Jeg har kopieret uden transkodning til Matrasko, AVC High@4.1 og kompressions lyd står lossles/lossy i kompression mode.
General
Unique ID : 266883693927541623687617126223954958261 (0xC8C7EE061626A1F56E786DA58225D7B5)
Complete name : D:\DATA\Videos\Film\Valerian.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 37.3 GiB
Duration : 2 h 16 min
Overall bit rate mode : Variable
Overall bit rate : 39.1 Mb/s
Movie name : Hovedfilm
Writing library : Lavf57.3.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Nominal bit rate : 38.0 Mb/s
Maximum bit rate : 38.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.764
Writing library : x264 core 152 r2851 ba24899
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=34 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=38000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=30000 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : Unknown / 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Delay relative to video : -42 ms
Title : English
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Title : Danish
Language : Danish
Default : No
Forced : No
Menu
00:00:00.000 : :chapter 1
00:17:29.840 : :chapter 2
00:34:10.256 : :chapter 3
00:51:13.570 : :chapter 4
01:07:55.613 : :chapter 5
01:26:05.076 : :chapter 6
01:40:16.635 : :chapter 7
01:58:40.655 : :chapter 8
02:16:38.231 : :chapter 9
Ærgerligt at jeg har kopieret lidt film hvor jeg har reencodet uden det var nødvendigt. Heldigvis ikke så mange.
Bedre sent end aldrig, som man siger.
