni-2012 kl. 15:14
Så er den klar: http://www.flatpanels.dk/test.php?subaction=showfull&id=1339053745 - flatpanels.dk - test af VT50 50" versionen
------------- Panasonic TX-P50G20E ( http://forum.recordere.dk/forum_posts.asp?TID=79511&title=brugeranmeldelse-af-panasonic-txp50g20e - anmeldelse )|Onkyo TX-SR308B|Sony BDP-S550|PS3-Slim
Skrevet af: Bruger udmeldt 33
Skrevet den: 07-Juni-2012 kl. 15:35
Jeg vil godt lige sige tak til ham der har oprettet tråden med ham der bumptious kommentarer. Det er sådan noget information der virkelig rykker. Tak til Fredtoft for at lave de bedste anmeldelser af tv på nettet. Det er sådan det skal gøres. Når man er færdig med at læse de anmeldelser så har man virkelig et godt udganspunkt som kan bruges til noget. Tak til Bantam og ham den anden specialist der er her. Det er bare dejligt at høre en spade blive kaldt en spade. Tv´ene får det kritik de skal ha og den ros de skal ha. Grunden til at det er så rart at høre er at jeg ikke selv er specialist i hvad alle de forskellige fejl er gør og hedder nødvendigvis. Men når jeg ser et panasonic plasma så har jeg aldrig været rigtig tilfreds, og så er det rart der er nogen specialister der kan bekræfte/afkræfte det man har set istedet for alle de andre test på nettet, hvor problemerne ikke bliver gjort ret store og hvor de næsten pr. automatik løber med den ene awards efter den anden. Ved godt panasonic stadig er et godt tv, og det kan jeg også sagtens selv se. Det kan nogen ting som især lcd´erne ikke kan. Der er bare det problem at de fejl panasonic så har er så irriterende at det faktisk diskvalificerer tv´et for mit vedkommende. Ved godt det ikke har meget med dfc at gøre dette indlæg, men syntes lige jeg ville give ros til den gode og nøgterne information de nævnte altid kommer med.
Skrevet af: SVP03
Skrevet den: 07-Juni-2012 kl. 15:43
Også lidt udenfor emnet.
Jeg laver lige en sammenligning af det Pana 50vt50 mod mit Pio krp-500a i næste uge.
Kan stille dem op ved siden af hinanden og smide det samme signal op i dem.
Men det kunne være fint at jeg fik at vide på hvilke film man skal kunne se det.
Det må jo være mere udtalt når 2 TV står side om side.
------------- SVP03
Skrevet af: sani
Skrevet den: 07-Juni-2012 kl. 15:53
Det er sådan noget information der virkelig rykker. Tak til Fredtoft for at lave de bedste anmeldelser af tv på nettet. Det er sådan det skal gøres. Når man er færdig med at læse de anmeldelser så har man virkelig et godt udganspunkt som kan bruges til noget. Tak til Bantam og ham den anden specialist der er her. Det er bare dejligt at høre en spade blive kaldt en spade. Tv´ene får det kritik de skal ha og den ros de skal ha. Grunden til at det er så rart at høre er at jeg ikke selv er specialist i hvad alle de forskellige fejl er gør og hedder nødvendigvis. Men når jeg ser et panasonic plasma så har jeg aldrig været rigtig tilfreds, og så er det rart der er nogen specialister der kan bekræfte/afkræfte det man har set istedet for alle de andre test på nettet, hvor problemerne ikke bliver gjort ret store og hvor de næsten pr. automatik løber med den ene awards efter den anden. Ved godt panasonic stadig er et godt tv, og det kan jeg også sagtens selv se. Det kan nogen ting som især lcd´erne ikke kan. Der er bare det problem at de fejl panasonic så har er så irriterende at det faktisk diskvalificerer tv´et for mit vedkommende. Ved godt det ikke har meget med dfc at gøre dette indlæg, men syntes lige jeg ville give ros til den gode og nøgterne information de nævnte altid kommer med. |
der er ingen tv der er perfekter og derfor er panasonic heler ikke... men kender du tv der er bedere and VT50 pt... når du skriver at panasonic er diskvalificeret for din vedkommende ,,, hvilke tv har du ... har den mindre skevanker and pana... eller er der bare såden at du ikke læger så stor vægt på dem ? for fejl kan vi finder på dem alle sammen
sorry for of topic
------------- Anthem,Lexicon,MK 150, Velodyne DD, Vienna Acustic BBG,Densen,Sonos,Apple dimser,osv
Skrevet af: Hother
Skrevet den: 07-Juni-2012 kl. 16:11
Jeg er helt enig med Sani. Det der er problemet i sådan en type af tråd er ikke sjældent, at det ikke er alle der i stand til at sortere oplysningerne i den rigtige kasse, forstået på den måde, at ting som nævnes her er ting, som man virkelig skal kigge efter med et meget kritisk og meget erfarent billedeøje. Og nogen kan se de små billedfejl, andre, og typisk langt de fleste, vil aldrig se fejlene.
Nu har jeg haft - jeg ved ikke hvor mange fladskærme, og jeg er ikke en pind i tvivl om, at VT50 har et af de bedste billeder som jeg har set, og at VT50 er et særdeles alsidigt og kompetent TV, med funktioner kom kan komme rigtigt mange til gavn.
Og, det var mig der oprettede tråden Og når en kapacitet som Bumtious erstatter sit KRP-500 med et VT50, så kan det ikke stå helt galt til med VT50
Skrevet af: Bruger udmeldt 43
Skrevet den: 07-Juni-2012 kl. 16:51
Bumtious is in love Og i den tilstand er det svært at være objektiv. Han har fået besked på at skille sig af med sit 60 tommer KRP, ellers.....
I sådan en situation kunne han sikkert finde PROS i et Denver TV
Skrevet den: 07-Juni-2012 kl. 16:56
Det må jo være mere udtalt når 2 TV står side om side. |
Hej , det lyder da som en rigtig god ide . Men er det ikke det bedste at vente , de plasma jeg har og har haft ændrer sig jo noget " over tid ".... MVH
Skrevet af: xcardman
Skrevet den: 07-Juni-2012 kl. 16:58
er enig intet tv er perfekt
men kan ikke rigtig noget andet tv i øjeblikket som slå en vt50 det viser alle test også
der er ikke noget rigtig alternativ, hvis man ser tv mest om aften og ikke ser tv i fuld sol mit led tv kan man ikke se en meter på, når lyset står ind i køkkenet tænk jeg anbefalede et LG 960 til Hother, da han tænkte og købe et led tv det må du meget undskylde, men er nok det mest elendige tv til 30000 kr man kan få http://www.flatpanels.dk/test.php?subaction=showfull&id=1338561376 - http://www.flatpanels.dk/test.php?subaction=showfull&id=1338561376
Skrevet af: Hother
Skrevet den: 07-Juni-2012 kl. 17:03
xcardman skrev:
er enig
intet tv er perfekt
No hard feelings, jeg havde - skal du se, nok ikke alene købt det på en anbefaling. Man skal også selv kigge
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 17:12
Jeg har svaret på dit tidligere spørgsmål om en film, hvor du kan se det, og Humperdink har i et indlæg lidt efter lagt en link til et klip, der viser fejlen. Det kan være, vi kan lægge et klip mere op.
Som udgangspunkt vil jeg sige, at det er ligegyldigt om det ene TV står i Langtbortistan og det andet i Sønderborg, men det kan selvfølgelig være en hjælp...
------------- /lars
Skrevet af: SVP03
Skrevet den: 07-Juni-2012 kl. 17:14
| Nu ved jeg godt i siger at det kan man ikke få mere. Men er KRP serien ikke samlet lige en tand bedre målt på billedkvalitet. Der er jo løbende nogen til salg herinde.
------------- SVP03
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 17:16
Tak for indsparket, Kim. Jeg har ikke set ISFccc-menuen for VT30/VT50. Har du en liste over indstillingerne?
Jeg er allermest interesseret i om PB-punktet er i vores modeller ie EU/DK?
Jeg har læst beskrevet, at man på VT50 via ISFccc-interfacet kan opnå korrekt farvegengivelse med en lysstyrke, der placerer sig et sted mellem THX Cinema og THX Bright Room. Måske er det noget du kan teste?
Har du testet tilsvarende på VT30 (altså mht. om ISFccc-interfacet kan vriste mere lys ud af TV'et end PROFESSIONAL1/2 uden at ødelægge farvegengivelsen og øge mængden af DFC)?
------------- /lars
Skrevet den: 07-Juni-2012 kl. 17:22
Hvis man kan hæve lysstyrken har det så andre ulemper , er der fex større fare for retention/evt burn-in ? Hvad ift ST50 , her er lysstyrken kraftigere , er der så også større risiko med den ?... MVH
Skrevet af: bantam
Skrevet den: 07-Juni-2012 kl. 17:27
Selvom man evt. kan løfte lysstyrken vha. ISFccc-indstillingerne, bliver det jo ikke lysere end THX Bright Room (og formodentligt heller ikke lysere end THX på VT30), så det burde være anvendeligt.
Jeg hører jo til de konservative, der anbefaler break-in i flere hundrede timer. Til formålet er min præference Burn-in Wash-DVD'en, der kan downloades her fra recordere.dk.
------------- /lars
Skrevet den: 07-Juni-2012 kl. 18:09
| Nu ved jeg godt i siger at det kan man ikke få mere. Men er KRP serien ikke samlet lige en tand bedre målt på billedkvalitet. Der er jo løbende nogen til salg herinde. |
jeg tænker på en ny skærm og ikke en monitor som min eller din. mener du også har en det er alså begrænset hvor mange som køber en skærm i dag uden tuner og højtaler men du har ret, en krp er nok samlet set en tand bedre i rå billedekvalitet
men synes nu pan har taget sig sammen for en gangs skyld frem for deres tidligere modeller
Skrevet den: 07-Juni-2012 kl. 18:25
Skrevet den: 07-Juni-2012 kl. 22:10
Har uploadet 3 video klip hvor DFC bliver fremprovokeret - det første klip er det samme, der bliver linket til i det nederste indlæg på side 3.
American Idol:
Clouds:
http://dl.dropbox.com/u/3156172/DFC/DFC_Clouds.mpg -
TV3 Spot:
http://dl.dropbox.com/u/3156172/DFC/DFC_TV3_spot.mpg - - http://dl.dropbox.com/u/3156172/DFC/DFC_TV3_spot.mpg
Skrevet af: pipper
Skrevet den: 08-Juni-2012 kl. 13:19
Skrevet den: 08-Juni-2012 kl. 17:21
Så kom min 55" VT50 ind af døren - så bliver det spændende om jeg bliver tilfreds med billedet
Skrevet af: Hother
Skrevet den: 08-Juni-2012 kl. 18:02
Skrevet den: 08-Juni-2012 kl. 18:50
Takker - Ja og så er det 9" større end mit nuværende så dårligt kildemateriale bliver sikkert voldstraffet i forhold til mit nuværende. Til gengæld forventer jeg mig meget af bluray materiale
Skrevet den: 09-Juni-2012 kl. 14:22
Kører I med 1080 pure direct - synes ikke jeg kan se en forskel på at den er til eller fra - kører med de indstillinger ovre fra flatpanels og hvad med 24P smooth - har i den fra eller....
Skrevet af: bantam
Skrevet den: 09-Juni-2012 kl. 15:49
Så fik Humperdink og jeg vurderet 50VT50 for DFC og taget lidt billeder af fænomenet.
Billedet herunder er taget i THX BRIGHT ROOM med de samme indstillinger for kamera og TV, som vi brugte ved tilsvarende test af 55VT30 på første side i denne tråd (dette for at kunne sammenligne med VT30 og vurdere udviklingen fra 2011 til 2012):
Vores opfattelse er, at hvis der er sket en forbedring, ligger den i intervallet fra meget lidt til ingenting.
En anden ting, som vi lagde mærke til (og med reference til det oprindelige indlæg hentet fra Bumtious allerførst i denne tråd) var et grønt stik i billedet. Dette kan tænkes at udspringe fra flere kilder:
(1) Forkert hvidbalance: Kan i THX-modes kun fikses gennem kalibrering via servicemenuen.
(2) Green push (for høj farvestyrke for grøn og måske gul/cyan): Kan ikke fikses i THX-modes, da der ikke er adgang til CMS.
(3) Forkert ( http://forum.recordere.dk/forum_posts.asp?TID=101601&PID=1034195 - for lav ) gamma: Nogle modes understøtter gamma-eqalizer-indstillinger, andre kun en overordnet gamma-justering. Problemet er, at man ikke med sikkerhed kender håndtering af gamma i hele signalkæden.
(4) DFC: Kan som udgangspunkt ikke fikses uden at aktivere IFC (MAKSIMUM).
Grundlaget for min mistanke til DFC som kilde til det grønne stik er, at jeg i rigtig meget af tiden (og med andet materiale end DFC-testmaterialet) observerede, at der var "mikrofine" og lynhurtige DFC-artefakter til stede i hudfarver, som dermed kommer til at virke grønlige eller gullige (Bumtious bruger udtrykket " http://en.wikipedia.org/wiki/Jaundice - jaundice "). Da vores syn er følsomt overfor grønt stik, har jeg en formodning om, at noget af det grønne stik kommer fra DFC. Toppen af DFC-effekten kan muligvis tages ved at minimere det grønne stik gennem justering af indflydelsen fra punkt 1, 2 og 3 (mens man stadig holder sig indenfor rammerne af kalibrering mod BT.1886/BT.709 (her er punkt 3 så en udfordring)).
En tredje ting, som jeg lagde mærke til (og som jeg også noterede for G30 og VT30) var, at der er nogen flicker i billedet: Fænomenet minder om det, man ser, når man ser et lysstofrør i periferien af sit synsfelt. Måske er det for at mindske crosstalk, da ”ON-tiden” for pixels virker forkortet i forhold til tidligere Panasonic plasma-TV (før 3D) og andre plasma-TV (som jeg er vant til at se på). Det virker ikke specielt distraherende, men jeg synes dog, at billedet er noget uroligt ved panoreringer uden IFC aktiveret. Måske er det der 50[Hz]-buggen stammer fra (pga. 50[Hz] sub-field-drive-algoritmen).
En stensikker kur for DFC ser ud til at være at sætte IFC=MAKSIMUM (de andre IFC-indstillinger fjerner ikke DFC). Jeg har ikke målt frameraten (refresh) på VT50 endnu, men mit gæt er, at det som for VT30 gælder, at panelet drives ved 60[Hz] i denne indstilling, og at den dertil hørende sub-field drive-algoritme bare er meget bedre end den, der understøtter 50[Hz]/24p. Dette kan være forklaringen på, at DFC ikke er noget, der omtales i særlig høj grad for US-modellerne - eller noget som japanerne selv har fokus på. Prisen for IFC=MAKSIMUM er naturligvis soap-opera-effekten. Jeg kan ikke vurdere, om den er forbedret siden VT30, da jeg ikke er vant til at se på IFC=MAKSIMUM på VT30. Vi har efterhånden samlet en del billedmateriale: Indtil videre har vi data fra Panasonic 55VT30, Panasonic 50VT50 og Pioneer LX-5090 (alle i forskellige skærmindstillinger, som har betydning for DFC-mængden). Idéen er at lave en fotomontage for sammenligning af resultaterne, men vi holder dem ind til kroppen lidt endnu, da vi overvejer om vi kan få et par relevante Samsung og LG plasma-TV med i sammenligningen. Indtil videre kan jeg røbe, at vi kan fremprovokere DFC på LX-5090, men en del mindre synligt end på VT50 i PROFESSIONEL1/2. Til gengæld kan vi fjerne DFC på LX-5090 (ved at justere panelets refresh).
Billedet ovenfor er som sagt lavet med 50VT50 i THX BRIGHT ROOM, hvor DFC er meget tydeligere end i PROFESSIONAL1/2-indstillingen, men mindre udtalt end i NORMAL (og naturligvis også i DYNAMISK).
Der flere (mindst tre) måder at observere fænomenet på og i fotomontagen kommer vi til at bruge to af dem med de testklip, der er linket til tidligere i tråden:
(1) STATISK: Fotografering af bevægelser i billedet mens kameraet står stille.
(2) PANORERING: Fotografering af objekter i bevægelse mens vi forsøger at panorere kameraet med bevægelsen for at simulere øjets bevægelser.
Den tredie metode er simpelthen at have f.eks. et ansigt på skærmen (som gerne skal fylde en væsentlig del af skærmarealet og ikke behøver at være et af de omtalte testklip) og så "virre" relativt hurtigt med hovedet fra side til side, mens man ikke fastholder blikket på noget fast punkt på skærmen.
Man kan gøre noget tilsvarende med et kamera, som jeg har gjort her med 55VT30 i PROFESSIONAL1-mode:
Her kan man i øvrigt se en indikation af, at PROFESSIONAL1-indstillingen producerer mindre DFC end THX-mode gør - men prisen er et mindre lysudbytte – og måske er der en direkte sammenhæng mellem lysmængden og synligheden af DFC.
Lad mig lige slutte af med at bekræfte, at filtret på TV'et gør det i stand til at levere bedre sort i dagslys end GT50, som igen er bedre i denne disciplin end VT30.
Noter:
Jeg skal understrege, at billederne er udvalgt som værende repræsentative for det, som Humperdink og jeg ser, og de tjener således alene som illustration af fænomenet og omfanget af det, når vi betragter TV’et. Billederne er kun beskåret og gemt i JPEG med mindst mulig komprimering.
------------- /lars
Skrevet af: bantam
Skrevet den: 09-Juni-2012 kl. 16:04
kennethbrdk skrev:
Kører I med 1080 pure direct - synes ikke jeg kan se en forskel på at den er til eller fra - kører med de indstillinger ovre fra flatpanels og hvad med 24P smooth - har i den fra eller.... |
Prøv at læse i http://www.avforums.com/reviews/Panasonic-VT50-TX-P50VT50B-P55VT50B-P65VT50B-50-Inch-Flagship-3D-Plasma-TV-Review_282/Test_Results.html - dette review : Der er nogle hints.
------------- /lars
Skrevet den: 09-Juni-2012 kl. 16:25
Hej bantam , super indlæg , glæder mig til sammenligningen med de andre tv... Ved ikke hvor meget du eller andre læser med på AVForums , men her har rigtig mange problemer med " lyse vertikale bånd " på skærmen. De fleste har dem i siderne , et par cm inde. Er det noget du har observeret ? , og evt kan forklare hvad er ? Mange får dem byttet af denne grund , bumtious mener at det kan være noget med skærmenes reflektions belægning. De billeder i har taget , synes du det er noget man sådan lægger mærke til . De skærme får trods alt super anmeldelser hele vejen rundt?.... MVH
Skrevet af: bantam
Skrevet den: 09-Juni-2012 kl. 16:47
MVH |
Jeg vil tror, at det er de færreste, der lægger mærke til DFC - og mange af de, som gør, vil formode, at der er tale om fejl i kildematerialet (de klip, vi bruger, kan man selv prøve at afspille på en LCD-skærm (f.eks. en laptop) for at konstatere, at klippene ikke indeholder fejl af den art, som DFC kommer til udtryk som).
Som jeg tidligere har nævnt, er DFC det enkeltstående problem, som jeg gerne så Panasonic fiksede ASAP. Tager man det ud af ligningen, er jeg meget tilfreds med skærmen - men i min bog betyder tilstedeværelsen af DFC, at der ikke er tale om en reference-skærm (men derfor kan den godt være god). Jeg ved ikke, hvorfor reviewers ikke kan se fænomenet - men de har måske ikke noget testmateriale, der egner sig til at reproducere problemet samt udstyr, der egner sig til at dokumentere det. Endelig kan det være, at de primært reviewer 60[Hz]-materiale. Kombinationer heraf er mulige.
Det bliver i øvrigt interessant at se, om Panasonic trækker DFC med over i OLED, som alt andet lige også kommer til at blande farverne vha. PWM (Pulse Width Modulation), som er grundprincippet i sub-field-drive. Her er http://www.faqs.org/patents/app/20090243499 - et patent , der fortæller om OLED og PWM. Valg af PWM-algoritme og motion-tracking og andre parametre er bestemmende for, om vi får synlig DFC eller ej. Dette http://www.faqs.org/patents/app/20080204372 - dokument , har en fysiologisk forklaring, som er funderet i et matematisk, fysisk princip, der nærmest oversættes til (lidt kryptisk) at "DFC ses, når PWM-algoritmens tidsmæssige tyngdepunkt for lysdannelsen ikke er vokser kontinuert med video-niveuet". Der er ikke noget hokus-pokus ved det som sådan.
Mht. til de lyse bånd: Det er ikke noget, jeg har lagt mærke til - men jeg har heller ikke kigget efter det. Kan du evt. smide et link?
------------- /lars
Skrevet den: 09-Juni-2012 kl. 16:52
http://www.avforums.com/forums/plasma-tvs/1639440-panasonic-vt50-part-five.html - http://www.avforums.com/forums/plasma-tvs/1639440-panasonic-vt50-part-five.html Dette er så " part 5 " af VT50 tråden , men de andre tråde der omhandler ST og GT har samme problem. MHT dem der har direkte sollys ind bagfra på deres VT50 , og hvor lyset går lidt igennem skærmen et par steder , ja så læs sidste side af dette link , der har bumtious løst problemet med et par stykker tape .... MVH
Skrevet den: 09-Juni-2012 kl. 17:47
bantam skrev:
Prøv at læse i http://www.avforums.com/reviews/Panasonic-VT50-TX-P50VT50B-P55VT50B-P65VT50B-50-Inch-Flagship-3D-Plasma-TV-Review_282/Test_Results.html - dette review : Der er nogle hints. |
Takker - jeg er dog ikke enig i deres observationer - hvis jeg slår 24 p smooth helt fra - så bliver bevægelserne unaturlige hurtige
Skrevet af: bantam
Skrevet den: 09-Juni-2012 kl. 18:25
hopgreve skrev:
Ved ikke hvor meget du eller andre læser med på AVForums , men her har rigtig mange problemer med " lyse vertikale bånd " på skærmen. De fleste har dem i siderne , et par cm inde. Er det noget du har observeret ? , og evt kan forklare hvad er ? Mange får dem byttet af denne grund , bumtious mener at det kan være noget med skærmenes reflektions belægning. |
DSE (Dirty Screen Effect) er som sagt ikke noget jeg har kigget efter. Efter en søgning på DSE og GT50 på Google, har jeg fundet nogle billeder af fænomenet. Jeg har ikke noget konkret bud, der er bedre en Bumtious' - ud over, at det måske kan være et problem med uniformiteten af fosforerne. Et gæt på en effekt, der stammer fra fremstillingsprocessen er nok bedste bud. Tilsyneladende er det ikke noget, der forsvinder (som f.eks. de grønne og magenta blobs vi så på sidste års modeller (det har jeg heller ikke kigget efter på dette års modeller)).
------------- /lars
Skrevet af: Hother
Skrevet den: 09-Juni-2012 kl. 19:42
Nu er det på ingen måde for at nedgøre Bantam&co store arbejde omkring DFC, for det er bestemt et spændende emne. Men, nu har jeg haft VT 20, hvor jeg fra tid til anden godt kunne se forskellige typer af mindre billedfejl, haft et VT30 - hvor jeg stort set ingen billedfejl har observeret, og nu har jeg et VT50.
Jeg har testet alle 3 modeller med alt hvad jeg har af testmateriale (Spears og Munsil, HD Basic m.v.), og jeg må blankt erkende at jeg ikke har set antydningen af hvad der beskrives.
Er det i virkeligheden sådan at DFC skal fremprovokeres, eller typisk optræder i relativt få billedsekvenser, eller som jeg tidligere har nævnt, at man måske skal være enten særlig kritisk opmærksom alternativt næsten være disponeret for at se fænomenet?
Skrevet af: Hother
Skrevet den: 09-Juni-2012 kl. 19:45
MVH |
Må sige at de lyse vertikale bånd er heller observeret på mit panel. Den eneste billedfejl jeg har set på VT50 er Flicker, og da kun i testmateriale. Det kan så retfærdigvis også opstå i andre sammenhænge
Skrevet af: JeTex
Skrevet den: 09-Juni-2012 kl. 20:08
MVH |
Må sige at de lyse vertikale bånd er heller observeret på mit panel. Den eneste billedfejl jeg har set på VT50 er Flicker, og da kun i testmateriale. Det kan så retfærdigvis også opstå i andre sammenhænge |
Og det er "fejl" så minimale, at man ved normalt brug intet ser. Ved meget kritisk kigning, opstår problemet i få sekunder, set over flere timers brug. Lad os blot glæde os over, at vi har et tv, der i 99,99999% af tiden yder outstanding sammenlignet med resten af tv markedet.
Skrevet den: 09-Juni-2012 kl. 20:27
Indtil videre er jeg godt tilfreds med skærmen men jeg er faktisk endnu mere overrasket over hvor go min sony skærm egentlig var. Dermed ikke sagt at vt50 ikke er bedre for det er den, men min sony var også 5 år gammel. VT50 har overrasket mig positivt på flg. områder - reflektion er yderst begrænset i forhold til hvad jeg havde frygtet, der er ingen larm fra skærmen, har ikke set skyggen af retention. Der er lidt med bevægelser hist og pist men ikke noget alarmerende og så er det klasse at have fået en 55" skærm
Skrevet af: Hother
Skrevet den: 09-Juni-2012 kl. 20:44
VT50 har overrasket mig positivt på flg. områder - reflektion er yderst begrænset i forhold til hvad jeg havde frygtet, der er ingen larm fra skærmen, har ikke set skyggen af retention. Der er lidt med bevægelser hist og pist men ikke noget alarmerende og så er det klasse at have fået en 55" skærm |
Hvad oplever du omkring bevægelser. Sidder lige nu og ser en udsendelse om pingviner, og her er mindsandten bevægelser - uden at jeg kan se noget forkert
Skrevet den: 09-Juni-2012 kl. 21:23
"Co" svarer lige på denne 1. Der er stor forskel fra person til person på om man kan se / lægger mærke til fænomenet / ved hvad man skal kigge efter hvornår. Hvis man kører med IFC i MAKSIMUM tilstand er der, som Bantam skriver, ingen DFC og man kan af gode grunde ikke se det. 2. DFC skal bestemt ikke provokeres - og det ses i særlig grad når der panoreres over ansigter i en vis hastighed. DFC ses ofte i hårgrænser og i områder, hvor der er skygger i ansigtet bl.a på næsen og yders på kinderne. Jeg gætter på at der er forskel på hvor vi rent faktisk kigger på et TV billede. Nogle ser "hele billedet" på en gang og er sikkert ikke så følsomme for DFC, hvor andre ser mere på detaljerne i billedet og spotter det ganske hurtigt. 2 af de 3 klip der ligger til download her i tråden er ganske almindelige TV billeder sakset fra ganske almindelige TV optagelser. Specielt i klippet fra "American Idol", hvor der panoreres hen over deltagerne illustrerer i hvert fald på smukkeste vis - så de fleste kan se det - at DFC er tilstede på Panasonics TV - såfremt man ikke har aktiveret DFC i dens MAKSIMUM indstilling. Jo mere man kigger efter det jo mindre skal der til før man kan se det blot ved de mindste bevægelser i billedet - hud bryder op i farvede striber så snart kameraet bevæger sig. 3. Jeg er selv indehaver af et TX-P55VT30Y og blev nærmest forskrækket over fænomenet allerede fra starten af ejerskabet. Jeg er enig med Bantam i at det er det største af de relativt få problemer Panasonic stadig har til gode at løse.
Skrevet af: Hother
Skrevet den: 09-Juni-2012 kl. 21:29
3. Jeg er selv indehaver af et TX-P55VT30Y og blev nærmest forskrækket over fænomenet allerede fra starten af ejerskabet. Jeg er enig med Bantam i at det er det største af de relativt få problemer Panasonic stadig har til gode at løse. |
Takker for svaret "Co" Jamen det giver mig da noget at gå efter. Har fo rlidt siden set en panorering over vel nogle hunderede pingviner, og så intet usædvanligt
Skrevet den: 09-Juni-2012 kl. 21:37
Hvis du spotter en flok hudfarvede pingviner med en god mørk italiener manke og der panoreres hen over dem i en vis hastighed og forholdsvis tæt på - så skal du bare se løjer
Skrevet den: 09-Juni-2012 kl. 21:45
Med andre ord... DFC vil sandsynligvis ikke forekomme så det er synligt ved den slags panoreringer du omtaler... det ses mest i farveovergange fra eksempelvis hår til hud eller i skyggeområder i huden når der panoreres i en vis hastighed.
Skrevet af: Hother
Skrevet den: 09-Juni-2012 kl. 22:08
humperdink skrev:
Med andre ord... DFC vil sandsynligvis ikke forekomme så det er synligt ved den slags panoreringer du omtaler... det ses mest i farveovergange fra eksempelvis hår til hud eller i skyggeområder i huden når der panores i en vis hastighed. |
Okay, og den type af pingviner har jeg nu aldrig set Nu har jeg set noget med 60 timer TV, skiftende mellem DVB-C og BD, og det meste af tiden ret koncentret for at spotte de forskellige ting, som anmeldere, og du og Bantam fremkommer med, og jeg har intet set af billedefejl, udover Flicker som jeg så på HD Basic. Så nu tror jeg det er tid, bare at nyde mit utrolige lækre billede, med en billededybde, farver og detaljer, som jeg ikke har set bedre. Og jeg har haft 8 paneler, heraf 1 Samsung, 3 Pioneer og 4 Panasonic.
Jeg er nok bare en heldig billedekartoffel
Skrevet af: bantam
Skrevet den: 09-Juni-2012 kl. 22:12
Man skal huske på, at når det største problem er løst, så er det største tilbage - og som sagt oplever jeg 2012-plasma-modellerne fra Pansonic som rigtig gode - men der er mere arbejde at lave, så hvorfor lade dem hvile på laurbærene?
DFC optræder i scener, der er i stand til at vise det - det giver sig selv: Vi kan jo nemt finde scener, hvor det ikke forekommer, og det testmateriale, du nævner, indeholder indeholder faktisk ikke ret meget, der er af en type, der viser DFC (jeg sidder og tænker på, om scenen med basketball-spillet på HD-Basics måske kan vise noget - men jeg tvivler). I langt de fleste tilfælde optræder det glimtvis - og oftest i hudfarver i bevægelse. Graden af gene vil jeg beskrive som rundt regnet på niveau med regnbuer i single-chip DLP-projektorer.Hvis der var tale om et overnaturligt fænomen, ville der (sandsynligvis) ikke være patenter og videnskabelige dokumenter, der beskriver løsninger på problemet (jo, måske fra Sovjettiden...).
Det er muligt at nogle mennesker bare er mere opmærksomme, har "urolige øjne" eller har et opfattesystem, der reagerer anderledes, men som tidligere nævnt har ingen, som vi har vist de klip for, der er linket til tidligere, været ude af stand til at se fænomenet. Klippet fra American Idol vil jeg langt fra betegne som noget odiøst klip: Det er et almindeligt forekommende klip - men dog af noget længere varighed end de fleste DFC-situationer.
Hvorfor Panasonic ikke løser problemet er uvist - jeg er sikker på, at de har kendskab til det - det er formodentligt ganske kompetente folk, de har. Der kan næsten ikke være tale om en situation, hvor de ikke er kapable eller hvor de bliver blokeret af et patent hos en konkurrent, da de jo har vist, at de kan løse problemet ved 60[Hz], med mindre der findes et specifikt 50[Hz]/24p-patent. Måske er de så hårdt presset økonomisk, at det er et område, der nedprioriteres (som det mindste af deres oplevede problemer), da det ikke er noget anmeldere har fokus på, og fordi folk har vænnet sig til så dårligt kildemateriale, at de tror der er tale om et problem med dette i stedet for med TV'et.
Jeg gætter egentligt på, at de aldrig får det løst, men jeg vil blive positivt overrasket, hvis de gør, før koreanerne løber med OLED-TV-markedet (og det uden DFC) eller måske først får styr på sortniveauet på deres plasma-TV. Så er problemet selvfølgelig løst.
------------- /lars
Skrevet af: Hother
Skrevet den: 09-Juni-2012 kl. 22:21
Det er vi helt enig om Bantam, og jeg håber meget, at du og eventuelle andre, får råbt Panasonic op
Skrevet den: 10-Juni-2012 kl. 08:57
Hvad oplever du omkring bevægelser. Sidder lige nu og ser en udsendelse om pingviner, og her er mindsandten bevægelser - uden at jeg kan se noget forkert |
Der er lidt "hakken" men mest på alm tv - nok "50 hz bug" (der var dog ingenting til em fodbold og det er jo det vigtigste !) samt det jeg vil kalde unaturlige bevægelser, som oftest ses ved hurtige panoreringer. Er ikke sikker på jeg har bemærket dfc og gider heller ikke at kigge efter det for ville sikkert irriterer mig grænseløst hvis jeg først bemærker det. Iøvrigt så jeg lidt golf på tv sport hd og når bolden er i bevægelser så mister bolden lidt detaljer, det samme gjorde sig gældende ved fodbold. Men som sagt - intet af det har været kriminelt og jeg er nærmest hysterisk hvad det angår så jeg er sikker på jeg nok skal blive rigtig glad for skærmen . Og lige afsluttende skal jeg tilføje at jeg har slået alt "billedfremmende" fra på skærmen og kører med flatpanels indstillinger.
Skrevet den: 10-Juni-2012 kl. 13:18
Jeg synes billedet bliver bedre for hver gang jeg bruger tv'et
Skrevet af: tvkartoffel
Skrevet den: 10-Juni-2012 kl. 13:40
bantam skrev:
Jeg gætter egentligt på, at de aldrig får det løst, men jeg vil blive positivt overrasket, hvis de gør, før koreanerne løber med OLED-TV-markedet (og det uden DFC) eller måske først får styr på sortniveauet på deres plasma-TV. Så er problemet selvfølgelig løst. |
Det er jo interessant læsning må jeg sige, og jeg finder det ret besynderligt at de forskellige problemer der har været rapporteret siden NEOplasma serien blev introduceret (G10, V10...) stadig ikke er rettet. De billeder du viser af de farvede "slanger" ved DFC ser virkelig forfærdelige ud og det burde uden tvivl rettes omgående. Det der undrer mig i den forbindelse er så at jeg selv byttede et G10 til et PZ85 for et par år siden. På det PZ85 som jeg har kigget på i 1000vis af timer har jeg til dato ikke set noget der ligner. Det har andre unoder, men "forkert-farvede slanger", opbrud i billedet ved panoreringer og flimmereffekten forkommer, efter hvad jeg kan se, slet ikke ved almindeligt kildemateriale. Jeg kan fremprovokere misfarvninger i visse konsolspil og jeg een gang lagt mærke til det på video (Den nær sort/hvide introscene i "Game of Thrones" hvor der panoreres inde i vinter-skoven). Kan det passe at det er unoder der er introduceret sammen med NEOpalsma eller er det mig der bare ikke kan se det på det TV? Nu har jeg ikke set de nyeste modeller, men jeg er gået uden om 20 og 30 modellerne pga. 50Hz buggen som jeg synes er rimeligt tydelig i visse sekvenser. MVH
Skrevet af: bantam
Skrevet den: 10-Juni-2012 kl. 13:54
Jeg vil teste på et 46PZ85 snarest - jeg mener, at det kan ses der, men faktisk er det sådan, at Humperdink sagde det samme til mig den anden dag: Han blev først opmærksom på det med 30'er serien (hvor IFC ikke anvendes i samme grad).
Mit gamle 37PX70 klarer disciplinen nogenlunde tilfredsstillende ved 100[Hz] refresh, mens det er mærkbart bedre ved 50[Hz] refresh (det kunne man stille på den model).
Prøv evt. at hente de klip, der er linket til her i tråden og kør dem med og uden IFC på PZ85'eren. Specielt klippet med American Idol er nemt at fange som misfarvninger rundt om personernes ansigter under panorering.
------------- /lars
Skrevet den: 10-Juni-2012 kl. 14:59
Ja det er meget tydeligt på American Idol og TV3 sport klippet, som er i 50Hz. Jeg kan ikke umiddelbart se noget i sekvensen med skyerne, men den er ifølge media info i 24,000Hz, så det er måske derfor. I forhold til det billede du har postet på side 1 fra TV3 så er DFC på PZ85 knapt så slemt. Jeg kan stort set ikke se noget på Ottesens kinder. Det er mest ved hårgrænsen man kan se noget, selv om der er en lille smule i ansigtet. Jeg har prøvet at skifte mellem RGB og Component output fra afspilleren. Det hjælper ikke på hverken TV3 eller A. I. Jeg har prøvet at tvinge 24Hz afspilning. Det hjælper heller ikke på DFC og giver naturligvis ulidelig hakken. Jeg har også prøver at slå overscan til og fra. Det gør heller ikke nogen forskel. I det hele taget er der ikke nogen indstillinger jeg kan lave på TVet, andet en at slå IFC til, der afhjælper problemet Hvis jeg tvinger afspilleren til 60Hz forsvinder DFC fra TV3 eller A. I. DFC forsvinder også med IFC. IFC er dog ubrugeligt på PZ85 så det er stadig bedre uden og jeg bruger det kun meget sjældent. DFC har åbenbart været det hele tiden, men jeg har bare ikke lagt mærke til det før nu. Det er tydeligt at at PZ85 er optimeret til 60Hz da det er den eneste indstilling der ikke giver tydelig DFC i de sekvenser. Jeg skal prøve at lægge mærke til om det også optræder ved 24,00 og 23,97Hz. Ellers er det da mærkeligt at Panasonic ikke retter det. PZ85 er en 2008 model og alle modeller siden da har haft både dét og andre problemer. Der har da været tid nok skulle man mene. Tak til humperdink for upload :-) MVH
Skrevet af: SVP03
Skrevet den: 10-Juni-2012 kl. 15:32
Fik mit i går. Nu skal det jo lige have lov at køre nogen timer. Det står kanongodt. Min første anke er dog placeringen af 230v udtag. Har købt et tyndt vægbeslag. Men det er udtaget der rammer væg, ikke særligt smart.
------------- SVP03
Skrevet af: klinge
Skrevet den: 12-Juni-2012 kl. 15:07
humperdink skrev:
Har uploadet 3 video klip hvor DFC bliver fremprovokeret - det første klip er det samme, der bliver linket til i det nederste indlæg på side 3. http://dl.dropbox.com/u/3156172/DFC_American_Idol.zip - http://dl.dropbox.com/u/3156172/DFC_American_Idol.zip http://dl.dropbox.com/u/3156172/DFC_Clouds.zip - http://dl.dropbox.com/u/3156172/DFC_Clouds.zip http://dl.dropbox.com/u/3156172/DFC_TV3_spot.zip - http://dl.dropbox.com/u/3156172/DFC_TV3_spot.zip |
Hvordan spiller man nemmest disse clips på en VT50?
Jeg kunne godt tænke mig at se dem på en VT50 i en butik. Jeg unzipper dem selvfølgelig først, men hvad så? - Kan jeg tage dem med på USB? eller skal den være formateret på en bestemt måde?
- Kan jeg uploade dem til et sted og så afspille dem direkte fra TV'et browser?
Nogen bud fra ejerne derude?
-Morten
Skrevet af: Hother
Skrevet den: 12-Juni-2012 kl. 15:14
-Morten |
Muligt at jeg tager fejl, men hvad er fidusen ved at se klippene på et VT50, klippene er jo optaget med de nævnte fænomer, så det er jo ikke e fænomen der alene ses på et VT50, men i dette tilfælde på alle displays
Skrevet af: klinge
Skrevet den: 12-Juni-2012 kl. 15:23
Hother skrev:
Muligt at jeg tager fejl, men hvad er fidusen ved at se klippene på et VT50, klippene er jo optaget med de nævnte fænomer, så det er jo ikke e fænomen der alene ses på et VT50, men i dette tilfælde på alle displays |
OK så havde jeg misforstået det. Jeg troede det var clips som var optaget "på linjen" og derfor ville se OK på nogen TV, men ikke på VT50'eren.
Men dvs. det simpelthen er optaget med kamera som filmer et VT50, sorry (har ikke set klippene endnu)
Skrevet af: klinge
Skrevet den: 12-Juni-2012 kl. 15:26
SVP03 skrev:
Fik mit i går. Nu skal det jo lige have lov at køre nogen timer. Det står kanongodt. Min første anke er dog placeringen af 230v udtag. Har købt et tyndt vægbeslag. Men det er udtaget der rammer væg, ikke særligt smart. |
Ja, det har jeg også lagt mærke til. Jeg vil også have et ultraslim vægbeslag og så bliver jeg nødt til at fræse i min gips/trævæg for at få plads til powerstikket... sikke noget rod.
Skrevet den: 12-Juni-2012 kl. 16:02
-Morten |
Hov stop stands... vi skal lige have stoppet denne misforståelse!!! Klippene indholder netop IKKE dette fænomen i sig selv - Det er det er ganske almindelige TV optagelser fra et Windows Media Center, der alene er valgt fordi de netop frembringer DFC på visse plasma TV. Prøv at afspille klippene på et hvilket som helst LCD TV og vupti - ingen DFC. Så derfor - man kan sagtens tage klippene med ud i en butik på en media player (Det er det Bantam og jeg har gjort hos en forhandler Bantam og vi kender). Vi har brugt den samme afspiller til test på samtlige de TV vi har udsat for klippene, så der er en ensartethed i de tests vi har foretaget.
Skrevet af: Hother
Skrevet den: 12-Juni-2012 kl. 16:10
-Morten |
Så derfor - man kan sagtens tage klippene med ud i en butik på en media player (Det er det Bantam og jeg har gjort hos en forhandler Bantam og vi kender). Vi har brugt den samme afspiller til test på samtlige de TV vi har udsat for klippene, så der er en ensartethed i de tests vi har foretaget. |
Som skrevet står, jeg kunne tage fejl. Men når i viser et billede med fejlen, så gik jeg ud fra - at det var med en optaget fejl - beklager.
Skrevet den: 12-Juni-2012 kl. 16:14
No problems Men det vi faktisk gør er at fotografere fejlen når den forekommer - det er lidt svært og kræver mange forsøg, men det lykkedes som regel at få taget nogle billeder som er rimeligt repræsentative for hvad vi ser når klippene ruller hen over en given skærm.
Skrevet af: bantam
Skrevet den: 12-Juni-2012 kl. 19:33
Jeg har lige fået et svar fra Turbe (ControlCal) mht. Panel Brightness-indstillingen: Den findes ikke på EU-modellerne, så indtil andet er bevist (gerne af fredtoft), ser det ikke ud til, at der er forskel på indstillingerne i brugermenuen og i ISFccc-interfacet for EU-modellerne heller. Jeg håbede/håber, at der var noget at hente PQ-mæssigt, ligesom på den hedengangne Pioneer 9G plasma-TV-generation.
------------- /lars
Skrevet af: SVP03
Skrevet den: 12-Juni-2012 kl. 22:19
| Som min forhandler sagde lige så tørt. Da stadig et fremskridt til 30 serien der havde fast kabel med plug
------------- SVP03
Skrevet af: klinge
Skrevet den: 13-Juni-2012 kl. 08:58
-Morten |
Hov stop stands... vi skal lige have stoppet denne misforståelse!!! Klippene indholder netop IKKE dette fænomen i sig selv - Det er det er ganske almindelige TV optagelser fra et Windows Media Center, der alene er valgt fordi de netop frembringer DFC på visse plasma TV. Prøv at afspille klippene på et hvilket som helst LCD TV og vupti - ingen DFC. Så derfor - man kan sagtens tage klippene med ud i en butik på en media player (Det er det Bantam og jeg har gjort hos en forhandler Bantam og vi kender). Vi har brugt den samme afspiller til test på samtlige de TV vi har udsat for klippene, så der er en ensartethed i de tests vi har foretaget. |
Sådan havde jeg også forstået det. Men så tilbage til mit oprindelige spørgsmål. Hvordan afspiller jeg dem nemmest i en butik?
Du skriver på en mediaplayer? Hvad mener du med det?
Skrevet den: 13-Juni-2012 kl. 09:08
Jeg har observeret dfc en gang på 4 dage på mit vt50 og det varede i ca. 10 sek. Det var i starten af en af kampene ved VM hvor kameraet panoreret hen over spillernes ansigter ved nationalmelodien. Generelt har jeg observeret meget få "billedfejl" i de 4 dage jeg har haft tv' et, hvilket har overrasket mig positivt. Man havde jo frygtet det værste når man hører nogles erfaringer rundt omkring.
50 hz bug forekommer yderst sjældent på mit eksemplar.
Skrevet af: bantam
Skrevet den: 13-Juni-2012 kl. 17:27
Den indbyggede mediaafspiller i TV'et kan ikke afspille alle de klip vi har, og den introducerede (så vidt jeg husker) ret meget judder, så vi opgav at bruge den og valgte i stedet at bruge den medieafspiller, som vi har brugt til alle vores forsøg (WD TV Live).
Vi har i øvrigt testet 60PZ950W den anden dag (LG's plasma-topmodel fra 2011). Her er det THX Bright Room (den billede-mode, der live udviser mest DFC på TV'et, men billedet er stadig nogenlunde repræsentativt for det, som vi oplever, når vi ser klippet i bevægelse (måske er DFC en anelse mere synligt i bevægelser, men det kunne ikke fanges bedre end dette på et still-billede). DFC er iøvrigt mere til den røde side på LG'en - med en snert af magenta/blå, som det kan ses i billedet (tinding, tæt på hårgrænse):
(optaget på samme måde som de øvrige billeder i tråden)
O.T.: Jeg synes, at LG'en håndterer panorering (i f.eks. fodbold) bedre end LX-5090 uden nogen form for "bevægelsesforbedringsteknologi". Jeg synes ikke jeg så noget, der mindede om jitter eller noget 50[Hz]-bug-lignende. Sortniveauet var til gengæld ikke noget at skrive hjem om - men en hurtig kalibrering af TV'ets hvidbalance fungerede overbevisende godt.
------------- /lars
