lave samsung HD-850 regionsfri??
Forumnavn: DVD afspillere
Forumbeskrivelse: DVD afspillere (men ikke optagere)
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=20912
Udskrevet den: 14-November-2024 kl. 12:25
Emne: lave samsung HD-850 regionsfri??
Skrevet af: brwnx
Skrevet den: 20-Februar-2007 kl. 15:42
Er der nogen der har gjort Samsung HD-850 regionsfri??
mvh
Mikkel
Skrevet af: Timeguardian
Skrevet den: 23-Februar-2007 kl. 11:34
Hej brwnx.
Prøv dette link,burde løse dit problem.
http://thedvdforums.com/forums/showthread.php?t=161128&p age=14&pp=20
Hilsen Timeguardian.........
Skrevet af: Tarkin
Skrevet den: 23-Februar-2007 kl. 12:31
Jeg har selv en Samsung HD-850 og gjorde den nemt regionsfri:
1. Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. A number must appear on the screen (mine was 2). That is your player's current region.
4. Press the number for the region you want to use next (1 , 2 , etc). If you want your dvd player to be unlocked for all the regions press "9". A number should appear in the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. Congratulations: You now have a multi-region dvd player
Skrevet af: brwnx
Skrevet den: 28-Februar-2007 kl. 10:05
takker....
har ikek fået prøvet jeres forslag endnu, men vil skynde mig a kigge på det
