Logitech Squeezebox Touch & Radio
Forumnavn: Streaming media
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=62140
Udskrevet den: 19-Februar-2025 kl. 02:32
Emne: Logitech Squeezebox Touch & Radio
Skrevet af: slate
Skrevet den: 22-Juni-2009 kl. 01:45
En ny presset æske på vej.... intet officielt endnu men den er dukket op på et par web shops til ca 280-300€
The color touch-screen Wi-Fi music player that lets you discover a world of music. Listen to your personal digital music collection, new music from online music services, and thousands of Internet radio stations—all through your stereo. A 4.3-inch color touch screen makes it easy for anyone to use.
'22-07-2009' as availability date?! mon ikke Squeezecenter 8.0 kommer samtidig
http://www.avforums.com/forums/streamers-network-music-players/1021607-avforums-squeezebox-touch-discussion-thread.html - http://www.avforums.com/forums/streamers-network-music-playe rs/1021607-avforums-squeezebox-touch-discussion-thread.html
http://forums.slimdevices.com/showthread.php?t=64706 - http://forums.slimdevices.com/showthread.php?t=64706
Stue: Duet->Beresford Caiman->Carver A-500x->B&W 704 + Tosh EP35, Sony 32v5500
Kælder: Mitsu HC6000, Steward 92", Tosh XE1, Oppo 93, Onkyo 875, JBL+Velo
DVD:124, RØD:141, BLÅ:107
Skrevet af: slate
Skrevet den: 24-Juni-2009 kl. 09:11
Så nåede nyheden til engadget; de nævner også opdateringer til Boom og Duet...
http://www.engadget.com/2009/06/23/logitech-prepping-squeezebox-updates/ - http://www.engadget.com/2009/06/23/logitech-prepping-squeeze box-updates/
Skrevet af: slate
Skrevet den: 25-Juni-2009 kl. 00:23
Der kom vistsnart en officiel release; indtil videre må i nøjes med en oversættelse fra Hollandsk. Bid mærke i 24/96.
Logitech Squeezebox expands line with Touch-model
Logitech is about to its Squeezebox line upgrade it. It is partly a Squeezebox Touch with a 4.3 "touchschreen. Furthermore, the Squeezebox Duet and an update will be small tree variants.
Logitech Squeezebox TouchThe Squeezebox Touch includes a capacitive touch-sensitive screen with a Diagonal Size 4.3 inch.
The Touch can mp3, flac, wav, aiff, wma, ogg, aac and ale-files from a USB storage device or SD card playback. WMA lossless, APE, MPC and WavPack files are transcoded by the player, which also can be played.
Furthermore, the Squeezebox radiostreams Touch handle the formats mp3, ogg and wma.
In addition to the analog audio and headphone outputs, the device includes optical and coaxial digital output, while the connection to the Internet via Ethernet or 802.11g wifi.
Notable features are a light sensor that adjust the brightness automatically adjusts to ambient light and proximity sensor that the presence of the user takes.
Several websites offer the Touch all for a price between 270 and 330 euro, but the supply is likely to begin only in July.
The release of the Touch will probably coincide with those of two new Squeeze Boxes.
It would be small devices with embedded speakers
are: a portable player with radio that works on batteries and will cost $ 200, and an alarm clock of 300 dollars. Both will be under the Boom flag be given.
Finally, the Squeezebox Duet is a thinner version released.
Audio formats: • MP3, FLAC, WAV, AIFF, WMA, Ogg Vorbis, AAC, Apple Lossless • WMA Lossless, APE, MPC and WavPack supported through transcoding • Some formats may require additional software installation Internet radio • Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams Wireless interface • True 802.11g wireless networking • Support for 802.11b and 802.11g routers and access points • One-touch setup (with compatible WPS-supporting routers) • Supports WPA Personal, WPA-2AES, and 64/128-bit WEP encryption Ethernet interface • Connects to any 100 Mbps or 10 Mbps network (with Auto MDX) General: • USB host connector for accessing music and photos via USB drive or USB key • SD card slot for music and photos • Supports sampling rates up to 24 bit / 96 kHz • Stereo analog (RCA), headphone jack, digital optical, and digital coax output • 4.3-inch 24-bit color LCD with capacitive touch screen • Ambient light sensor to adjust display brightness according to environment • Infrared proximity sensor to detect presence
Skrevet af: panhero
Skrevet den: 24-Juli-2009 kl. 21:36
Oprindeligt skrevet af slate slate skrev:
Jeg skal lige være helt med, da engelsken ikke er i top. Er det korrekt at der vil komme opdateringer af Squeezebox Duet? Tror du/I det bliver i form af nye modeller eller hvordan skal sidste linie forståes?
Jeg er heller ikke helt med på, om Squeezebox Touch er ligesom en Squeezebox controller? Forstået på den måde at man skal have en reciever ved siden af - eller kan man nøjes med Touch'en (hvis nu der var en indbygget reciever i, hvis man kan kalde den det).
mfg. the one and only panhero
Skrevet af: Muele
Skrevet den: 27-Juli-2009 kl. 10:20
Engadget blander tingene sammen.
http://forums.sonos.com/showthread.php?t=13043&highlight=squeezebox - http://forums.sonos.com/showthread.php?t=13043&highlight =squeezebox I dette link er et rygte om flere nye produkter(Heriblandt en ny controller og boom), som har været "prøvet af" på en lukket skare af brugere. Det må siges at være et løst rygte, da det bare er en enkelt gut der taler over sig.
Mht Squeezebox touch, må det siges at være lidt mere konkret. Der er mindst tre webshops der er kommet til at publisere den til salg. Først med d. 22/7 som leveringsdato og senere med en leveringsdato ca 20/8, jeg husker det ikke helt.
Touchen bliver en receiver med "nærbetjening". Nok noget lignende controlleren (baseret på samme software?), men med touchskærm istedet for knapper og drejehjul.
Nu må vi se hvornår de synes de har soft-/firmwaren nok på plads til rent faktisk at release den.
-Mogens
Edit: ændret link til Sonos' forum, hvor rygtet faktisk kom fra.
Skrevet af: slate
Skrevet den: 27-Juli-2009 kl. 15:01
Touch bliver ved med at dukke op på webshops.
Her en fra New Zealand - På lager 18/8 ?!
480 NZD = 1650 DKK
http://www.ascent.co.nz/productspecification.aspx?ItemID=379698 - http://www.ascent.co.nz/productspecification.aspx?ItemID=379 698
Skrevet af: panhero
Skrevet den: 04-August-2009 kl. 16:49
"Touchen bliver en receiver med "nærbetjening". Vil det sige at man skal sætte højtalerstikket bagi Touchen eller? For det virker ikke videre smart til en fest.
Skrevet af: Letten
Skrevet den: 04-August-2009 kl. 17:36
Du skal ikke regne med at der er forstærker i, så enten skal det være aktive højttalere eller også skal det lige forbi en forstærker først.
Jukeboxe plejer da at fungere fint til fester
Skrevet af: slate
Skrevet den: 13-August-2009 kl. 10:53
Produkt informationen var kortvarigt oppe på Logitech New Zealand, men er fjernet igen. Der var dog nogen som nåede at tage et snapshot af siden.
Nye billeder kan ses i denne tråd, midt på siden http://forums.slimdevices.com/showthread.php?t=64706&page=31 - http://forums.slimdevices.com/showthread.php?t=64706&pag e=31
Så må vi se om den 18 August holder.
Skrevet af: tipsen
Skrevet den: 13-August-2009 kl. 15:26
Som én bruger skrev på forum'et var det nok ikke realistisk, da man nok skulle vente på en færdiggørelse af SqueezeCenter 7.4 samt det nye website.
Skrevet af: slate
Skrevet den: 26-August-2009 kl. 16:56
Ingen officiel nyhed endnu, men nu er de dukket op på Logitechs US webshop til pre-order
http://buy.logitech.com/store/logib2c/en_US/pd/productID.156464000">Squeezebox Touch
http://buy.logitech.com/store/logib2c/en_US/pd/productID.156464000 - Squeezebox Touch
The digital music revolution has given you a wealth of ways to enjoy music. Digital music files allow you to easily store thousands of songs. Online music services can tailor tunes to your taste. Internet radio lets you discover new genres from all over the world. Now, your Logitech® Squeezebox™ Touch brings it all together in a powerfully simple little package that uses your Wi-Fi or Ethernet network to stream music to your stereo system. Up close, the player uses an intuitive, fun-to-use color touch screen. From the sofa, you use the included wireless remote. Now that’s a digital revolution that hits all the right notes.
USD 299.99
http://buy.logitech.com/store/logib2c/en_US/pd/productID.156463700">Squeezebox Radio - Black
http://buy.logitech.com/store/logib2c/en_US/pd/productID.156463700 - Squeezebox Radio - Black
Logitech Squeezebox Radio combines the power of the Internet with the simplicity of old-fashioned radio. You plug it in, turn it on, and pick a source—free Internet radio, subscription services*, or your personal digital music collection.
Skrevet af: slate
Skrevet den: 03-September-2009 kl. 13:41
Så blev det officielt
Touch http://www.logitechsqueezebox.com/products/squeezebox-touch.html - http://www.logitechsqueezebox.com/products/squeezebox-touch. html
Radio http://www.logitechsqueezebox.com/products/squeezebox-radio.html - http://www.logitechsqueezebox.com/products/squeezebox-radio. html
Skrevet af: Kurt Poulsen
Skrevet den: 03-September-2009 kl. 21:09
Det kunne godt ligne en julegave
Mvh Kurt
Philips 50PUS9006,
Sony BD200D
Sonos Beam med 2 Symfonisk som baghøjtalere.
Sonos Port, 2 x Sonos One Sl, 1 x Ikea Symfonisk
Skrevet af: JanFroe
Skrevet den: 04-September-2009 kl. 17:36
Den er bare vildt lækker, det kunne være fedt hvis den kunne TDC-PLAY og at man havde et WEB-PLUG-in så man kunne programmere sit mediacenter via en programguide på touchscreenen. Så er det både Jul og Fødselsdag på samme tid.
Jan F
JanFroe
Skrevet af: tipsen
Skrevet den: 04-September-2009 kl. 20:38
DRM rimer ikke på Squeezebox, så TDC-Play er no go.
Skrevet af: joze
Skrevet den: 08-September-2009 kl. 20:07
Den nye SB touch bliver helt klart et must for mig. Det ser ud som om, jeg kan slippe for at have en pc kørende 24/7 og  istedet koble min USB disk direkte til SBT'en og spare en del strøm. Den kan tilmed streame til huset andre enheder og agere som SMB share, så man ganske let kan pushe ny musik fra en PC op på USB disken.
Skrevet af: Highway
Skrevet den: 08-September-2009 kl. 22:23
Ny på banen.. Søger en mulighed for at afspille musik overalt:) Så faldt jeg over denne tråd.
For at skære ud: Kan jeg slutte sq. touch til min forstærker (hvis ja, hvilke kabler bruges??). Derefter kan man så sidde med touch skærmen og styre musikken eller skal den stå ved siden af forstærkeren siden den vel er tilsluttet her med kabel...? Eller skal man styre touch med en fjernbetjening?
Hvordan fungerer multirum funktionen? Skal man hænge en touch op i et andet rum og hvordan sendes lyd videre til højtalere?
Måske dumme ? men har svært ved lige at få et overblik over dens muligheder...
Kan nogen bringe klarhed:)??
Skrevet den: 08-September-2009 kl. 22:27
Læs på http://www.logitechsqueezebox.com/ - http://www.logitechsqueezebox.com/
Mvh Kurt
Philips 50PUS9006,
Sony BD200D
Skrevet af: Highway
Skrevet den: 08-September-2009 kl. 22:42
ok.Helt fint. Så står tingene mere klart.
Jeg kan ikke fange mit trådløse net når jeg går udenfor. Ville det være en ide at anskaffe en router som kan sende et stærkere signal? Tænker ift at streame over netværk (det æder vel noget at eks. streame sin musiksamling over netværket..?)
Skrevet af: tipsen
Skrevet den: 09-September-2009 kl. 00:02
Squeezebox Touch, Squeezebox Receiver (fra Duet-pakken) og Squeezebox Classic er alle beregnet til at koble til et par aktive højttalere eller mere oplagt en forstærker/receiver, som fodrer dine højttalere med lyd. Dvs. de er et "add-on" til dit eksisterende anlæg - et bindeled mellem dit hifi-anlæg på den ene side og din digitale musik på computeren på den anden side (groft sagt).
Touch, Receiver og Classic har alle almindelige phono-udgange samt digitale (optisk/coaxial) udgange. Hvis du bruger phono-udgangene sender du signalet analogt til din forstærker og benytter dermed Squeezebox'ens DAC til at behandle lyden mens de digitale udgange giver dig mulighed for at benytte forstærkerens DAC (eller en ekstern af slagsen).
Touch'en er beregnet til at stå ved anlægget koblet sammen med kabler og dermed ikke som en transportabel enhed/fjernbetjening.
Der er dog ikke noget galt for at Touch'en kan vægmonteres og udelukkende benyttes til at kontrollere andre Squeezeboxe som er koblet til serveren (SqueezeCenter). Det er dog en lidt dyr "fjernbetjening" og man bør her nok overveje enten Controlleren (Fjernbetjening fra Duet-pakken) eller måske en iPhone/iPod Touch med iPeng-programmet til at styre squeezeboksene. Det kan også være at der kommer nogle helt andre brugbare iPod-fjernbetjeninger, når Apple i morgen opdaterer produktlinien!
Hvis du vil have musik i flere rum, skal du bruge en Squeezebox til hvert af rummene samt forstærker og højttalere med mindre du vælger en Squeezebox Boom eller Squeezebox Radio der begge har integrerede højttalere..
Du kan så styre om de enkelte boxe skal synkroniseres eller spille uafhængigt af hinanden afhængigt af behov.
Skrevet af: kyyhn
Skrevet den: 09-September-2009 kl. 08:56
Hov hvor fandt du at den kan streame til de andre enheder? det lyder næsten for godt til at være sandt hvis vi endelig kan slippe for at have Slimserver kørende 24/7!
Skrevet af: joze
Skrevet den: 09-September-2009 kl. 09:00
Inde på forummet hos Logitech/Slimdevices.
Skrevet af: Letten
Skrevet den: 09-September-2009 kl. 09:24
på USB disken.
Husk lige at der er nogle begrænsninger, pga. den ret
svage CPU der er i en Touch.
-ikke noget web interface, du kan altså ikke betjene dine
squeezeboxe fra en browser på en PC.
-ingen transcoding af musikfiler, dvs. at din egen musik
skal ligge i de formater som squeezeboxene kan afkode
native, mig bekendt er det MP3 og FLAC.
-langsom opdatering af musik database. Sker kun ved
ændringer. Hvis du arbejder meget med dine tags, kan det
være en pestilens hvis det tager et halvt døgn at scanne
al musikken igen.
-størrelsen af dit musikbibliotek, jeg vil gætte på at
Touchen ikke egner sig til meget store musiksamlinger
(memory)
Personligt vil jeg nok beholde min laptop indtil jeg
hører om nogle praktiske erfaringer med Touchen.
Skrevet af: joze
Skrevet den: 09-September-2009 kl. 10:03
Mange tak for den liste af begrænsninger, har nemlig ledt efter noget lignende.
Det meste kan jeg nok leve med, da jeg har mit musik i FLac. Jeg har en lille samling på ca 80GB. Langsom opdatering af musik, kan nok også gå. Det springende punkt er helt klart performance.
Men jeg tror jeg tager dit råd og lige spiser brød til og beholder min server til jeg har set hvordan det kører uden.
Nu du er så meget inde i de tekniske sager - ved du hvor stort et SD kort den max vil acceptere?
Skrevet den: 09-September-2009 kl. 10:14
Nu er det jo slet ikke sikkert at den er så langsom til at opdatere musiksamlingen. Så vidt jeg har kunnet forstå på nogle af diskusionerne på forumet så har den et meget lille footprint og den skulle automatisk begynde at skanne musikken når der sker ændringer.
Jeg tror at den kan tage lige så stort et SD-kort som du kan få fat på. Så vidt jeg mener at have læst så understøtter den SD-HC.
Mvh Kurt
Philips 50PUS9006,
Sony BD200D
Skrevet af: slate
Skrevet den: 06-April-2010 kl. 23:13
Så kom Touch endelig på markedet http://wiki.slimdevices.com/index.php/Release_Notes - http://wiki.slimdevices.com/index.php/Release_Notes
Skrevet af: joze
Skrevet den: 07-April-2010 kl. 07:52
Lækkert, men den kan "kun" trække to ekstra players, hvis den skal agere server.
Skrevet af: tipsen
Skrevet den: 07-April-2010 kl. 10:39
- det er jo også en lightudgave af serveren - med skrabet funktionalitet, så det næsten minder om et Sonos System :-)
Skrevet af: bhaagensen
Skrevet den: 07-April-2010 kl. 13:14
al musikken igen.
(memory)
Megahurtig er den (Touchen's SBS) nok ikke, men den nye (inotify-aktiverte) skanner i kombination med sqlite (fremfor mysql) gør den noget usammenlignbar med den gamle. Med SBS 7.6 (var SBS 7.5-embedded=Touch SBS) tager det blot et par sekunder fra jeg kopierer en cd ind, til den kan afspilles - dette sker selvfølgelig automatisk). Dette er dog på en noget kraftigere, men stadig ~7år gammel pc-basert server. Ydelsesspringet er nok ikke lige stort ved forskellige slags gennembladring, men dog i mange henseende stadig væsentlig hurtigere.
Det vidste jeg ikke. Men det må i hvert fald være... samtidigt, eller? Man kan vel godt have så mange afspiller det skal være til at stå i tomgang?
Er det ikke også noget med at Touch ikke understøtter (alle) plugins. Måske ikke 3.parts?
vh
Skrevet af: joze
Skrevet den: 07-April-2010 kl. 13:18
Hehe, ja det kan man sigeLOL
Skrevet af: joze
Skrevet den: 07-April-2010 kl. 13:21
vh
Det håber jeg så sandelig den kan, da det er sådan jeg i givet fald har tænkt mig at bruge den. Når det går vildt til, så har vi tre afspillere til at køre, så det meste af tiden, vil jeg snildt kunne holde mig til to afspillere.
Skrevet af: Muele
Skrevet den: 07-April-2010 kl. 13:38
Det med de maks to ekstra afspillere er godt nok lidt af en bet. Vi har fire afspillere pt.
Det ser dog ikke ud til at det er en hård begrænsning. Så man kan måske forestille sig at det går med 3-4 samtidige afspillere, hvis man har et optimalt setup (mht filtyper, kablet netværk osv)....
http://wiki.slimdevices.com/index.php/Squeezebox_Touch_as_a_Home_Music_Server - http://wiki.slimdevices.com/index.php/Squeezebox_Touch_as_a_Home_Music_Server
Jeg havde ellers en ide om at der skulle sådan én op i stuen ovenpå, og så skulle den gamle spand af en laptop der pt kører som server skrottes. Men nu klapper jeg lige hesten.
Skrevet den: 08-April-2010 kl. 23:01
Ja men den her tråd siger at virkeligheden er en hel anden:
http://forums.slimdevices.com/showthread.php?t=77010 - http://forums.slimdevices.com/showthread.php?t=77010
Mvh Kurt
Philips 50PUS9006,
Sony BD200D
Skrevet af: Muele
Skrevet den: 09-April-2010 kl. 12:28
Det er da gode nyheder. Der kommer nok nogle rapporter om det i de nærmeste dage, når preorders begynder at blive leveret.
Skrevet af: joze
Skrevet den: 09-April-2010 kl. 12:35
Det er da rigtigt gode nyheder. Jeg kommer ikke i nærheden af de antal enigheder, som ham der udtaler sig i tråden. Det krydret, med at Logitech folkene tydeligt skriver, at det ikke er en hård begrænsning, gør at det vil være et udemærket alternativ for mig.
Skrevet af: tipsen
Skrevet den: 09-April-2010 kl. 12:58
Skal det være en USB-enhed der kobles til Touch'en eller kan den tilgå musik på et SMB- eller NFS-share via netværket?
Skrevet af: Muele
Skrevet den: 09-April-2010 kl. 18:06
USB: Ja Share: Nej.
Men den kan relativt nemt hackes til det.
Mon ikke der kommer en app til det inden for kort tid?
http://forums.slimdevices.com/showthread.php?t=76997 - http://forums.slimdevices.com/showthread.php?t=76997
Skrevet af: Muele
Skrevet den: 09-April-2010 kl. 18:13
Nå ja, de anbefaler så ikke at man gør det pga performance, da Databasen over metatags etc lægger sig samme sted som musikken.
Så der skal hackes lidt mere for at på db flyttet over på et flashkort. Jeg tror nu staig på at nogen sætter sig ned og laver det.
Skrevet af: HenrikMadsen
Skrevet den: 15-April-2010 kl. 16:58
Nogen der har fået deres Touch? Min var på vej, men Post Danmark har valgt at smide den væk.
Skrevet af: mdande
Skrevet den: 15-April-2010 kl. 17:57
Er også ret vild med Squeezebox TouchSmile.Men kan det ikke bedre betale sig at købe en Squeezebox reciever og en iTouch. Det er da nogenlunde samme pris ik ? Squeezeboxen er da ikke håndholdt som en iTouch vel ? Eller er der noget jeg har overset ?
Sony BDP-S570
Harmony 1000+IR/RF
Orbaudio mod2 5.1 speakers
Xtreamer/Squeezebox duet
Skrevet den: 15-April-2010 kl. 18:17
Jeg har købt Touchen for 96kHz muligheden
Skrevet af: mdande
Skrevet den: 15-April-2010 kl. 18:23
Sorry ..... Men er lidt blank Wink . Er det kvaliteten på afspilningen eller ?
Sony BDP-S570
Harmony 1000+IR/RF
Skrevet af: Zulu
Skrevet den: 15-April-2010 kl. 18:37
Ja, den indbyggede server i SB Touch'en... Wink
Skrevet den: 15-April-2010 kl. 18:48
Muligheder for at afspille filer af højere kvalitet. CD er 16bit/44.1kHz, DVD-A er 24bit/96kHz. Kun Touch (og Transporter) kan afspille det sidste.
Skrevet af: tipsen
Skrevet den: 15-April-2010 kl. 19:24
Er denne forskel hørbar i praksis eller er der snarere tale om en teoretisk forskel? Hvor køber man musik i denne kvalitet - jeg har set, at Nephew udgav deres nyeste album i 24-bit på nettet, men kan man også rippe en DVD-A, hvis man har sådan én?
Skrevet den: 15-April-2010 kl. 19:37
Det stiller større krav til optagelsen, men på en god optagelse er der forskel. Jeg har rippet mine DVD-A plader til FLAC.
Skrevet af: tipsen
Skrevet den: 15-April-2010 kl. 19:54
Er DVD-A det samme som DVD-Audio - det mente jeg ikke der var nogle "computer-drev" der understøttede? Hvad er det for nogle albums du har rippet og hvilket drev/program har du brugt til formålet?
Skrevet den: 15-April-2010 kl. 20:27
Ja. DVD-A er en forkortelse for DVD-Audio. Alle DVD-drev kan læse DVD-A, men ikke forstå. Det kræver specielt software. Det er SACD, som computere ikke kan læse.
Der er flere programmer der kan rippe DVD-A. Jeg mener det jeg brugte hed DVD explorer og jeg brugte bare min bærbar.
Skrevet af: DanishBacon
Skrevet den: 15-April-2010 kl. 22:50
Proshop sendte min i går, og den ankom til omdeling i Århus 05:25 i morges - men jeg havde desværre været dum nok til igen at vælge at få den sendt direkte til min døgnpost...
Så nu går der en dag ekstra inden jeg får den. Jeg forstår ikke, hvorfor halvdelen af mine døgnpost forsendelser bliver omdelt samme dag som ankomst til Århus, og den anden først over et døgn senere Angry
Men f*ck, jeg glæder til mig til i morgen Big smile
LG OLED C8 65” | Marantz SR7010 | XTZ 99.36 | Nvidia Shield TV | Squeezebox
