Mede8er MED500X ny Realtek, smart design
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=67205
Udskrevet den: 23-December-2024 kl. 08:16
Emne: Mede8er MED500X ny Realtek, smart design
Skrevet af: daskino
Skrevet den: 29-September-2009 kl. 17:43
Xtreamer nye ven og, skulle klare NFS bedre end xtreamer, og har en mindre larmende blæser
youtube video
http://www.youtube.com/watch?v=mgtJaxSMJ5Y - http://www.youtube.com/watch?v=mgtJaxSMJ5Y
Sony 46HX823 Samsung H5505
Roku LT, Google nexus player, Sidewinder 4 Xtreamer,
WD TV HD, Live Mini og Ryan Mini2, SB 3, Wii,
Skrevet af: daskino
Skrevet den: 29-September-2009 kl. 23:34
anmeldelse i engadget
http://www.engadgethd.com/2009/09/22/the-mede8er-multimedia-monster-gets-reviewed?icid=sphere_blogsmith_inpage_engadget - engadget
en anden anmelelse
http://txdaily.co.za/gadgets/meeting-mede8er-multimeda-monster/ - http://txdaily.co.za/gadgets/meeting-mede8er-multimeda-monst er/
Skrevet af: daskino
Skrevet den: 29-September-2009 kl. 23:36
Video Codec Supported: MKV, H264, DVD (VOB – IFO – ISO), DIVX, XVID, DAT, AVI, MPEG, HD MPEG-2, TS, HD MPEG-4, SP, ASP, AVCD (H.264), MTS, M2ts, WMV9, FLV, VC-1, Real Networks (RM/RMVB) 8/9/10, up to 720p
Audio Codec Supported: MP3, MP2, OGG Vorbis, PCM, LPCM, AAC, RA, Dolby AC3 Passthrough, Dolby AC3 Downmix, DTS Passthrough, DTS Downmix, FLAC, WAV,
WMA Standard (DRM, & Advanced Profile not supported)
Photo format Supported: JPEG, BMP
File System Supported: FAT32, NTFS – UI Format Feature
Input / Output
• HDMI 1.3, Component video, Composite Video
• Stereo RCA audio for analogue audio connection
• SD / Sony Pro Duo Card Slot
• S/PDIF optical Output / Coaxial Digital RCA Output
• Video output resolution – NTSC, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p24hz
• USB – 2.0 HOST port x 2 (compatible to USB 1.1)
• USB – 2.0 SLAVE port
General
• 3.5″ SATA Internal Hard Drive Bay up to 2TB compatible
• Built in 40mm cooling fan – TPE mounts for low noise
• Playlist creation from remote
• Screensaver – Selectable in GUI setup
• In folder JPEG preview feature
• Easy navigation button use (excl DVD files)
• Time Bar FF/FR and Time Bar jump
• Media Library Jump To file number feature
• Resume playback feature
• Photo slide show with background music
• Network – Ethernet 10/100 Mbps
• Optional Wi-Fi (802.11b/g/n up to 300Mbps)
• Samba server – NAS storage
• A/V streaming via UPnP Media Server (CNN – YouTube etc via optional program such as PlayOn,   Tversity etc)
• Internet Radio (SHOUTcast)
• File Copying – Card, USB, HDD and Network
• Subtitle: SRT, SSA, SUB, SMI format
Contents: MED500X, RC, AC Adapter, Carry Bag, Cables – AV, HD HDMI, USB, Component, USB extension with Base
Looking at the specs it all seems to be pretty impressive. It is one of the first media players in SA to support HDMI 1.3, X264 Compression and 2TB hard drives.
Skrevet af: dr_schlemer
Skrevet den: 13-November-2009 kl. 22:00
Så er 1 stk på vej i posten. Til at erstatte min gamle rapsody n35; som i sidste ende vandt over popcorn 1.generation pga brugbarheden og det snappy interface... Venter spændt :-)
Skrevet den: 20-November-2009 kl. 17:57
Så er den modtaget - meget positivt første indtryk. God building-quality, masser af tilbehør - bl.a. USB-kabel (til slavemode), bæretaske, component-kabel samt et godt hdmi-kabel. Fjernbetjeningen er også ok.
På få min er hd'en (understøtter op til 2TB) installeret, setup fungerer upåklageligt og skærmen står fuldstændig crispy. Der formateres direkte via boksen i NTFS-format; hvorefter man kan komme i kontakt med maskinen via NAS samba eller usb-slave 2.0.
Det ser ud til at virke rigtig, rigtig godt. Endnu et plus er det meget aktive forum, hvor producenten løbende er i kontakt med sine brugere vedr. forbedringer og problemer med produktet.
Skrevet af: Falcon
Skrevet den: 29-December-2009 kl. 13:35
DR_Schlemer, hvor har du købt den og hvad måtte du give for den?
mvh Jørn
Skrevet den: 02-Januar-2010 kl. 17:59
Jeg har købt den gennem divxplayer.nl for ca. 1300,- inkl. fragt
Skrevet af: Tstampe
Skrevet den: 24-Januar-2010 kl. 13:01
Hej...
Har lige investeret i noget IOMEGA-ting, som skal returneres... Og søgte lidt efter noget der kunne erstatte funktionen streaming af lyd/billeder/film...
Og faldt over dette indlæg. Hvordan er status på dette produkt. Er man tilfreds og er det "FUNDET", som løser mange af tingene i det daglige digitale hjem.
Er den nævnte leverandør her til at stole på eller hvor kan det anbefales at købe produktet. Og bør man ikke købe den med en HD med det samme. Kan se den kan køre som NAS også på netværket... Hvordan fungerer dette og er det super...
Der er da "kun" plads til en HD i dette produkt eller kan man tilslutte eksterne HDer som så også vil fungere med NASen...
Skriv gerne da jeg skal have fundet noget som er transportabel og som tåle lidt normal transport med forsigtig også...
Afventer svar...  Tongue og til den pris.... eller skal man tænke et Popcorn e.l. hjææææælp
Thomas Stampe
Med venlig hilsen
Thomas Stampe
Skrevet af: daskino
Skrevet den: 24-Januar-2010 kl. 17:09
hej har den iike selv me se her hvad en kender sir;
Men det er jo ikke just den mest transportable afspiller, der ville jeg gå efter en lille Bollo med 2,5" hd
After testing and comparing the devices (Mede8er - 6500A - c-200 - HDX-1000)
I must say over all the Mede8er is the best buy:
+ fastest boot up (22 sec with HDD)
+ nice and pratical gui
+ Realtek chip is cheaper than sigma 8635c and has about the same performance
+ mature firmware (just little things need to be fixed e.g. HDD formating doesn't work)
- high bitrate content (>50 Mbps) streamend over gigabit network studders (same as 6500A) but recovers when bitrate is lower (not 6500A it keeps studdering) HDX-1000 due to the 100 Mb interface has more studders, c-200 with latest firmware is flawless!!!!
- nfs shares need to be configured manually (like 6500A, browsing option for c-200 and HDX-1000 - much easier)
- no Frontdisplay for operating the device without TV (good: 6500A, not so good c-200)
- strange remote button order (small play and stop button)
- no thumbnail album art playing music (mp3 - nicer in 6500A)
so for around 150 Eur you get the same functionallity as the 6500A but there is a display missing in the front!!!!
Card reader options weren't important to me so I won't commend on those.
The C-200 has the most powerful chip with additional features like bluray drive it is a complete multimedia devices with bluray and dvd playback and internet gadgets. But the gui of the c-200 and HDX-1000 is slower and not as functional. (I personally like the gui of the 6500A (enhanced with Movie GUI Builder) followed by the mede8er and last the c-200 (faster browsing than HDX-1000)
All Devices have internet radio capabilities (6500A needs a little workaround but it does the job)
Picture quality of all devices is about the same in my eyes on a 50" Plasma
%20 -
Skrevet af: Tstampe
Skrevet den: 24-Januar-2010 kl. 17:31
Så melder spørgsmålet sig...
Hvor skal man erhverve den henne? Hvilken forhandler er troværdig og har en god kundepolitik....
Og hvad hvis den skal repareres?
Med venlig hilsen
Thomas Stampe
Skrevet af: daskino
Skrevet den: 24-Januar-2010 kl. 21:11
tja den er svær at få fat i gennem DK forhandler, men du kan vælge at købe direkte hos mede8er dem selv de sælger direkte. %20 - http://www.mede8ershop.eu/ eller du kan købe hos divxplayer.nl ligesom en aden her i forum har gjort.
Skrevet af: Tstampe
Skrevet den: 24-Januar-2010 kl. 22:21
Takker - jeg havde fundet de 2 salgssider, men overvejede om der ikke var nogen, som kendte til andre steder i DK eller tæt på. Men det findes åbentbart ikke, har dog fundet en tysk leverandør (et sted i Tyskland også)...
Og hvis man evt. finder Mede8er egen hjemmeside i Sydafrika, så er der ovenikøbet større salgspakker med rabat. Men at få en pakke sendt fra den anden side af jorden og garanti... hmmm....
Nogen der har handlet ved divxPlayer.nl og som kan sige god for dem? Wink
Men nogen som ved noget, om denne snart kommer til DK eller... For frygter lidt for garanti-ordningerne ved at handle et af de ovenstående steder...
Atlså hos:
- Divxplayer.nl
- Mede8ershop.eu
Med venlig hilsen
Thomas Stampe
Skrevet af: Tstampe
Skrevet den: 25-Januar-2010 kl. 22:50
Faldt lige over denne tyske butik..... Shocked
Nogen der har handlet der og som kan anbefale den..
http://doublex24.de/product_info.php?info=p696_Mede8er-MED500X---1000-GB-SATA-HDD.html - http://doublex24.de/product_info.php?info=p696_Mede8er-MED500X---1000-GB-SATA-HDD.html
I forhold til direkte hos producenten, så lugter det måske ikke lidt. Hvad mener I?
Med venlig hilsen
Thomas Stampe
Skrevet af: Tstampe
Skrevet den: 29-Januar-2010 kl. 07:41
Hejsa...
Lige et spørgsmål mere...
Nogen som kan foreslå en god HD til Mede8er... Jeg tænker på omkring 1 TB størrelsen, for spørgsmålet er om man ikke skal bestille enheden med en HD i, når man ikke selv har en SATA-HD liggende....
Men kunne være der nogen, som havde et godt forslag og en som måske var mere støjsvag... Big smile
Med venlig hilsen
Thomas Stampe
Skrevet af: Tstampe
Skrevet den: 29-Januar-2010 kl. 13:27
Så er der bestilt en Mede8er uden HD fra Mede8er.eu...
Kan dog oplyse til andre, at den mail-bekræftigelse, som man modtager efterfølgende også har divxplayer.nl nævnt... Så mon ikke det kommer fra samme forretning Wink
Som HD fandt jeg følgende hos danske Compumail:
WD Caviar Green WD15EARS 1500GB SATA 64MB
Så må vi se om det ikke spiller max Big smile...
Med venlig hilsen
Thomas Stampe
Skrevet af: steger
Skrevet den: 11-Maj-2011 kl. 17:14
Hvad så. Var den god skriv gerne din erfaring med den her :)
BIO: Libratone Lounge, Panasonic TH-42PZ80.
PC: Apple Cinema Display 23", ATI HD7850 0db., Core i5 I5-2550K 3,3GHz, 8 GB RAM, Windows 7 x64
Skrevet af: Tstampe
Skrevet den: 12-Maj-2011 kl. 18:40
Hej Steger...
Jeg har nu benyttet MED500X i et stykke tid og den har afspillet det jeg har budt den. Jeg er glad for boksen, men overvejer at flytte den ind til datteren og så benytte den kun til hende. Og så få en LG eller SAMSUNG net-BLUERAY/HHD-afspiller.
Positivt:
- Har løbende opdateringer
- Udemærket forum med hjælp
- Relativ billig boks
- Fruen kan bruge den = Brugervenlig
- Ikke støjende i min stue
Negativt:
- Har oplevet MED500X har slette filer på den interne HD - sket flere gange
Alt i alt har jeg fået en udemærket mediaboks, som har de funktioner jeg ønskede. Og om jeg kan anbefale den.... Der vil jeg skrive, den fungerer MEN jeg har oplevet Materiale er slettet af boksen selv på den interne HD.
Stampe
Med venlig hilsen
Thomas Stampe
Skrevet af: steger
Skrevet den: 13-Maj-2011 kl. 10:55
Tak for svaret. :)
Kan du evt. linke til de to du overvejer at købe - og hvorfor er de bedre en med500x? :)
Skrevet af: Tstampe
Skrevet den: 14-Maj-2011 kl. 09:53
Hej Steger...
Overvejer lidt følgende:
Muligt fælleskøb her:
SAMSUNG BD-D8500. http://forum.recordere.dk/forum_posts.asp?TID=96506&title=flles-kb-for-samsung-bdd8500 - http://forum.recordere.dk/forum_posts.asp?TID=96506&title=flles-kb-for-samsung-bdd8500
eller
SAMSUNG BD-D8900N. http://forum.recordere.dk/forum_posts.asp?TID=97092&title=flleskb-for-samsung-bdd8900n - http://forum.recordere.dk/forum_posts.asp?TID=97092&title=flleskb-for-samsung-bdd8900n
eller
LG-modellen hr570C. http://www.justbuyit.dk/shop/lg-hr-570c-blu-ray-8227p.html - http://www.justbuyit.dk/shop/lg-hr-570c-blu-ray-8227p.html
Det sidste link er blot for at vise dig modellen. Ved ikke om det er det rigtige sted at erhverve den...
Håber dette kan give dig en ide Wink
Med venlig hilsen
Thomas Stampe
Skrevet af: steger
Skrevet den: 16-Maj-2011 kl. 17:09
slettet.
