Scart omskifter med RGB
Forumnavn: Tilbehør
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=415
Udskrevet den: 12-December-2024 kl. 13:59
Emne: Scart omskifter med RGB
Skrevet af: Dan Wulf
Skrevet den: 22-Januar-2004 kl. 16:22
Oprindeligt skrevet af Lars Lars skrev:
Jeg er stadig på jagt efter en scart-omskifter der understøtter RGB, en som skifter elektrisk og som kan fjernbetjenes. Men foreløbig uden held Smile
Lars, fint initiativ med dette forum. Vi har gennem et år brugt en Trilogy 1 som kan ses her:  http://www.threedoubleyou.com/quattroscart.htm - http://www.threedoubleyou.com/quattroscart.htm
Er det evt. noget i den stil som du leder efter?
Skrevet af: Lars
Skrevet den: 22-Januar-2004 kl. 16:28
Hej Dan
JA - der var den! Jeg håbede noget sådan fandtes, men jeg havde ikke set nogen på markedet.
REMOTE CONTROLLED FIVE WAY SCART CONTROL CENTRE
A SUPREME MACHINE
Home Entertainment Total Control Centre
The Trilogy 1 central console has simple plug-and-play operation allowing connection of up to ten pieces of AV equipment without complicated cabling.  Smart Automatic Switching always switches to the last video input turned on and looks for the last active video input when the current video input is turned off.  The supplied remote control allows you to manually select which input to view on your TV and which input to record on your VCR.  The front panel LED indicators display current video inputs and outputs at a glance.  Extra features allow you to record two different videos at the same time and a special lock function ensures against accidental interruption.  The Trilogy 1 has four scart RGB inputs and will cope with up to five composite or S-Video signals.
Trilogy 1 Features:
Loop-through, switching and distribution.
Microprocessor controlled two independent video inputs to TV and VCR outputs.
Auto switching with Euro-scart and RCA inputs.
Auto detection and switching to the second video when the first video switched off.
Auto detection and switching to TV when all video inputs are switched off.
Switching protection on the second video with LOCK function.
Video and Audio direct from SAT and VCR scarts to LD scart from decoder.
RGB and S-Video switching from SAT, LD, DVD and VCR scarts to TV scarts.
First and second videos selectable on TV2.
Can also be used to get five outputs from one input.
Watch your DVD on the Television whilst simultaneously recording something on the VCR
The easy way to connect ALL your AV equipment to your TV - Compatible with DVD, VCR, Camcorder, Satellite, Games Console, etc. - Copes with Composite,S-VHS and RGB Signals!
  /Lars
Ansvarshavende redaktør.
Webmaster, recordere.dk
Skrevet af: Lars
Skrevet den: 22-Januar-2004 kl. 21:08
Hej Dan
Nu har jeg bestilt en, så håber jeg den er god! Smile
  /Lars
Skrevet af: hedi
Skrevet den: 22-Januar-2004 kl. 21:09
Hej Dan
Hvordan er den så er du tilfreds og har du selv købt den via den hjemmeside i england. ? Er der noget man skal være opmærksom på ved bestilling fra dem.
Skrevet den: 23-Januar-2004 kl. 09:11
Lars & heidi,
Jeg har købt gennem ovennævnte firma, men Trilogy 1 og lign. produkter forhandles flere steder i UK (se fx http://www.lektropacks.co.uk/dept.asp?Hash=617&dept_id=112 - http://www.lektropacks.co.uk/dept.asp?Hash=617&dept_id=112  ). Jeg havde ingen problemer med selve bestillingen og køb. Betalte med visa og der var relativ hurtig levering. Når man handler on-line er det en god ide' altid først sende firmaet en mail med spørgsmål vedr. pris incl. shipping til DK og betalingsmåde, hvis sidstnævnte ikke tydeligt fremgår af website.
Vores Triology 1 var løsningen på 5 kilder (sat1, sat2, DVD, VCR & PS2) og et 6-7 meter kabeltræk fra rack til TV. Nu kan vi nøjes med et kabel fra rack (Trilogy 1) til TV og behøver ikke sidde og "browse" med inputknappen på TVets remote for at finde den korrekte kilde. Dejligt!
Det eneste problem jeg har haft med Triology 1 er udfald under VHS-optagelser eller manglende optagelse efter timer-indstilling, men det skyldes formodentlig en løs forbindelse i et scart-kabel.
Upload evt. fjernbetjeningens koder til en programmerbar remote og så kører den ellers.....
Nu skal jeg ikke spille for klog , men taget i betragtning af, at der rent faktisk er mange danskere som har et akut behov for et sådan produkt er det lidt underligt, at der ikke er flere som er bekendt med mulighederne for at købe dem i UK. Her er google.com en fin søgemaskine - søg fx. på scart switch remote automatic RGB - og så er der ellers hul igennem til Trilogy-serien og andet.... Internettet? Søg og du skal finde!
kh
dansan
Skrevet af: hedi
Skrevet den: 23-Januar-2004 kl. 20:01
Til Dan tak for dit svar til Lars giver du ikke en lille anmeldelse når du har fået din Trilogy 1.
Henrik
Skrevet af: Lars
Skrevet den: 23-Januar-2004 kl. 21:04
Hej Henrik
Jo, selvfølgelig. Smile
De har den dog ikke på lager, men har skrevet at de får nogle hjem igen i næste uge.
  /Lars
Skrevet af: Rebbe
Skrevet den: 24-Januar-2004 kl. 13:02
Et andet og billigere alternativ jeg selv har overvejet, er denne sorte box.  http://play.com/play247.asp?page=title&r=GADG&title=142733 - http://play.com/play247.asp?page=title&r=GADG&title=142733
Er blevet rost af flere i.f.m. med plasmaskærme på WhatVideo.
/rebbe
Skrevet af: Anonym
Skrevet den: 24-Januar-2004 kl. 19:02
Hej Alle
Det vælter jo frem med gode forslag Smile
Jeg kan dog godt lide at den er fjernbetjent, men omvendt hvis auto-switch funktionen virker fornuftigt er det ikke sikkert jeg vil bruge det så meget.
  /Lars
Skrevet af: Lars
Skrevet den: 05-Februar-2004 kl. 11:58
Hej Alle
Jeg har forresten fået den Triology 5-1 scart-omskifter med RGB og fjernbetjening nu (se længere oppe i denne tråd) men jeg har ikke haft tid til at prøve den Smile
Selve boksen ser dog ganske fin ud, finish mv. er iorden.
Slutprisen endte på 1200 kr. alt incl.
  /Lars
Skrevet af: MichaelS
Skrevet den: 12-Juni-2004 kl. 20:20
Aldi har i næste uge (16.6.04-19.06.04) et tilbud på en SCSRT omskifter box:
Ligner et godt tilbud - køber den om muligt!
Hilsen
Michael Sørensen
mvh MichaelS
Skrevet af: Thorvald
Skrevet den: 12-Juni-2004 kl. 20:32
Hvis man tilslutter to eller for den sags skyld tre HDD-DVD optagere til denne boks fra Aldi - er det så muligt at optage på alle to (tre) optagere på samme tid? Se evt. også: Opsætning med flere digitale videoer?
Med de venligste hilsener
Thorvald.
Skrevet den: 12-Juni-2004 kl. 21:05
Hej Thorvald
Det kommer an på hvordan du kobler dem.
Se svar i din tråd om emnet
Hilsen
Michael Sørensen
mvh MichaelS
Skrevet den: 16-Juni-2004 kl. 09:57
Aldi omskifteren er beskrevet her:
http://www.recordere.dk/forum/forum_posts.asp?TID=1146&PN=1&TPN=1 - http://www.recordere.dk/forum/forum_posts.asp?TID=1146&P N=1&TPN=1
Hilsen
Michael Sørensen
mvh MichaelS
