Onkyo TX-SR876 FW opdatering?
Forumnavn: Teknik & Teori
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=88434
Udskrevet den: 24-Februar-2025 kl. 19:19
Emne: Onkyo TX-SR876 FW opdatering?
Skrevet af: MMJ,75
Skrevet den: 06-November-2010 kl. 17:21
Hej. er der nogen der har opdatering deres onkyo, 876?
jeg kan ikke få min pc til at snakke med min 876. den skiver
"Run-time error '8002'"?????.
så er der nogen herinde som kan hjælpe mig Tak!..
http://www.avsforum.com/avs-vb/showthread.php?t=1067401 - http://www.avsforum.com/avs-vb/showthread.php?t=1067401
ps, jeg er lidt ordblind. så ikke så god til at læse
Skrevet af: Hother
Skrevet den: 06-November-2010 kl. 17:40
Hvis jeg kigger på Onkyos hjemmeside (godt nok US siden), så er der ingen updates)
http://www.us.onkyo.com/model.cfm?m=TX-SR876&class=Receiver&p=d - http://www.us.onkyo.com/model.cfm?m=TX-SR876&class=Receiver&p=d
Skrevet af: MMJ,75
Skrevet den: 06-November-2010 kl. 17:51
http://www.us.onkyo.com/model.cfm?m=TX-SR876&class=Receiver&p=d - http://www.us.onkyo.com/model.cfm?m=TX-SR876&class=Receiver&p=d |
Hej Hother. det er hvad jeg har fundet ud af nu?. jeg har skaffet denne her 1.05 den har nu 1.01 i?.
New Main firmware available at Onkyo Service points only, 2009-01-14: Main 87 1.04 08Z22A
How to upgrade the firmware makelegs was kind enough to provide his instructions which I used as a base and thanks to gurkey and ibmack for taking a second look at them as well as markymiles and JonStatt. Please note that you are doing this on your own and will probably void warranty and don't blame anyone else than yourself it you screw it up or if it doesn't work even if you followed the instructions. The firmware should only upgraded by the official Onkyo Service Point so you are on your own. What is described below is just an example of how "easy" it can be if you decide to do it. If anything is missing or is incorrect or if something needs more explaination, let me know and I will update the instructions! All about the firmware can be read here: http://www.avsforum.com/avs-vb/showthread.php?t=1016297 - http://www.avsforum.com/avs-vb/showthread.php?t=1016297 and post any questions about the upgrade process there.
Here are the steps to complete the 876 FW update:
1) Plug in USB end of RS-232 adapter into computer and load any drivers for it.
2) Go to "Ports" in Device manager, and set adapter to COM-1 (Right-click on the device->Properties->Port Settings Tab->Advanced)
You may have com port 1 already in use. You would then need to assign the adapter to a different com port. If this is the case you will also need to change the update software to the same port BEFORE clicking the main update button, step 7. The com ports available on the update software are 1-3.
3) Turn off the power of the receiver (*)
4) Connect # - db9 RS-232 cable to both the USB adapter and the 876, make sure they are securly fastened.
5) Hold "Enter" behind the front flap while powering the receiver back on (*). "MainUpdateMode" appears on the 876 screen.
6) Run "UPDATE.EXE" on the computer If it complains about drivers, unpack the Setup_Adapater-package and run the setup.exe contained therein. It should list something like ths: Firmware Read Result ******************************** 001. F000000A / FF000000 002. F000000A / 01000000 003. F000000A / 02000000 004. F000000A / 03000000 *************************************************** If not, you are in the wrong directory.
7) Click on the "Main Update" button on the PC screen .... and it's off and running. (If you get ""Searching F/W..." on the receiver, you could be in the wrong directory at step 6). (If you get something like "Run-time error '8002'" and "Invalid port number", you have no connection to your receiver. It is either your ports that are not configured correctly or the cable itself)
On the front panel display, it will begin the "erase" countdown and then start the "write" process. Process includes 25,339 units, and counts rapidly up from 1. It takes 16 minutes. Note: The update hangs/waits a few secs at 24,933 while the front panel displays "write FFBB00" but it soon finishes and the display says "Complete" and goes into normal standby.
(*) Either disconnect/connect the power cord of the receiver or press the main power switch behind the front flap if you have a non American model to power off/on.
Skrevet af: Hother
Skrevet den: 06-November-2010 kl. 18:10
4) Connect # - - db9 - RS-232 - cable to both the USB adapter and the 876, make sure they are securly fastened.
Uha, det er er vist en større omgang du vil i gang med. Og man skriver, at opdateringen kun bør udføres af en officiel Onkyo tekniker - og du skal benytte et http://forum.recordere.dk/RTE_textarea.asp?mode=quote&POID=898007&ID=341# - - db9 - RS-232 - cable til opdateringen. Jeg vil gerne oversætte hovedpunkerne hvis du mener at det er nødvendigt for dig
Skrevet af: bekker
Skrevet den: 06-November-2010 kl. 18:45
Jeg opdaterede min Onkyo 876 for et halvt års tid siden, fordi jeg havde problemer med at den rendte varm, og der kom lidt grønne streger i billedet når det skete.
Der var som sådan ingen problemer i det. Eneste "spændingsmoment" for mig, var om mit USB -> RS-232 kabel ville være brugbart, eller om jeg skulle grave en gammel bærbar med rigtig RS-232 port frem. Jeg valgte at bruge USB -> RS-232, hvilket ikke gav problemer
Skrevet af: MMJ,75
Skrevet den: 06-November-2010 kl. 21:19
Der var som sådan ingen problemer i det. Eneste "spændingsmoment" for mig, var om mit USB -> RS-232 kabel ville være brugbart, eller om jeg skulle grave en gammel bærbar med rigtig RS-2port frem. Jeg valgte at bruge USB -> RS-232, hvilket ikke gav problemer  32 |
Hej bekker, kunne du sige mig hvilken firmware version du har. også hvor du fik den fra?  ...
jeg kan ikke rigti frostå hvoen man gøer  ? det med RS-232/usb den meller dette her "Run-time error '8002'"? lige som der står her når jeg prøver = If you get something like "Run-time error '8002'" and "Invalid port number", you have no connection to your receiver. It is either your ports that are not configured correctly or the cable itself). er det sådan at du kan sige mig hvordan jeg gør Tak,,,
Skrevet af: MMJ,75
Skrevet den: 06-November-2010 kl. 21:25
Citat: Hother
mange tak Hother!  . ja mit problem er det jeg skrev til bekker!. så hvis du kan jelpe?
Skrevet af: Hother
Skrevet den: 06-November-2010 kl. 21:31
MMJ,75 skrev:
Citat: Hother
mange tak Hother!  . ja mit problem er det jeg skrev til bekker!. så hvis du kan jelpe? |
Bare iorden - Bekker har jo også været øvelsen igennem. Send ham evt. en PM
Skrevet af: MMJ,75
Skrevet den: 06-November-2010 kl. 21:36
det gøere jeg Tak .
Skrevet af: MMJ,75
Skrevet den: 07-November-2010 kl. 15:40
Nå i mens jeg venter på bakker ?. er der mån ander der kan jelpe mig imens Tak ...
Skrevet af: Hother
Skrevet den: 07-November-2010 kl. 15:54
Skrevet af: bekker
Skrevet den: 07-November-2010 kl. 16:00
Jeg har 1.04 på min lige nu - jeg fandt alt info i denne tråd http://www.avsforum.com/avs-vb/showthread.php?p=14678948#post14678948 - http://www.avsforum.com/avs-vb/showthread.php?p=14678948#post14678948 - lidt nede er der et punkt der hedder Firmware.
Jeg kan ikke umiddelbart finde programmet til opdateringen igen, og det ser ud til at de links der er på førnævnte side, er nede.
Du får højst sandsynlig den fejl, fordi der er rod med din com port opsætning. Så vidt jeg husker, er programmet til at køre opdateringen med, sat op til at bruge Com1 - du skal muligvis ind i Enhedshåndtering og ændre dette manuelt på din PC.
edit: Jeg ser lige at den side jeg henviser til, rent faktisk er det samme du har copy/pasted
Du skal sikkert bare have styr på din com port...
Skrevet af: Hans j
Skrevet den: 07-November-2010 kl. 17:33
Det ville være nemmere at hjælpe dig, hvis du beskrev hvordan du har koblet din computer til Onkyo´en. Bruger USB til RS232 interface eller bruger du en RS232 port direkte ? Har du et RS232 kabel lige igennem ? osv osv.
Foranlediget af dit spørgsmål, prøvede jeg i går at opdatere min egen.
Det som tog længst tid var at finde firmware.
Jeg udpakkede firmwarepakken og installerede software på computeren.
Derpå forbandt jeg pc til Onkyo via RS232-port (ikke USB-adapter) og aktiverede update på Onkyo. Trykke på update på computer og så kørte det stille og roligt.
Skrevet af: bekker
Skrevet den: 07-November-2010 kl. 17:37
Lige nøjagtig, det er ret lige ud af landevejen.
Bruger man en USB adapter, som jeg gjorde, er det ekstra RS-232 kabel selvfølgelig ikke nødvendigt. Til gengæld ender com porten ofte med at hedde com 7, eller andet spas.
Skrevet af: MMJ,75
Skrevet den: 07-November-2010 kl. 18:49
jeg siger tak til alle der hjælper mig super . ja jeg har hente version 1.05?. det jeg ikke kan er det med kablet? jeg har sådan et her http://www.amazon.com/TRENDnet-Serial-Converter-TU-S9-Blue/dp/B0007T27H8/ref=pd_cp_e_2_img - http://www.amazon.com/TRENDnet-Serial-Converter-TU-S9-Blue/dp/B0007T27H8/ref=pd_cp_e_2_img
og ja det har noget med Com at gøer?. jeg er måske lidt  men jeg kan ikke læse så godt!, mit
problem er nok det med pc,er?. men jeg ringer gerne op hvis i kan hjelpe mig så sen mig en pm?  tak
Skrevet af: bekker
Skrevet den: 08-November-2010 kl. 19:27
Tjaa... hvor meget har du styr på computer ?
Du skal dybest set starte med at få styr på din com port - ind i enhedshåndtering og finde din USB com port. Noter hvilken com port den benytter, og vælg (om muligt) det samme i programmet til opdateringen.
Jeg sidder hverken med programmet til opdatering eller en PC med com port, så detaljerne er lidt slørede - men arbejd hen imod at få styr på din com port.
Skrevet af: Hother
Skrevet den: 08-November-2010 kl. 19:35
Jeg har så også sendt trådstarter en dansk oversættelse af den engelske vejledning. Men i og med, at jeg ikke er specielt komputer minded, så ved jeg ikke hvo brugbar min oversættelse er. Men kunne da udlede, at ntop portproblematikken er vigtig
Skrevet af: MMJ,75
Skrevet den: 08-November-2010 kl. 20:09
tak og tak tak. som sagt er jeg ikke særlig god til at skive. så det ville være nemmer for mig på telefonen?, så hvis du/i? gider senne mig et nr , kunne jeg forklare hvad jeg har gjort og hvad jeg ved?. ps. enu en gang tusind tak for den hjælp jeg har fået
Skrevet af: Hother
Skrevet den: 08-November-2010 kl. 20:13
Skrevet af: Hans j
Skrevet den: 08-November-2010 kl. 21:04
Eventuelt kan du prøve, at installere programmet http://onkyocontrol.zwo.dk/ - her.
Her kan du styre din Onkyo via RS232, så kan du via setupmenuen, ændre porten under communication settings og efterfølgende se hvornår du kan styre din Onkyo.
Når det virker har du fået forbindelse til Onkyoen og du kan så opdatere via updater (husk at sætte port i dette program også).
Grunden til jeg foreslår dette er, at her kan du ikke komme til at lave ulykker , men måske forvirrer det mere end det gavner, men det er op til dig selv at vurdere.
Men det er nu et fint lille program som en eller anden har udviklet, kan ikke huske hvem det var som postede det herinde.
Skrevet af: fabhund
Skrevet den: 08-November-2010 kl. 21:17
MMJ,75 skrev:
tak og tak tak. som sagt er jeg ikke særlig god til at skive. så det ville være nemmer for mig på telefonen?, så hvis du/i? gider senne mig et nr , kunne jeg forklare hvad jeg har gjort og hvad jeg ved?. ps. enu en gang tusind tak for den hjælp jeg har fået |
Hvor i landet bor du? Vi kan sikkert godt finde en aften hvor jeg kan kigge forbi ?
Skrevet af: Hother
Skrevet den: 08-November-2010 kl. 21:37
Recordere.dk er bare ind i mellem så skøn med hjælpsomhed. Undskyld at jeg bliver lidt rørt
Skrevet af: MMJ,75
Skrevet den: 08-November-2010 kl. 22:09
jeg ved heller ikke hvad jeg skal sige en tusind tak til alle her ene .. ps jeg bor i nærheden af Roskile?. men det er vel ikke tæt på ?. jeg vil selvfølig prøve alt i skiver her ene i mens. og det lykes også sikkert en dag ...
Skrevet af: fabhund
Skrevet den: 08-November-2010 kl. 22:14
Det er det desværre ikke, jeg er i Århus
Skrevet af: Hother
Skrevet den: 08-November-2010 kl. 22:16
Skrevet af: MMJ,75
Skrevet den: 08-November-2010 kl. 22:17
ja det var det jeg sagde . nå som sagt jeg finder nok på noget men tak skal du have .
Skrevet af: MMJ,75
Skrevet den: 08-November-2010 kl. 22:19
ham her ? http://www.recordere.dk/indhold/templates/design-udenkomm.aspx?articleid=3697&zoneid=6 - http://www.recordere.dk/indhold/templates/design-udenkomm.aspx?articleid=3697&zoneid=6
http://www.recordere.dk/indhold/articlefiles/3697-csn3.jpg -
Skrevet af: Hans j
Skrevet den: 08-November-2010 kl. 23:05
Hvor ved Roskilde (Nord/Syd/Øst/Vest) ?
Skrevet af: Hother
Skrevet den: 09-November-2010 kl. 08:43
Lige præcis, en meget dygtig og hyggelig, og ikke mindst et fair menneske
Skrevet af: henningdalgaard
Skrevet den: 09-November-2010 kl. 10:19
Jeg har også en 876'er Har også et usb-rs32 kabel. Men hvorfor overhovedet opgradere? Jeg oplever ingen problemer med min. Hvad er det der driller siden du vil opgradere?
Skrevet af: MMJ,75
Skrevet den: 10-November-2010 kl. 14:43
jeg vil skifte fordi jeg har hørt at det skulle hjælpe vamet problemet!. og fixe nogle problemer der var?. di senner vel heller ikke en opdatering hvis det ikke er nødventit . og ja den lyder godt nu men ting hvis det skulle blive beder ,,, MHW, MMJ
Skrevet af: MMJ,75
Skrevet den: 08-December-2010 kl. 14:31
Hej til alle . ja nu er det alså sludt ?, og jeg vil Tkke alle der her har hjulpet mig i mit lille projekt med opdatering af minTX-SR876 og især en stor tak til Hans j får at komme forbi og FW opdatering min Onkyo! ogTak til får at oversætte Hother  ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Skrevet den: 08-December-2010 kl. 14:40
fedt, har det løst problemet?
Skrevet af: Sploink
Skrevet af: Sploink
Skrevet den: 08-December-2010 kl. 14:46
Hvis det hjælper på varme problemet, kunne det være jeg også selv skulle overveje det. For den bliver da godt nok en kende lun til tider
Skrevet af: MMJ,75
Skrevet den: 08-December-2010 kl. 14:52
ja det toer jeg nok . varmen er ikke så slem meger men jeg ved ikke heldt om det har hjulpet i nu da det ikke mer en et par dage siden og jeg har skifte aldt mit udstyer ud , så lyden er Fjong
andet kan jeg ikke sige men jeg skal da nok kikke efter hvad der er nydt?. men jeg gik fra en 1.01 til 1.05 så mund ikke det har hjulpet....
Skrevet af: mureren
Skrevet den: 08-December-2010 kl. 15:41
Jeg har en TXSR805, og har et måske dumt spørgsmål!
Har fået den DSP firmware update der skal bruges for at fjerne "DTS Bomb".
Manualen siger der skal sættes en cd-afspiller med optisk kabel til receiveren, for at udføre updaten.
Vil min AC Ryan PlayOn HD Mini ikke kunne udføre nøjagtigt det samme, hvis jeg sætter det optiske kabel til receiveren?
------------- Mvh. Mureren
"I wish there was a knob on the TV to turn up the intelligence! There's a knob called "brightness", but it doesn't work!"
Skrevet af: MMJ,75
Skrevet den: 08-December-2010 kl. 16:06
Vil min AC Ryan PlayOn HD Mini ikke kunne udføre nøjagtigt det samme, hvis jeg sætter det optiske kabel til receiveren? |
Hej, ja det skulle jeg mene, den fanger selv DSP firmware  , så du skal bage spile den cd,er!.
