Gælder det kun controlleren?
De andre enheder: Zonebridge, ZP90 og ZP120 kan resettes totalt ved at tage strømmen fra, holde "mute" inde, blive ved med at holde "mute" inde og sætte stømmen til.
Når enheden blinker går reset i gang og "mute" kan slippes.
Fra Sonos's egen Q&A:
Question |
As a general rule of thumb, Sonos does not suggest factory resetting your Zones in an attempt to resolve any issues you are having with your system. Rarely a factory reset will resolve anything, and in turn just creates more work on your end because it erases all of your saved settings. Factory resetting is mainly used if you are looking to register the system to a new email address and not for troubleshooting purposes.
ZonePlayer: Disconnect power, and then hold down the mute button and reconnect the power plug. Continue holding the Mute button until the Mute indicator light begins to flash amber. Eventually it will start flashing green and white simultaneously, meaning it is factory reset and ready to add back to your system.
ZoneBridge: Disconnect power, and then hold down the Connect button and reconnect the power plug. Continue holding the Connect button until the status indicator light begins to flash amber. Eventually it will start flashing green and white simultaneously, meaning it is factory reset and ready to add back to your system.
Handheld Controller 200: Select Settings>Controller Settings>Advanced Settings>Factory Reset from the Music Menu. If the message “Searching for ZonePlayers” is displayed, select Settings>Factory Reset.
