Kan en CDM CNT bruges? Den er ikke helt i den klasse du ønsker, men den er nu ganske god og ikke helt så dyr ;-)
CDM CNT Magnetically shielded centre channel loudspeaker system
Product Summary: The magnetically shielded CDM CNT centre channel loudspeaker completes the CDM NT range. Like the rest of the speakers in the CDM NT family, the centre channel harnesses all the latest technological advancements such as Nautilus™ tweeter, Kevlar® and contoured cabinet edges.
Technical highlights:
Nautilus™ Tweeter: B&W's Nautilus™ Tweeter technology ensures that the sound remains focused and time-sensitive and that the stereo-image is presented with unparalleled three dimensional accuracy.
Kevlar®: B&W developed and patented the method of using Kevlar® for loudspeaker cones to reduce unwanted standing waves. DuPont originally created Kevlar® for use in bulletproof vests.
Flowport™: Golf ball aerodynamics theory points the way towards lower distortion reflex ports. Dimples improve the way the air flows over the surface of any object. In the case of reflex ports, they offer a significant improvement over simply flaring the port ends in reducing air flow turbulence at each end of the port; so you get less chuffing noise and less compression at high sound levels.
Description: 2-way vented-box system with magnetic shielding
Drive units: 1 x 25mm alloy dome high-frequency 1 x 165mm woven Kevlar® cone bass/midrange
Frequency response: 50Hz – 20kHz ± 3dB on reference axis
Sensitivity: 91dB spl (2.83V, 1m)
Nominal impedance: 8Ω (min 4.6Ω)
Power handling: 50W - 120W into 8 ohm on unclipped programme
Dimensions: Height: 300mm Width: 460mm Depth: 290mm
Finishes: Cabinet: Black Ash Grilles: Black cloth
B&W Loudspeakers Ltd reserves the right to amend details of the specifications without notice in line with technical developments. E & OE. All trademarks acknowledged. http://www.bwspeakers.com™" rel="nofollow - www.bwspeakers.com™
Ganske flot og 100% fejlfrie enheder.
Kom med et frisk bud på en pris.
------------- mvh MichaelS Recordere.dk medlem siden 11-Marts-2004 kl. 22:33
