Problem. at installere Slimserver på Qnap
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=33815
Udskrevet den: 08-Juni-2024 kl. 17:33
Emne: Problem. at installere Slimserver på Qnap
Skrevet af: caschmidt
Skrevet den: 12-Januar-2008 kl. 16:16
Jeg har investeret i en Qnap TS-109Pro. Desværre uden præinstalleret SlimServer - så det må jeg jo selv gøre :-(
Jeg har fundet en installationsvejledning på http://progressiveav.com/ts109install/ - http://progressiveav.com/ts109install/ og fulgt vejledningen, herunder installation via Putty, som gennem installationen skriver følgende:
[/share/HDA_DATA/Public] # ./install-ts10x-20x.sh debian-4.0-arm-2007-07-15 Installing to: /share/HDA_DATA/Public/etch creating directories ... installing linux image ... gzip: Invalid magic tar: Child returned status 1 tar: Error exit delayed from previous errors Looking for host pool.ntp.org and service ntp hos found : 0x503e52a6.arcnxx10.adsl-dhcp.tele.dk 12 Jan 14:40:52 ntpdate[2233]: adjust time server 80.62.82.166 offset 0.042854 sec TS-109 detected - mounting mtdblock5 modifying startup scripts ... Executing startup script (starting slimserver) Please wait ... mount: mount point /share/HDA_DATA/etch/dev does not exist mount: mount point /share/HDA_DATA/etch/proc does not exist mount: mount point /share/HDA_DATA/etch/bus/usb does not exist mount: mount point /share/HDA_DATA/etch/ext/updates does not exist mount: mount point /share/HDA_DATA/etch/ext/Qmultimedia does not exist mount: special device /share/HDA_DATA/etch/opt/slimserver/Plugins does not exist ls: //share/HDA_DATA/etch/ext/extchroot-bin/ : No such file or directory chroot: cannot execute ls: No such file or directory Installed. Please be patient while slimserver starts up for the first time and scans your collection Your music should be copied into the "Qmultimedia" share [/share/HDA_DATA/Public] #
Herefter sker der ingenting ;-)
Det eneste jeg har fået ud at ovenstående "installation" er, at min NAS-server nu ikke længere hedder "QNAP" med "SlimServer-109" i administrationsprogrammet til serveren.
Hvordan starter jeg min SlimServer? ... hvis jeg da i det hele taget har fået den installeret!? ... og hvis ikke - hvordan installerer jeg den så?
------------- Desperate hilsner
Skrevet af: krimmo
Skrevet den: 12-Januar-2008 kl. 17:30
Yrk!
Det lyder bestemt ikke rigtigt!
Jeg mener at have læst et sted at der kan opstå problemer med filnavn/extension hvis man downloader pakken med Internet Explorer, frem for f.eks. Firefox.
Måske er det det der er sket?
Har selv en QNAP 109 m. Slimserver installeret. Og jeg fulgte også vejledningen fra Proressiveav.
Men hos mig gik det helt uden problemer...
Måden at se om Slimserver kører er via f.eks. 'ps' kommandoen i putty.
Herover ser du en perl process der kører slimserver
769 1000 56136 S /usr/bin/perl -w /opt/slimserver/slimserver.pl
og 10 mysql processer som også bruges af Slimserver
850 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 851 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 852 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 853 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 854 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 855 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 857 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 858 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 859 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 860 1000 19840 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve
Hvis de er der kører Sllimserver...
EDIT: Nærlæste lige din besked igen, og hvis den er korrekt copy/pasted, så mangler din fil en extension, som jeg skrev om.
Det korrekte filnavn skal være:
[/share/HDA_DATA/Public] # ./install-ts10x-20x.sh debian-4.0-arm-2007-07-15.gz
Altså med .gz til slut. Det er temmelig sikkert derfor der optræder de beskrevne fejl... install programmet kan slet ikke finde debian... pakken.
Hilsen
K
TH42PV60 (med slanger af og til)
Samsung 3126
PS3
Yamaha RX-V1700
Squeezebox Duet(s) + Classic + Boom + Touch
QNAP-109
SqueezeCenter 7.5.1
Skrevet den: 12-Januar-2008 kl. 17:53
Jeg prøver straks at køre kommandoen ps -aux i Putty. Resultatet var straks en masse kommandoliner - lidt i stil med ovenstående.
Men der mangler noget: - Samtlige linier starter med admin - Der er ingen usr/bin/perl - Der er ingen SlimServer
Har jeg slet ikke installeret den? Hvordan gør jeg så? Er det en forkert fil, jeg har downloaded? Hvor finder jeg så den rigtige fil?
Hilsen caschmidt
Skrevet af: krimmo
Skrevet den: 12-Januar-2008 kl. 18:08
"Ro på!"
Du har fat i den helt rigtige software...
Jeg ved ikke om du har læst min "EDIT" i mit forrige indlæg? Ellers så se lige på det igen.
Jeg skal lige forberede lidt skærm-billeder for at hjælpe dig, så vender jeg tilbage...
Problemet er temmelig sikkert din download, som mangler .gz endelsen. Du kan muligvis ikke se fil-endelser i Windows, da de som udgangspunkt er skjult.
Er tilbage om lidt!
K
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet af: krimmo
Skrevet den: 12-Januar-2008 kl. 18:29
Skrevet den: 12-Januar-2008 kl. 23:06
1.000 tak Krimmo
Kender du det, når man er lidt i vejen for sig selv? Nej, sikker ikke - men er så min historie:
Den downloadede fil (som ligger i en anden folder) "debian-4.0-arm-2007-07-15.gz" er jo en pakket fil. Det kan man se på WinZip-ikonet. Derfor pakkede jeg den ud (den indeholder kun en fil, som hedder det samme blot uden extension).
Det var tilsyneladende problemet. Løsningen bestod derfor blot i, at kopiere den originale downloadede fil til /Public og så ellers køre kommandoen med minutiøs "stavekontrol" i Putty.
Det var vist bare det.
... troede jeg. For nu har Putty været i gang med at starte SlimServer og indeksere mine ca. 100 MB musik alt imens jeg har set "Pearl Harbor" på DVD.
Det er sgu' en lang film - men Putty er ikke færdig endnu
De sidste linier, som Putty skriver er:
Installed. Please be patient while slimserver starts up for the first time and scans your collection. [/share/HDA_DATA/Public] # 2008-01-12 19:42:56.8118 Warning: Migrating from 6.3.x used with MySQL! 2008-01-12 19:44:01.3733 Couldn't resolve IP adress for: localhost 2008-01-12 19:44:42.4937 About to look for files in /ext/Qmultimedia 2008-01-12 19:44:42.5852 For files with extensions in: [(?e-xsm:\.(?:ape|wma|shn|wav|wave|mp3|mp2|flc|flac - og en masse mere - )$)] 2008-01-12 19:48:43.9513 Found 469 files in /ext/Qmultimedia 2008-01-12 19:48:46.2281 About to look for files in /ext/Qmultimedia 2008-01-12 19:48:46.2998 For files with extensions in: [(?e-xsm:\.(?:asf|wax|asx|lnk|wpl|m3u|pls|xpf|cue)$)]
Ja, som man kan se, så er der til syneladende ikke sket noget i de sidste tre timer ... men jeg synes også at kunne se, at på trods af at Putty har besvær med at finde en IP-adresse på "localhost", så er der alligevel indekseret 469 musikfiler.
Hvad mon der så er galt? Skal den have lov at stå og tænke over det hele natten? ... eller må kan slukke sin PC og gå til køjs?
Flere gode forslag ønskes. Hilsen caschmidt
Skrevet af: Breddam
Skrevet den: 12-Januar-2008 kl. 23:26
Don't pay ANY attention
Edit igen: Sorry, jeg havde bare skrevet noget vrøvl, eftersom jeg ikke havde set dit sidste indlæg...
------------- http://widepond.dk - Widepond
Skrevet den: 13-Januar-2008 kl. 10:59
G'morn Så er jeg her igen!
Til Breddam: Hvad i alverden mener du med det?
Til Krimmo: Ja, jeg slukkede altså PC'en og gik i send! I morges startede jeg så op igen, og kørte kommandoen "ps -aux" i Putty, som du beskrev i dit første svar.
Her ser jeg at jeg både har:
Kode:
769 1000 56136 S /usr/bin/perl -w /opt/slimserver/slimserver.pl | | |
og 11 mysql processer:
Kode:
855 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 856 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 858 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 859 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 860 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 861 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 862 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 863 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 864 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 865 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve 869 1000 15204 S /opt/mysql/bin/mysqld --defaults-file=/home/slimserve | | |
Kan jeg så konkludere at SlimServer kører?
Og hvordan får man får man den så "frem i lyset" så man kan arbejde dem den? Jeg har læst noget om et systembakke-ikon (tray icon) - hvordan kommer det ind i billedet?
Stadig forvirret... caschmidt
Skrevet den: 13-Januar-2008 kl. 11:06
Hej igen - igen
Det må I undskylde - men nu har jeg vist selv set lyset
Det eneste jeg manglede var jo blot at skrive ...:9001 i browseren for at påkalde mig port 9001 - hvor jeg har jo har læst, at SlimServeren findes.
Nu skal jeg blot have opdateret SS til version 6.5.4
Tak for hjælpen
caschmidt
Skrevet af: krimmo
Skrevet den: 13-Januar-2008 kl. 11:20
EDIT: Nå Du nåede det før mig!!
Godt at høre at det ser bedre ud her til morgen...!
caschmidt skrev:
... troede jeg.
Flere gode forslag ønskes. Hilsen caschmidt |
G'Morn (eller er det? )
Skanning af 100MB (500 filer) burde tage et par minutter..! Som din log også siger det har gjort.
Hvorfor den ikke "slutter" ved jeg ikke... jeg tror faktisk at den er færdig, og var det kl. ca. 19:48:..
Jeg husker ikke præcis hvordan det så ud da jeg installerede min egen. Men jeg tror faktisk ikke jeg endnu havde kopieret nogen musikfiler ind før jeg havde Slimserver oppe og køre.
Har du prøvet at åbne web-sitet til Slimserver på: http://<NAS IP adresse>:9001/
Der vil du kunne se om, og hvor meget der er skannet ind.
Med hensyn til "localhost" fejlen må jeg blive dig et svar skylding.
Du kan i putty prøve kommanden: ping localhost
Så skal du få svar i stil med (tryk Ctrl-C når du har fået et par linier):
[~] # ping localhost PING localhost (127.0.0.1): 56 data bytes 64 bytes from 127.0.0.1: icmp_seq=0 ttl=64 time=0.2 ms 64 bytes from 127.0.0.1: icmp_seq=1 ttl=64 time=0.2 ms 64 bytes from 127.0.0.1: icmp_seq=2 ttl=64 time=0.2 ms 64 bytes from 127.0.0.1: icmp_seq=3 ttl=64 time=0.2 ms
--- localhost ping statistics --- 4 packets transmitted, 4 packets received, 0% packet loss round-trip min/avg/max = 0.2/0.2/0.2 ms
Til slut - har du sat en fast IP-adresse på din NAS? Det er altid "god karma" at "servere" har fast IP så klienterne (Squeezebox, Windows PCere, m.m.) altid ved hvor de kan finde dem.
Hos mig ser det således ud: (Lad være med at kopiere det råt!! IP adressen skal passe til addresserne i dit netværk, og de er ikke nødvendigvis lige som mine...!)
Hilsen
K
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet den: 13-Januar-2008 kl. 11:57
Hej Krimmo
Godt at se, at du også er med igen
Jo, nu kører det vist fint. Men jeg ville jo gerne have opdateret fra nuværende version 6.5.3 til nyeste version: 6.5.4
Jeg har på http://www.slimdevices.com/su_downloads.html - www.slimdevices.com/su_downloads.html hentet filen, der referer til Windows (for jeg kører jo WinXP) Denne fil en en *.exe
Er det bare den, jeg skal kopiere ind i mappen \Public\updates ?
Eller skal jeg hente pearl-filen? Eller ...
Jeg er stadig forvirret - en smule ... men nu ser jeg da lys for enden at tunnellen
caschmidt
Skrevet af: krimmo
Skrevet den: 13-Januar-2008 kl. 12:17
UHA NEJ!!
Du skal pinedød ikke bruge de downloads som ligger på Slimdevices website! De passer IKKE til din QNAP!
Du skal bruge den pakke som ProgressiveAV har lavet, og som jeg refererer til i min posting fra kl 18:29 i går:
Fra Slimdevices forum sider:
Kode:
Ok it is late and I am tired so no update on the crap HTML pages I haven't got time to make look pretty!!
TS-x09 - SlimServer 6.5.4 update here - http://www.progressiveav.com/ts109install/01-SlimServer-v6.5.4-arm-etch-2007-08-29-module-update.tgz - http://www.progressiveav.com/ts109in...ule-update.tgz
Download into the updates folder in the Public share and reboot.
TS-101 users - I have the new install package working on mine now
without any problems. I also have the 6.5.4 update file as well. Don't
have the time now to upload and explain how to install so I'm sorry but
you'll have to wait till Sunday when I get back.
P.S. For some reason when you download this file with IE7 it doesn't
download the correct extension (probably trying to be clever) it
downloads it as .gz rather than .tgz so it is up to you if you go to
the command prompt and rename the file or download it with a proper web
browser like Opera or Firefox.
& ;nbs p;
& ;nbs p;
& ;nbs p;
& ;nbs p;
& ;nbs p;
& ;nbs p;
& ;nbs p; &nbs p;__________________
& ;nbs p; &nbs p;Paul
Progressive Consumer Electronics Ltd
Læs P.S., og pas på med de manglende file-endelser!!!
Det betyder også at du/vi er afhængige af at ProgressiveAV (eller andre) "pakker" Slimserver så den kan installeres på QNAP når f.eks. version 7 bliver frigivet inden længe!
Hvis du vil læse hele 6.5.4 tråden så findes den her: http://forums.slimdevices.com/showthread.php?t=38005 - http://forums.slimdevices.com/showthread.php?t=38005
Held og lykke med det!
Og pas på fil-endelserne. Og ikke noget med at pakke filen ud inden du kopierer den ind i updates folderen.
K
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet den: 13-Januar-2008 kl. 13:41
10.000 tak Krimmo
Nu forstod jeg det endelig!
Den fil fra progresivav havde jeg jo også hentet - i går formiddags. Men jeg havde selvfølgelig i forvirringen glemt hvad jeg skulle med den.
Nu spiller min SlimServer
... på WinAmp spiller den ganske vist lidt for hurtigt (!?) og jeg har sikkert 1.000 andre dumme spørgsmål i forbindelse med brugen af både den og Squeezeboxen ... men det hører vist til i en ny tråd.
Vi må hellere lukke denne tråd. Endnu engang tak for din tålmodighed.
caschmidt
Skrevet af: krimmo
Skrevet den: 13-Januar-2008 kl. 14:01
For hurtigt!
Det har jeg godt nok alligevel aldrig hørt om.
Men nu er WinAmp jo ikke den naturlige klient til Slimserver, så måske har det noget med det at gøre.
Prøv i stedet SoftSqueeze, som du finder på højre side af Slimserver web-siden. (Kræver installation af Java runtime, hvis du ikke har det i forvejen.)
http://<NAS IP Adresse>:9001/html/softsqueeze/index.html
Den skulle gerne kunne spille din musik korrekt fra PC!
caschmidt
Jo jo - men vi skal jo lige være sikre på at alle er glade - ikk'?
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet den: 13-Januar-2008 kl. 14:34
Jo, da - hvis du insisterer
Jeg fulgte dit link til softsqueeze og startede denne i et JAVA Applet vindue. Det ser jo fint ud!
Jeg vælger en sang med "fjernbetjeningen" og klikker på [play] ... men den spiller ik' !
I displayet står der "afspiller" et kort øjeblik - så står der atter "stop" ... ingen musik!
Ka' du også knække den?
Skrevet af: krimmo
Skrevet den: 13-Januar-2008 kl. 15:16
Bummer!
Det skal ikke være let - hva'? Nu jeg lige selv prøvet som både 'Applet' og 'Java web start'. Og jeg har altså ingen problemer med at afspille på min PC.
Hvad med en Squeezebox - har du ikke sådan en?
Hvilket format er dine filer i?
K
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet den: 13-Januar-2008 kl. 16:11
Squeezeboxen er desværre i restordre, og jeg må derfor klare mig med "alt det sjov" jeg kan få ud af Qnap og SlimServer. ... men går da også helt fint med det
Jeg tror nu nok, jeg har fundet forklaringen på mit sidste spørgsmål:
1. WinAmp er tydeligvis ikke den rigtige afspiller fra SlimServeren. Jeg fik nemlig liv i Softsqueeze, og det lyder jo meget bedre. 2. Jeg skal nok have kigget mine musikfiler efter i sømmene, for kan Softsqueeze åbenbart ikke afspille wma-filer!
Ka' det passe? I hvert fald får jeg den nævnte fejl, hver gang jeg vil afspille så'rn en
PS: Jeg har bl.a. et album med 10cc i wma-format. Hvordan finder man det med Squeezeboxen? Kan synes ikke at kunne foretage søgninger med tal i titlen!
caschmidt
Skrevet af: krimmo
Skrevet den: 13-Januar-2008 kl. 16:33
Squeezebox/Slimserver kan håndtere wma. Men ikke hvis det er DRM beskyttet (Digital Rights Management).
Så vidt jeg ved...
Hvis man vil kunne spille DRM beskyttet wma materiale skal man "fifle" lidt med filerne først. Men her må jeg krybe til korset, da jeg ikke ved hvordan.
Men på Slimdevices forum sider er der masse af hjælp at hente.
Dit problem med at finde dit 10cc album har ikke noget med navnet at gøre. Har selv Foreigner med albummer "4" og et "4 Non Blondes" album som jeg ikke har problemer med at finde...
Jeg tror mere på at det er din wma-fil som er problemet.
Det er muligt, via putty, at lave en skanning med debug output så man kan se om der er problemer med en fil.
Se evt her i bunden af siden: https://www.ripcaster.co.uk/node/112
Det der skal til er følgende kommandoer:
chroot /share/HDA_DATA/etch /bin/bash
cd /opt/slimserver
./scanner.pl --wipe --progress --d_sql --d_scan --d_parse /ext/Qmultimedia
Argumenter til "scanner.pl" kan du selv undersøge ved at køre "scanner.pl" uden argumenter. Så får du en liste over hvad man kan...
Men her er du ude i det lidt mere lang-hårede...
Så "tænk-før-du-trykker" er på sin plads. Jeg er dog ret sikker på at du ikke kan ødelægge noget. Og ultimativt er det muligt at starte forfra med QNAP og Slimserver install...
Du er jo ved at være i træning - ikk'?
Hilsen Kim
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet den: 13-Januar-2008 kl. 16:47
Jeg synes, jeg banker hovedet imod noget hele tiden. Er efterhånden ved at være bange for ...
Nå, nu ikke flæbe ...
De wma-filer, som Softsqueeze ikke vil spille er ikke kopi- eller licensbeskyttede på nogen måde. Det er blot filer, som er rippet fra CD via Windows Mediaplayer. Men sku' vel for pokker ikke være et problem, eller hva'?
Iøvrigt sidder jeg p.t. og bander over et andet problem: På serveren vil jeg gerne oprette en mappe til \Musik\ og en til \Playlists\ Det er tidligere (i går) lykkes mig at oprette mapper på Qnap'en via Windows File Explorer ("Denne computer"). Men i dag får jeg pludselig fejlmeldingen: "Adgang nægtet" Derved kan jeg jo heller ikke kopiere filer ind.
Men, som sagt, det virkede sgu' i går! Qnap'en bliver pludselig heller ikke længere vist under "arbejdsgruppecomputere" - som den gjorde i går.
Måske har jeg fjumret lidt for meget rundt i setup i dag. Jeg prøver at genstarte PC'en - det kan da være ...
caschmidt
Skrevet af: krimmo
Skrevet den: 13-Januar-2008 kl. 16:56
Med hensyn til wma, så prøv en skanning via kommandlinien.
Drevet får du nemmes fat i ved at gå ind via QNAP Finder via [Tools][Map network drive] menuen, og log så på med admin/<adm pwd>
Så har du helt sikkert skriveadgang!
Når så blodtrykket er kommet lidt ned igen , så check hvilken Windows Workgroup din PC og QNAP'en er medlem af.
Sørg for at de er ens.
Endelig kan du lave en bruger på QNAPen med samme navn og password som du har på din PC (Hvis du overhovedet bruger auth.). Og give denne bruger skriverettigheder til Qmultimedia så vil du ikke længere skulle bekymre dig om sikkerhed.
Du kan selvfølgelig også bare give rettigheder til "anonymous", eller hvad det nu end hedder.
K
Samsung 3126
PS3
Yamaha RX-V1700
QNAP-109
SqueezeCenter 7.5.1
Skrevet af: KissmeTiger
Skrevet den: 13-Januar-2008 kl. 17:06
Så vidt jeg ved...
En lovlig måde at slippe af med DRM-beskyttelse er vist nok Tunebite.
------------- Panta rei
Skrevet den: 13-Januar-2008 kl. 19:15
chroot /share/HDA_DATA/etch /bin/bash cd /opt/slimserver ./scanner.pl --wipe --progress --d_sql --d_scan --d_parse /ext/Qmultimedia
Så kørte jeg lige en tur med Putty. Jeg skal da love for at den angivne kommando gav gevinst. Det tog vel 3 min. inden Putty var færdig med at skrive i konsollen, hvis buffer for længst er overskredet.
Det kommer vel ikke bag på nogen, men jeg fatter ikke meget at det. Der er ikke rigtigt noget, der tyder på definitioner af filtyper el.lign.
Måske man skulle ønske sig en kommando, der kan præcisere for SlimServer hvilke filtyper den skal kunne modtage?
I øvrigt havde jeg opfattelsen at, at SlimServeren skulle kunne læse de m3u playlists, som jeg har liggende fra WinAmp? Men når jeg beder SlimServer om at vise Gemte playlister, så er listen tom!
Måske man bare skulle tage og "re-rippe" al sin musik og så lave playlists i SlimServer. Det kan jo godt tage et par dage - men fornøjelsen med/af Squeezeboxen skulle jo også gerne vare længe
PS: Svar til KissmeTiger: En lovlig måde at slippe af med DRM-beskyttelse er også at brænde musikken til CD, som man så ripper. Ja, der er ik' så langt at gå over åen efter vand endda
--- caschmidt
Skrevet den: 13-Januar-2008 kl. 19:18
PS til Krimmo
Det forstod jeg ikke.
Det ser ud til at siden ripcaster.co indeholder værdifulde informationer, men hjælp til scanning med debug output synes jeg ikke at kunne finde.
--- caschmidt
Skrevet den: 13-Januar-2008 kl. 22:00
Yes det er en anden mulighed
Bruger bare selv Tunebite, det er mindre besværligt. Udmærket program.
