Her er en måde at holde styr på, hvor mange timer ens Panasonic G20 har kørt (Virker på følgende modeller X24 - C2 - U2 - S2 - G20 - G25 - VT20 - VT25)
På eget ansvar, hvis man vil ind og checke
Panasonic Consumer Models X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
- Press and hold the {VOL -} button ON THE PLASMA.
- Then press the {INFO} button on the remote control 3 times.
- The Service Menu will be displayed with the following options:
- ADJUST {Picture Adjustment}
- WB-ADJUST {White Balance Adjustment}
- OPTION {Option Setting}
- V-SUS {V-SUS Adjustment}
- AGING
- SRV-TOOL {Service Tool}
{1} & {2} buttons move through options
- Press the {2} button once to select "SRV-TOOL".
- And press the {OK} button to access it.
- Using the cursor keys, highlight the right side
of the last item "PTCT :00.00.00.00.00" :
- Then press and hold the {MUTE} button for 3 seconds.
- Time and Count will be displayed in red color:
__TIME = Hours : Minutes of operation. COUNT = Times the Plasma was powered on.
- To exit, unplug the power cable.
_<<<<<<<<<<< WARNING BY BRUZZI >>>>>>>>>>> _-The {VOL+} & {VOL-} buttons are used to change values _-while in the Service Menu. Make sure not to touch those _-buttons anytime while checking the hours used.
Link: http://www.highdefjunkies.com/showthread.php?1772-The-Official-quot-How-to-Check-the-Hours-Used-on-Your-Plasma-quot-Thread - http://www.highdefjunkies.com/showthread.php?1772-The-Official-quot-How-to-Check-the-Hours-Used-on-Your-Plasma-quot-Thread
