Viera link måske
Forumnavn: Streaming media
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=164208
Udskrevet den: 23-November-2024 kl. 03:19
Emne: Viera link måske
Skrevet af: peter12
Skrevet den: 28-November-2021 kl. 18:07
Har panasonic tx55fx740e. (måske 3-4 år gammelt)
Synes jeg læser, at det har mulighed for at caste ligesom med crome?
Kan der laves en kogebog til mig?
Eller er Crome Cast den mest optimale løsning.
Peter12
Med venlig hilsen
Peter
Skrevet den: 28-November-2021 kl. 18:15
 Funktionen er det samme som Screen Mirror, så hvad der vises på på Skærmen på Android enheden, er det der vises på TVet.
How do I use the Screen Mirroring app on my TV?
Connect both your TV and the Android (OS 4.2 or higher) device to the same wireless network.
Turn on the TV and press the [APPS] button on the TV remote.
Select the application labeled "Mirroring" using the navigational buttons and press [OK].
On the TV display you will see the message displays.
Press [OK] to select "Yes".
Enter the settings menu of the Android (OS 4.2 or higher) device and tap on the "Screen Mirroring" setting.
Tap on the VIERA model number that is displayed on the screen of the Android (OS 4.2 or higher) device.
Press the [OK] button on the TV remote to select "Yes".
After a short connection period (less than 10 seconds) of time, the screen of the Android (OS 4.2 or higher) device will appear on the screen.
Tap the "End Connection" button on the Android (OS 4.2 or higher) device to stop mirroring the device.
You can also press [RETURN] on your TV remote. When you use the [RETURN] Button on the TV remote  the following message will display. "Do you want to exit Mirroring?.
http://eng-au.faq.panasonic.com/app/answers/detail/a_id/52026/~/how-do-i-use-the-screen-mirroring-app-on-my-tv%3F" rel="nofollow - http://eng-au.faq.panasonic.com/app/answers/detail/a_id/52026/~/how-do-i-use-the-screen-mirroring-app-on-my-tv%3F
Skrevet af: Munch
Skrevet den: 28-November-2021 kl. 19:31
Og det virker kun på android og ikke iOS Dead
Skrevet den: 28-November-2021 kl. 20:17
 Siden det ikke er nævnt, så må det vel forholde sig som skrevet. Bruger Android TV bokse.
Skrevet af: Rasmus Larsen
Skrevet den: 29-November-2021 kl. 08:20
Skærmspejling (screen mirroring) er fin til at vise fotos, men dog ikke en god løsning til at få streaming fra mobilenhed op på TV'et.
Panasonic har desværre hverken Chromecast eller AirPlay indbygget, så en billig ekstern Chromecast-enhed er nok vejen frem. Skal der være flere muligheder og fuld brugerflade på TV'et så en boks som Xiaomi Mi Box, Nvidia Shield eller Apple TV 4K. TV'ets fjernbetjening kan styre boksene – og vice versa. Det sker via det system du henviser til, altså Viera Link, som er Panasonics navn for HDMI CEC-styring.
Skrevet af: jsh662
Skrevet den: 29-November-2021 kl. 23:14
Viera link er bare ikke godt nok.
Smid en cromecast i.
