Hvordan gør jeg det ( film )
Forumnavn: Spillekonsoller
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=35557
Udskrevet den: 21-Februar-2025 kl. 20:05
Emne: Hvordan gør jeg det ( film )
Skrevet af: René P
Skrevet den: 09-Februar-2008 kl. 15:05
Hey!
Jeg så i en tråd et link til et divx program, som en eller anden her inde bruger på hans ps3,
mit spørgsmål er , hvordan installere jeg det på min ps3?.
Skrevet af: René P
Skrevet den: 09-Februar-2008 kl. 15:20
ved i hvad, det er ligemeget,
har fundet det her i en anden tråd
http://www.download.com/PS3-Video-9/3000-2194_4-10779503.html?part=dl-PS3Video9&subj=uo&tag=button&cdlpid=10779503 - http://www.download.com/PS3-Video-9/3000-2194_4-10779503.htm l?part=dl-PS3Video9&subj=uo&tag=button&cdlpid=10 779503
Skrevet af: nekolas
Skrevet den: 11-Februar-2008 kl. 08:52
editors review fra download.com:
Citér
This video converter is made by Red Kawa, the same folks who now make the popular Videora iPod video converter. Although both programs are plagued by rampant advertising, the situation is much, much worse in this one. The ads take up much more screen space than they do in the iPod video converter, and the ones for the PS3 include shrill voices excitedly informing the user that you have won not one but two, yes two, iPod Nanos. And judging from the included images, they're old Nano models at that.
Although freeware with ads can be annoying, the manner of inclusion here goes beyond irritating and interferes with interface navigation. Video conversion rates were fine, but the cluttered and unintuitive UI significantly hampers the user's ability to determine what comes next: Pop-up boxes indicating subsequent steps are not easily distinguished from the ads that surround them.
We have noted some user complaints about the conversion success rate, so although we did not encounter any problems, we recommend using this converter as a near-last resort.
taget fra http://www.download.com/PS3-Video-9/3000-2194_4-10779503.html - http://www.download.com/PS3-Video-9/3000-2194_4-10779503.htm l
Skrevet af: Thyboen
Skrevet den: 15-Februar-2008 kl. 16:21
Giv lyd fra dig, hvis ikke du kan få det til at køre med de profiler, der følger med programmet. Det kunne JEG ikke, så jeg lavede 3 styks i 3 forskellige kvaliteter. Dem kan du få, hvis du har problemer.
Kent.
