http://www.befro.dk/shop/productinfo.asp?id=98%2D135%2D00030 - - Mustek DVD PL207 |
DVD, DVD+R/RW, DVD+R/RW, CD, CD-R/RW, (S)VCD, Kodak Picture CD and JPEG playback 7 inch active-matrix TFT screen (16:9) 5.1CH digital output Ultra slim & light weight: 196 x 150 x 28 mm; 700 g Credit-card-size wireless remote control Rechargeable lithium ion battery pack (for about 3 hours) 12-volt car cigarette lighter adapter for the car Audio/video cable for TV connection Build-in stereo speakers and stereo headphone jack Anti-shock system (ASP) DKK 2089,-
Eller denne Nextbase.
SDV17-A key features |
http://www.nextbase-europe.com/Webshop%20SDV17-A-en.html"> | |
- Tray type for easy loading
- 7 inch (17,78cm) 16:9 true color TFT display
- Super slim and lightweight for maximum portability
- Built-in Dolby digital (AC-3) decoder
- Built-in stereo speakers (1W +1W) and earphone jack
- Built-in anti-shock system
- DVD, CD and MP3 player in one
- Battery pack, car headrest holder and DC12V car power cable included
- Fully compatible with easy installation stands and arms for in car use. Europe E-mark approved by TUV Germany
TFT screen |
- 7 inch (17,78cm) 16:9 4:3 TFT display with wide temperature range (0 - 60 Celcius)
- Viewing area 154.08(W) x 86.58(H) mm
- High resolution 336,960 pixels (W480 x H234 x 3RGB)
Compatible formats and media |
- DVD/VCD/SVCD/MP3/CD/JPEG
- CD-R/RW, DVD+/-R/RW
Input/output |
- AUTO/PAL/NTSC system
- 1 x DC 12V input
- 1 x Optical digital audio IN/OUT (mini jack)
- 1 x Video IN/OUT (mini jack)
- 1 x 3.5mm earphone output with volume control
Battery pack |
- Rechargeable Ni-MH battery 3600 mAh
- Over 3 hours DVD playback time (7.4V, 3600mAh)
Physical format |
- Dimensions: 202 x 154 x 26 mm
- Weight: 674g without battery
Accessories included |
- AC-DC adapter, remote control, AV cable, soft carrying bag, operation manual, accessory bag, battery pack, car headrest holder and DC12V car power cable
Other |
- Multi OSD language (English, German, French, Italian, Spanish)
- Multi angle/audio/subtitles supported
- Parental lock
- Fast forward/reverse (X2,X4,X8,X20)
- Zoom play (X2,X3,X4,X1/2,X1/3,X1/4
- A-B and repeat function
- Programme play function
- Previous and next play function
- Search play function
- Battery capacity indicated on TFT function
Certification |
- Macrovision, Dolby, CE-LVD, CE-EMC, FCC, UL, CCC, E-mark, CSS, FDA
€ 249,-
