Nogen der kender dette læred
Forumnavn: Projektorer
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=49420
Udskrevet den: 03-Maj-2025 kl. 02:55
Emne: Nogen der kender dette læred
Skrevet af: henrik-t
Skrevet den: 29-Oktober-2008 kl. 22:33
hejsa har lige fået en projector og ville gerne lige spørge derude omkring læredet...!!
Nogen der kender dette lærdet...
Sapphire Parklane Series Manual Projection Screen - 2029mm by 1143mm 16by9 Format
A stylish white aluminium case, with channel fix brackets for easy install and the sapphire unique lock and fabric semi-auto retraction system
    Design
  • Adjustable channel fixing L-brackets make ceiling or wall installation extremely easy.
  • Simple clip on installation is even adjustable left to right.
  • The aluminium outer case is stylish and durable.
  • Installation is suitable for any flat surfaces, the screens are suitable for entertainment venues, home entertainment use etc...
    Screen Fabric
  • The fabric is a matt white 1:1 gain with a lovely flat surface
  • Multi-layered construction with fiberglass backing helps screen remains taut and prevents any V-waves from forming.
  • The projection surface utilizes unique materials creating a smooth surface for superior image quality. The flexible projection surface is suitable for all occasions and ensures a color-rich reflection and sharp pictures.
  • Sapphire screens have flexing rates of less than 1% compared to 33% for chemically treated fabrics.
  • Slow and even semi-auto retraction, simply pull the screen material down to the required stop position, hold the handle for 3 seconds and the screen will hold in any position required, to retract, pull the handle downwards and let then release the handle, the fabric will now auto retract into the case housing, this system is unique to sapphire projection screens.
Link :
http://www.projectorscreen.co.uk/pp/Projector_Screens/Projector_Screens/Sapphire_Parklane_Series_Manual_Projection_Screen_-_2029mm_by_1143mm_16by9_Format.html - http://www.projectorscreen.co.uk/pp/Projector_Screens/Projec tor_Screens/Sapphire_Parklane_Series_Manual_Projection_Scree n_-_2029mm_by_1143mm_16by9_Format.html
her er en anden fra England
Optoma Panoview 92 inch Manual Pull Down 16:9 Projection Screen
http://www.completelyvisual.co.uk/optoma-panoview-inch-manual-pull-down-projection-screen-p-146.html - http://www.completelyvisual.co.uk/optoma-panoview-inch-manua l-pull-down-projection-screen-p-146.html
har osse kigget på de her 2 svenske
Accurate Manuell 200 cm (92 tum) MW Andra sortering
http://www.fyndborsen.se/ScriptServer/TradePoint/B2C/UI/Cata log/ItemView.aspx?Key=5986 - http://www.fyndborsen.se/ScriptServer/TradePoint/B2C/UI/Cata log/ItemView.aspx?Key=5986
Accurate Motordriven 200cm (90tum) MW
http://www.fyndborsen.se/ScriptServer/TradePoint/B2C/UI/Catalog/ItemView.aspx?Key=5990 - http://www.fyndborsen.se/ScriptServer/TradePoint/B2C/UI/Cata log/ItemView.aspx?Key=5990
nogen tanker omkring disse valg af lærdet, da mit buget er ca 1500,- og min throw d er 3,5 m kan jeg prodecere 92" ca +/-  2 "
bliver i stuen , får først dek rum om ca 1 år tid desvære, så gidder ikke
åbne tegnedrengen for meget før den til, med et fast lærdet i oki god qualitet
min pj er en inFocus in78
+100HD Film
Skrevet af: Raven_74
Skrevet den: 30-Oktober-2008 kl. 09:03
Jeg kan desværre ikke få nogen af linkene til at virke!
Har copy pasted til både Firefox og IE.
Raven_74
Skrevet af: Clinten
Skrevet den: 30-Oktober-2008 kl. 09:25
Her:
http://www.projectorscreen.co.uk/pp/Projector_Screens/Projector_Screens/Sapphire_Parklane_Series_Manual_Projection_Scree n_-_2029mm_by_1143mm_16by9_Format.html - Projectorscreen.co.uk  sitet siger "Item out of stock" så det er ikke så informativt.
http://www.fyndborsen.se/ScriptServer/TradePoint/B2C/UI/Catalog/ItemView.aspx?Key=5986 - Fyndbørsen 1
http://www.fyndborsen.se/ScriptServer/TradePoint/B2C/UI/Catalog/ItemView.aspx?Key=5990 - Fyndbørsen 2
Der var utilsigtet kommet et mellemrum i linkene...
Skrevet den: 30-Oktober-2008 kl. 11:04
Alle link ´s er opdateret og virker nu som hyperlink... skulle bruge IE for at kunne hyperlinke ordenligt..
Henrik
+100HD Film
Skrevet den: 30-Oktober-2008 kl. 18:51
ingen der vill kommentere godt eller skidt
Henrik
+100HD Film
Skrevet af: Lars
Skrevet den: 30-Oktober-2008 kl. 19:02
Jeg tror erfaringerne herhjemme mere går på de danske lærreder, fra Lissau og Quality Screen, samt evt. Steward for den mere prof. installation (Steward er ikke danske - men de bygges/samles i Danmark).
Så når du finder nogle forskellige lærreder i udlandet, som ingen herhjemme kender, så er det svært at hjælpe
  /Lars
Ansvarshavende redaktør.
Webmaster, recordere.dk
Skrevet af: CSN Teknik
Skrevet den: 02-November-2008 kl. 00:09
Inden du beslutter dig så sørg for at få nogle lærreds prøver for at sammenligne med.
Mvh.Christian
http://www.csn-teknik.dk -
Integra.Elac.Velodyne.MKSound.KEF.CSN CustomCables.
