vclarke skrev:
beauville skrev:
Kunne jeg rigtig godt tænke mig stod i min stue
http://www.cyberport.de/item/1256/1020/0/97315/Onkyo_DV-HD805_HD_DVD-Player_schwarz.html?APID=6 - Hér er den
Eller - her VAR den:
http://forum.blu-ray.com/showthread.php?t=24977 - http://forum.blu-ray.com/showthread.php?t=24977
.... Og det er blevet afkræftet af Onkyo UK Det er garanteret kun i Italien og andre lande med et meget smalt HDM salg den er blevet 'discontinued' i.
Poster lige Joerod's mini review fra det amerikanske avsforum:
"Well, let me first start off by saying the entire front face is a very nice high gloss piano black. Very attractive. Now to what matters...
I will be 100% up front and honest here. I expected to open it and return it tomorrow! I really did. After spending a few hours though it has officially replaced my XA2 and A35 as the starter in my set up. It's true. It really has. I was stunned at how fast it loads. Its like Toshiba decided to wait and put the fastest load time on the HD805. Most HD DVDs that I put in loaded in about 10 to 12 seconds. Some even less! It is right up there with the Panasonic DMP BD30K. It may not equal it in load times but it is right there. That was a HUGE surprise.
Moving on to the HD DVD comparisons. Yes, it is the exact same menu as the XA2 and A35. Nothing different. It was a breeze to get going. I did forget about the button in the push open door on the front that requires you to select SD or HD output. So I compared them at 1080i/1080p60/1080p24... Now the interesting stuff. They should all have the exact same picture. Well, for some reason the HD805 has a sharper menu. I know that is no big deal but I found that odd. And all my displays were set the same exact way. It was not a huge difference but enough for me to take a second look. It was more noticeable with SD dvds which I will get to in a minute or two. Now playing the movies they all were pretty much the same. I did like the 1080i and 1080p pic Q slightly better on the HD805. For some reason there was less noise in the picture. My build date is October so it makes me wonder if they did a slight modification or two to the REON chip? I played the same exact scenes a few times just to make sure. It was ever so slight though so not enough to get crazy over. My 1080p/24 pic Q was great as well. Very sharp with hardly any noise. This unit was given some good parts because I tried like heck to get it to mess up. By mess up I mean show an error code or freeze or shut down. It wouldn't. It refused to disappoint me. I would have been very happy living with the XA2 or A35 but I am excited to put in the HD805 in my theater set up!
Now to SD dvds. Here is where it actually showed me something. SD dvds look clearer and are rendered with a little more detail. I think there is a XA3 in the works and I am willing to bet it will get the same modifications as the HD805. They obviously did something different with this unit. It is faster at responding, faster at loading and I am seeing a sharper image. Not to mention with all settings at minimum, less noise. And again not enough to throw your XA2 or A35 away but it does clearly show that a new player with these modifications will make a difference in the near future. I think if anything this is a positive for HD DVD. I truly expected the same exact performance of the XA2. I did get the same exact menu interface, cheaper remote and same back as the XA2. But from there I got much faster load times, faster responding, sharper images, less noise, and in my opinion the best looking HD DVD player to date. And of course this units biggest enemy is its pricing. If it were the same price as the XA2 I would choose it hands down over it. Heck, I would even pay a little more (which I just did)...
So I will keep my collector's special limited edition HD805... Who knows, maybe they are on to something... Something better! "
Det lyder godt
