PS3 virker igen!
Forumnavn: Spillekonsoller
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=76734
Udskrevet den: 06-Juni-2025 kl. 19:35
Emne: PS3 virker igen!
Skrevet af: SteffenD89
Skrevet den: 01-Marts-2010 kl. 11:50
Jeg lurede i MW2 tråden at der var én der ikke kunne spille pga. trophy problemer.
Dette gælder tilsyneladende alle diskbaserede spil, til alle PS3 phat versioner og skulle blive rettet op på hurtigst muligt.
Tjek evt. denne tråd http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=27207195&tag=topics;title - http://www.gamespot.com/pages/forums/show_msgs.php?topic_id=27207195&tag=topics;title
http://bf3stats.com/stats_pc/SteffenD89">
Skrevet af: Mikkel.C
Skrevet den: 01-Marts-2010 kl. 13:18
fandt det her:
Massive bug cripples "fat" PS3s
March 1st, 2010
Yesterday, PS3 owners worldwide suddenly found themselves locked out of the PlayStation Network, with trophy and game functionality severely compromised. No-one knows why, but it appears that a calendar bug within older PlayStation3s has wreaked havoc with the PS3's DRM and authentication systems with a far-reaching impact on the system.
The phenomenon does not appear to have affected the new PS3 Slim, but owners of the larger console are at risk, with the PS3 logging an 8001050F error as soon as the system attempts to connect to the PlayStation Network. The bug causes the date on the system to be reset to 1st January 2000, and reseting the clock manually makes no difference.
Other gamers have reported that the same error kicks in even on offline systems, meaning that titles that synchronise trophies when first booted fail to start. Even test PS3 units used by press and developers are said to be affected. The impact of the bug is so far-reaching that all the paid-for PSN content residing on your PS3 hard drive suddenly loses its activation privileges, meaning that in addition to some retail Blu-ray games that sync trophies on launch, bought-and-paid-for PSN titles are no longer playable in anything other than their trial versions - if they have one.
Quite why the bug kicks in remains unknown at this time. Checking in with SCEE this morning, the official line is, "We have found out that some users are experiencing a network connection failure when signing on to PlayStation Network. We are currently looking into the issue to identify the cause of this network connection failure and will update further information as necessary (on the Blog or official website). We appreciate for your understanding and continued support."
Sony initially acknowledged the issue early this morning, but thus far has offered no advice so far on what the problem is, how it can be avoided, and crucially when it will be fixed. The company has confirmed that Slim units are unaffected.
In the meantime, if you have a non-Slim PS3, and you've not used it since Saturday or beforehand, our advice is to keep it powered down until Sony issues some sort of guidance, or provides a fix. Confirmed on our 60GB launch unit this morning, the bug still impacts PS3s powered up today, even if they were not active on 28th February.
AND
As for which machines are affected, apparently it's model numbers CECH-A through to K that are affected, so basically if you've got a 60 or 40GB, you'll get this, as will the early 80GB models (like mine).
Some of the later 80s and 160GBs (CECH-L onwards) apparently seem to work and all Slims are okay, so it must be something in the older hardware.
I'm not going to risk it and much as I really want to play Heavy Rain, I think I'll stick to gaming on the PC or Wii instead.
Skrevet af: Henrik Nygaard
Skrevet den: 01-Marts-2010 kl. 13:21
Alt er messed up.. Jeg kan ikke logge ind, halvdelen af mine trophies mangler, datoen er 1-1-2000 og intet der kræver PSN forbindelse virker..
Skrevet af: O'Brian
Skrevet den: 01-Marts-2010 kl. 13:26
Same shit her Ouch
Det er vel bare at afvente... ? Hmmmm
Samsung C46 8705.
Samsung LE46M87B.
Philips BDP7500.
Philips DFR 9000.
Philips SRU 9600.
Canton Surround.
Beosound 3000.
Beolab 8000.
PS3-60 GB.
Skrevet af: amorbavian
Skrevet den: 01-Marts-2010 kl. 13:44
Jeg spillede da soendag eftermiddag, og der var ingen problemer paa min 80GB (ved ikke hvilken kode den har.)
Kom der en update som fuckede det op i loebet af dagen?
BORING!
Skrevet den: 01-Marts-2010 kl. 13:48
Det er uafhængigt af om man har været på nettet eller om den overhovedet er opkoblet på nettet. Hvis jeg mangler trophies permanent bliver jeg en smule irritabel.
Skrevet af: Pongman
Skrevet den: 01-Marts-2010 kl. 13:59
Sad og spillede i går og jeg oplevede ingen problemer.
Men tør da ihvertfald ikke tænde den i aften :(
Skrevet den: 01-Marts-2010 kl. 14:01
"It's a problem with the system clock (which is different from the OS clock that you see). It seems the system clock hit February 29th, 2010, and then the OS clock realized this is an impossible date, freaked out and went back to 1999. It should fix itself tomorrow (March 1st for the PS3), but either way, Sony is going to need to do a firmware fix."
Skrevet den: 01-Marts-2010 kl. 15:24
løsning
Don't know if this has been mentioned here but its indeed the internal clock of the older ps3's that is affected by this. The way to fix this issue on your own and you are already out of warranty. Is to open up your ps3 and get to the internal battery (its under the right front deck, and the battery will be green covered)and unplug it. Give it a min then plug it back in and reassemble your ps3. All should be good now.
I just got doing this and it works like a charm, not only fixing this issue but got a chance to clean the bottom half of the inside of my ps3 which was a mess lol.
But once again do this at YOUR OWN RISK.
Part two http://www.youtube.com/watch?v=TePnCFKionE - http://www.youtube.com/watch?v=TePnCFKionE At Around 1:29 yOU SEE THE GREEN BATTERY TAKE IT OUT AND PUT IT BACK
Also if you've had your ps3 fatty fixed through Sony and its working its quite possibly that they had to reset your battery at the service center then and that is why you aren't having this issue now.
Skrevet den: 01-Marts-2010 kl. 16:06
Sidst jeg havde min tændt var fredag d. 26, inden jeg i dag tændte den ved 12-tiden - så det har i hvert fald ikke haft noget at sige om den har været tændt eller slukket i perioden.
Men de må fandme gerne snart få problemet ordnet!
Skrevet af: osbech
Skrevet den: 01-Marts-2010 kl. 16:19
Cry
Blev også ramt af det igår.. Det samme gjorde en af mine venner... Håber snart de finder på en løsning..
Skrevet af: Speednut
Skrevet den: 01-Marts-2010 kl. 16:43
lidt træls, når man gerne vil spille lidt, når man kommer hjem fra arbejde. Jeg håber at Sony finder en løsning ret så hurtigt på problemet
Surround: Pioneer KRP-600M, Pioneer LX60, Pioneer BDP-LX71, Velodyne SPL 1200 Ultra, Focal Chorus surround.
Head-Fi: Sennheiser HD800, Red Wine Isabellina HPA LFP-V DAC/headamp
Skrevet af: osbech
Skrevet den: 01-Marts-2010 kl. 17:33
De mener det skulle rette sig selv i nat kl 24. Det er noget med det interne ur, skud år osv.. Lidt ala. the millenium bug.
Skrevet den: 01-Marts-2010 kl. 18:18
De kunne også bare fixe en patch, så vi skal vente yderligere 6 timer på at problemet MÅSKE løser sig selv.
Skrevet af: osbech
Skrevet den: 01-Marts-2010 kl. 18:26
Problemet er bare at den ikke kan gå på nettet og fw opdateres.  Så er der selvfølgelig usb muligheden, men hvis det bliver løst kl tolv midnat, så er skaden ikke så stor, og de kan få tid til at gennemgå systemet for evt. fremtidige fejl.
Skrevet den: 01-Marts-2010 kl. 18:28
Jeg mener at have læst, at systemopdateringer kører i et system for sig selv, så der skulle ikke opstå de store problemer der
Skrevet af: osbech
Skrevet den: 01-Marts-2010 kl. 18:31
Hvis det er tilfældet, så er skaden endnu mindre...
Skrevet den: 01-Marts-2010 kl. 18:59
Det vil jeg også tro er tilfældet. Man kan jo sagtens køre en systemopdatering og få godkendt, at man har seneste firmware installeret.
Ligeledes kan man også sagtens bruge browseren, så der er uden tvivl "hul igennem".
Skrevet af: Krjstoff
Skrevet den: 01-Marts-2010 kl. 19:47
Jeg havde ellers taget en fridag for at spille en god gang Heavy Rain som blev hentet da posthuset blev åbnet, men nej....
Lige for at opsumere:
- Systemopdatering bør virke fint. Den kan i hvert fald sagtens fortælle at den nyeste version er installeret. Så når der kommer en officiel løsning fra Sony, bør det fungere ganske godt (sålænge det kan fixes med en firmware-opdatering).
- Fejlen optræder udelukkende på de tykke PS3'er og alle slim-ejere er gået fri.
- Fejlen optræder også selvom PS3'en aldrig har været koblet på internettet.
- Der er IKKE tale om en isoleret PSN-fejl, selvom det umiddelbart kan se sådan ud.
- Der er risiko for at miste både save-data og trophy-data, hvis man anvender konsollen i den nuværende tilstand.
- Det er muligt selv at fixe problemet ved at pille det interne batteri ud, vente ca. 30 sekunder og samle det hele igen. Man skal dog være opmærksom på at al garanti og reklamationsret forsvinder.
Læs evt. mere her:  http://blog.us.playstation.com/2010/03/latest-info-on-playstation-network-status/comment-page-3/#comments - http://blog.us.playstation.com/2010/03/latest-info-on-playstation-network-status /
Jeg må tilstå at jeg er blandt mange bitre PS3-ejere lige nu.
En fridag er jo ikke ligefrem gratis...
Men livet går jo videre ... og mon ikke Sony finder på en løsning snart. Lad os bare sige at de i den grad er under pres fra deres brugere, hvis man kigger lidt rundt på diverse fora på nettet.
| Synology DS412+ | ATV4 | PS4 | Onkyo 507 | System Audio 2.1 | Logitech Smart Control |
Skrevet af: zulfo
Skrevet den: 01-Marts-2010 kl. 19:53
Men ikke på alle.... min 80Gbyte er i hvert tilfælde gået fri af fejlen....
Lars B
Skrevet af: osbech
Skrevet den: 01-Marts-2010 kl. 19:58
Selvfølgelig finder Sony en løsning hurtigt, alt andet ville være selvmord på så presset et marked (konsol)
Skrevet af: osbech
Skrevet den: 01-Marts-2010 kl. 20:07
Her kan man følge med i de officielle udtagelser fra sony http://twitter.com/PlayStationEU
Skrevet den: 01-Marts-2010 kl. 20:28
Altså nu er det helt tilfældigt at det lige rammer din fridagTongue men jeg forstår derimod sagtens gerne alle de nye Heavy Rain ejere der kommer hjem fra arbejde også sker dette..
Det skulle dog rette sige selv i aften til midnat.
Skrevet den: 01-Marts-2010 kl. 21:31
Det vil jeg nu se før jeg tror det. Min tror stadig det er d. 31/12, så jeg tvivler på at den finder frem til første marts ved midnat. Men håbet er da lysegrønt :)
Nåja og den skulle jo komme: http://www.youtube.com/watch?v=hoENVnD3J8w - - -
Hitler gets 8001050F on his Playstation 3 on 01 March 2010
Tongue
Skrevet den: 01-Marts-2010 kl. 21:36
minder mig om: http://www.youtube.com/watch?v=sfkDxF2kn1I&feature=related - http://www.youtube.com/watch?v=sfkDxF2kn1I&feature=related
kunne være fedt hvis der blev lavet en PS3 version med nævnte emne haha.
Skrevet den: 01-Marts-2010 kl. 21:45
Arh jeg er en link spasser - Internet er langt foran Steffen:
http://www.youtube.com/watch?v=hoENVnD3J8w - http://www.youtube.com/watch?v=hoENVnD3J8w
:D
Skrevet den: 01-Marts-2010 kl. 22:06
Det der var fucking godt hahahaha
Skrevet den: 01-Marts-2010 kl. 22:12
Den Hitler scene har været brugt meget flittigt i løbet af årene.
Men den bliver sgu aldrig for gammel. Kan stadig huske Warner gik Blu-ray exclusive udgaven LOL
Skrevet den: 01-Marts-2010 kl. 22:25
:D
Det er MÅNEDER siden jeg har grinet så meget!!! Big smileBig smileBig smile
Skrevet af: act_dk
Skrevet den: 01-Marts-2010 kl. 22:31
:D
Don't worry - he won't buy a Wii LOL
Skrevet den: 01-Marts-2010 kl. 22:38
"this never happend on my Atati 2600 with woodgrain finish - a console for true men."
Skrevet den: 01-Marts-2010 kl. 23:18
Den er da også for hardcore! Fuck painolak, hvis bare man kan få træpaneler! Big smile
http://jeremyhildreth.com/wp-content/uploads/2009/07/Atari2600a.jpg - http://jeremyhildreth.com/wp-content/uploads/2009/07/Atari2600a.jpg
Skrevet af: osbech
Skrevet den: 02-Marts-2010 kl. 01:01
It's alive Thumbs Up dog med lidt tab af trophies
Skrevet den: 02-Marts-2010 kl. 01:36
Min er stadig død Confused
Skrevet af: osbech
Skrevet den: 02-Marts-2010 kl. 01:45
Med samme fejlkode? min loggede på og så af igen, men nu er den stabil, har lige gamet lidt avp..
Skrevet den: 02-Marts-2010 kl. 03:09
Den kom heldigvis efter det nu - 4 runder MW2 uden problemer Smile
Skrevet af: viking40
Skrevet den: 02-Marts-2010 kl. 08:43
Så virker det igenBig smile
Men dato og uret rammer lidt ved siden af. 1 dag og 1 time og 10 min. forkert???
ps Online id ufo-viking
Skrevet den: 02-Marts-2010 kl. 09:03
hvordan med trophies? Er de der alle?
Skrevet af: Gelardi
Skrevet den: 02-Marts-2010 kl. 09:33
min virker også igen...og det ser ud atalle mine trophies er stadig der...
SONY KDL-46HX855
SONY STR-DN 1000
ANTHONY GALLO Nucleus Micro 5.1
SONY PS3 500 GB
PANASONIC DMP-BDT310
iPhone 5+5s16+32 GB
iMac 27"
iPad4,32GB3G,white
iPad Air 64GB3G,white
Skrevet den: 02-Marts-2010 kl. 10:03
Nu staar der, at lortet virker: men har I en officiel besked fra Sony?
BORING!
Skrevet af: rustru
Skrevet den: 02-Marts-2010 kl. 10:21
We are aware that the internal clock functionality in the PS3 units other than the slim model, recognized the year 2010 as a leap year. Having the internal clock date change from February 29 to March 1 (both GMT), we have verified that the symptoms are now resolved and that users are able to use their PS3 normally.
If the time displayed on the XMB is still incorrect, users are able to adjust time settings manually or via the internet. If we have new information, we will update you through the  http://blog.us.playstation.com/ -  or http://us.playstation.com/ - .
We apologize for any inconvenience this may have caused.
kilde:  http://blog.us.playstation.com/ -
Skrevet af: zulfo
Hvis nogen finder sådan en med et par spil, så er jeg aftager Tongue
Spillede SÅ meget på Atari 2600 da jeg var drenge, men jeg kan ikke huske hvad der blev af maskinen...
En ZX81'er er jeg også aftager til LOL
Nå, jeg skulle ikke kapre tråd!
Min egen PS3 80Gbyte fedbjerg blev ikke ramt af fejlen på noget tidspunkt, så dens modelnummer har nok været en af de heldige...
Lars B
