panasonic VT60 vs ZT60
Forumnavn: Plasma TV
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=130169
Udskrevet den: 22-Januar-2025 kl. 12:11
Emne: panasonic VT60 vs ZT60
Skrevet af: ThomasNorge
Skrevet den: 08-Februar-2014 kl. 16:19
Jeg vakler lidt. Begge TV koster 24999kr. Det ene er 65". Det andet er 60"
Jeg vil helst ha så stort som muligt. Men skal man gå på kompromis med størrelse for et billed, der på papiret er det bedste?
Jeg har ikke haft mulighed for at samligne dem side om side.
Hvilket TV ville du vælge?
Mvh Thomas
Skrevet af: vasif
Skrevet den: 08-Februar-2014 kl. 16:53
VT60E modellen koster kun 20300 Kr hos Cinemagic. Det er den europæiske model, som dog er præcis samme skærm, dog måske uden DVB-T2 tuner, som er relevant hvis du har Antenne, og har et boxer-abonnement med specifikke kanaler.
Her er en god side-by-side sammenligning. Ummidelbart hører man, at folk generelt ikke kan se den store forskel på billedkvaliteten.
http://www.electronichouse.com/article/hands-on_panasonic_zt60_and_vt60_plasma_hdtvs/D2/
But what if you live like a normal person and not a salamander from Lost River Caverns? The ZT60 has an important additional filter, a feature which Panasonic calls the Studio Master Panel, which cuts out most of the ambient light glare. It works. I had the TV in my basement, which is a dark cave, but even with the sconces and overhead lights turned on, the ZT60 looks good, noticeably better than the VT60. Both are great TVs; the ZT is a little better in ambient light. It’s worth recognizing though, that LED LCDs still generally look better in bright rooms than any plasma.
The VT also includes a pop-up camera on top. The camera is used for Skype video calls, facial recognition (for switching to different home screens) and games. The VT60 also includes front-firing speakers, while the ZT60’s speakers fire back and down.  The VT60s speakers do sound much better than the speakers in the ZT60, so if you’re not using a separate sound system or soundbar, that might be something to take into consideration.
Bottom Line
The choice between the two TVs is pretty easy: dark room=VT60; bright room=ZT60. If you’re looking for the best picture, either one of these may be it.
Skrevet af: vasif
Skrevet den: 08-Februar-2014 kl. 16:56
http://www.lydogbillede.dk/test/panasonic-60zt60/
http://www.flatpanels.dk/test.php?subaction=showfull&id=1368523913
Skrevet af: hopgreve
Skrevet den: 08-Februar-2014 kl. 16:58
Jeg ville gå efter 65VT , size does matter
PANASONIC 55CX725 | Pioneer VSX832 | TP TUBE 500/200/160 | PANASONIC BD220 | ATV4K
Skrevet den: 08-Februar-2014 kl. 17:28
Jeg skulle gerne benytte mig af Cinemagic tilbudet. Men jeg bor i Norge, så det er ikke rigtig muligt. Det vil overstige den norske pris at få det herop.
Jeg er helt sikkert mest tændt på 65VT60. Men det er næsten umuligt at opdrive et heroppe, uden jeg skal kører mange hundrede km efter det. Der er kun nogen stykker spredt ud over hele norge tilbage.
ZT60 er noget nemmere at få fat i. Derfor jeg begynder at overveje det, selvom jeg er lidt trist over at skal gå 5" ned.
Mvh Thomas
Skrevet af: vasif
Skrevet den: 08-Februar-2014 kl. 18:49
Man kan sige, at ZT60 er en mere eksklusiv skærm, som kun de færreste har. Det er der trods alt noget ganske fedt i synes jeg:)
Det lyder alt for besværligt at skulle køre flere hundrede kilometer efter en VT60. Det synes jeg slet ikke kan betale sig, når ZT60 indgår i overvejelserne, og begge skærme tilmed er til samme pris.
60" bør trods alt være tilstrækkeligt:)
Skrevet af: Mathias9000
Skrevet den: 08-Februar-2014 kl. 18:59
Af hvilken grund er et samsung PS64F8505 ikke inde i billedet? Det er ca. på niveau med et VT60, og du kan få det til de 25.000 inklusiv fragt... Godt nok koster det kun 20.000 i Danmark, men det kan du jo ikke bruge til noget. :)
Skrevet den: 08-Februar-2014 kl. 19:13
Samsungen må blive et af alternativerne,hvis ikke vt60 eller zt60 blir muligt at få.
Desuden synes fruen er det grimt. Hun bestemmer jo også lidt. Specielt når jeg er enig med hende.
Mvh Thomas
Skrevet den: 08-Februar-2014 kl. 19:17
Vasif>> du har helt ret. Men 5" er 5".
Da jeg købte mit første Panasonic i 2007-08, var jeg lun på den 37" for det var mere end nok.
Så blev jeg tilbudt en 42" til samme pris. Og jeg var så glad for jeg havde fået de ekstra 5 "
Jeg vil nødigt ende med at fortryde at jeg ikke tog de ekstra 5" denne gang.
Selvom du har ret i ZT er mere eksklusivt. Det var ikke aktuelt dengang i 07 for da vi 37" den "billige" uden fullhd. 42" med fullhd.
Mvh Thomas
Skrevet den: 08-Februar-2014 kl. 21:02
Fair nok. Wink
Har du/i set det i virkeligheden? Det børstede magnesium / magnesium-look synes jeg nu giver et mere eksklusivt udseende end det panasonic vt60 leverer, men vi har gudskelov ret til at have forskellige holdninger.  Smile
Skrevet den: 08-Februar-2014 kl. 22:32
Ja det designet i bunden af rammen jeg ikke kan li.
Fruen ville helst ha et hvidt TV. Men et sort højglans kan hun acceptere. Metallet på samsunget kan hun ikke li. Den er fin nok for mig.
Men fint alternativ hvis man kun ser på billedkvalitet :)
Mvh Thomas
Skrevet den: 09-Februar-2014 kl. 21:16
Hej Vasif. Hvis nu jeg snupper det 65vt60E hos cinemagic og får det fragtet herop. Hvad vil det sige hvis den ikke har den tuner? Jeg skal helt sikkert ha Canal digital parabol.
Mvh Thomas
Skrevet af: vasif
Skrevet den: 09-Februar-2014 kl. 22:15
Nu sakser jeg lige fra en hjemmeside:
DVB-T2 gør det muligt for den danske Gatekeeper Boxer TV A/S at udsende HD-materiale via det terristiske sendenet (DVB-T). For at kunne modtage disse HD kanaler forudsætter det at man har et TV med DVB-T2 og MPEG4 samt CA-indgangen skal være med CI+, derudover kræver det at man har et Boxer abonnement som indeholder HD kanaler.
Det skal derudover nævnes at DVB-T2 standarden idag bruges i bla. Sverige, England samt Finland. Så hvis man er bosiddende et sted hvor de pågældende landes kanaler kan modtages via antenne, kan man købe et TV med DVB-T2 modtager og modtage disse kanaler. (Bemærk dog at Sverige nu benytter både VHF og UHF antenne systemet)
Hvis du skal køre over Parabol, så er DVB-T2 ligegyldigt for dig, og de fleste kanaler er alligevel i DVB-T standarden, som Tv'et understøtter.
DVB-T er Tv via antenne.
Cinemagic.dk sender til Norge mener jeg.
Skrevet den: 09-Februar-2014 kl. 22:55
OK super. Så er det ligemeget om det hedder Y eller E!
Tak!
Mvh Thomas
Skrevet af: amorbavian
Skrevet den: 17-Februar-2014 kl. 12:35
Jeg håber, det er OK at hijacke tråden lidt i stedet for at lave en ny tråd - mit spørgsmål skulle gerne kunne besvares hurtigt.
Er der noget, jeg skal være opmærksom på (ud over hvis skidtet går i stykker) hvis jeg køber en VT60 i Sverige, hvor jeg bor nu, mhp. hvis jeg flytter til DK (som jeg har planer om at gøre inden for et år)?
Når/hvis jeg flytter regner jeg med at køre YouSee med et CA kort.
Her er tv'ets specs på den svenske Komplett:
http://www.komplett.se/panasonic-50-3d-plasma-tv-tx-p50vt60y/776232#!tab:extra - https://www.komplett.se/panasonic-50-3d-plasma-tv-tx-p50vt60y/776232#!tab:extra
Jeg tror ikke, jeg får et bedre TV til 12.000kr - selvom jeg er bekymret for retention og line bleed.
BORING!
Skrevet af: hjernemadsen
Skrevet den: 18-Februar-2014 kl. 16:17
Det er fuldstændig den samme model som sælges i DK (VT60Y). Service burde heller ikke være noget problem.
Skrevet den: 23-Februar-2014 kl. 09:47
Tak for svaret. Jeg tror sgu jeg hoppe på den, selvom det er et lidt stresset valg, da de jo er ved at forsvinde hurtigt - og jeg kan normalt IKKE lide stressede valg. Har dog slet ikke overblik over markedet - ud over, at jeg stadig ikke har set et bedre billede end på plasma. Hell, jeg synes min 4-5 år gamle Pana leverer bedre på billedsiden, end hvad jeg ser i butikkerne...
BORING!
Skrevet af: Hother
Skrevet den: 23-Februar-2014 kl. 10:11
Mja altså..... dit nuværende plasma, uanset hvilket fabrikat du har levere ikke bedre billede end dit evt. kommende VT60.
Det må være indstillinger og kendte omgivelser som spiller indSmile
Skrevet den: 23-Februar-2014 kl. 13:18
Jeg mente ud over de nyere plasma naturligvis...
Da jeg har været tilfreds med in PZ85 i alle de år, har jeg ikke rigtig fulgt med på markedet, så hvad er det bedste lige efter VT60 (altså ud over Panas anden topmodel), men som er i prisklassen ca. 15k?
BORING!
