Filen skulle hedde .tgz
Nu er den insatlleret, men serveren vil ikke starte.
0376: [10-04-20 16:25:07 ] ssctrl failed to start SqueezeboxServer. 0375: 0374: 3. Run the .tar.gz version of Squeezebox Server which includes all required CPAN modules. 0373: 2. Update the module's package using apt-get, yum, etc. 0372: 1. Install the latest version of the module(s) using CPAN: sudo cpan Some::Module 0371: To fix this problem you have several options: 0370: 0369: Audio::Scan (loaded 0.61, need 0.62) 0368: The following CPAN modules were found but cannot work with Squeezebox Server: 0367: [10-04-20 16:25:04 ] ssctrl Command line = /opt/ssods4/var/home/SqueezeboxServer/slimserver.pl --daemon --pidfile /opt/ssods4/var/home/SqueezeboxServer/Cache/squeezecenter.pid --cachedir /opt/ssods4/var/home/SqueezeboxServer/Cache --logdir /opt/ssods4/var/home/SqueezeboxServer/Logs --prefsdir /opt/ssods4/var/home/SqueezeboxServer/Prefs --noupnp --priority 0 --user guest --group everyone --httpport 9001 0366: [10-04-20 16:25:03 ] ssctrl Patching /opt/ssods4/var/home/SqueezeboxServer/Bin/arm-linux/sls 0365: [10-04-20 16:25:03 ] ssctrl Using system mysqld: /usr/local/mysql/libexec/mysqld 0364: [10-04-20 16:25:03 ] ssctrl Starting SqueezeboxServer 7.5.0-30464. 0363: [10-04-20 16:23:38 ] ssctrl failed to start SqueezeboxServer. 0362: 0361: 3. Run the .tar.gz version of Squeezebox Server which includes all required CPAN modules. 0360: 2. Update the module's package using apt-get, yum, etc. 0359: 1. Install the latest version of the module(s) using CPAN: sudo cpan Some::Module 0358: To fix this problem you have several options: 0357: 0356: Audio::Scan (loaded 0.61, need 0.62) 0355: The following CPAN modules were found but cannot work with Squeezebox Server: 0354: [10-04-20 16:23:35 ] ssctrl Command line = /opt/ssods4/var/home/SqueezeboxServer/slimserver.pl --daemon --pidfile /opt/ssods4/var/home/SqueezeboxServer/Cache/squeezecenter.pid --cachedir /opt/ssods4/var/home/SqueezeboxServer/Cache --logdir /opt/ssods4/var/home/SqueezeboxServer/Logs --prefsdir /opt/ssods4/var/home/SqueezeboxServer/Prefs --noupnp --priority 0 --user guest --group everyone --httpport 9001 0353: [10-04-20 16:23:35 ] ssctrl Patching /opt/ssods4/var/home/SqueezeboxServer/Bin/arm-linux/sls 0352: [10-04-20 16:23:35 ] ssctrl Using system mysqld: /usr/local/mysql/libexec/mysqld 0351: [10-04-20 16:23:34 ] ssctrl Starting SqueezeboxServer 7.5.0-30464. 0350: [10-04-20 16:23:11 ] ssctrl failed to start SqueezeboxServer. 0349: 0348: 3. Run the .tar.gz version of Squeezebox Server which includes all required CPAN modules. 0347: 2. Update the module's package using apt-get, yum, etc. 0346: 1. Install the latest version of the module(s) using CPAN: sudo cpan Some::Module 0345: To fix this problem you have several options: 0344: 0343: Audio::Scan (loaded 0.61, need 0.62) 0342: The following CPAN modules were found but cannot work with Squeezebox Server: 0341: [10-04-20 16:23:06 ] ssctrl Command line = /opt/ssods4/var/home/SqueezeboxServer
