USB På Philips 37PF9830
Forumnavn: TV
Web-adresse: https://forum.recordere.dk/forum_posts.asp?TID=9735
Udskrevet den: 12-Februar-2025 kl. 18:05
Emne: USB På Philips 37PF9830
Skrevet af: agger
Skrevet den: 17-Februar-2006 kl. 15:19
hej
er der nogen der ved hvad man kan bruge usb på Philips 37PF9830 , skal det vare fat 32 kan bare få bibliotek frem ikke se hvad der er i ????, ved ikke helt hvordan jeg skal forklare hvad jeg mener.
hilsen agger
Skrevet af: Lars
Skrevet den: 17-Februar-2006 kl. 15:33
Hej agger
Vil tro det skal være FAT.
Prøv at placere billederne i roden af din USB enhed.
  /Lars
PS. Sakset fra Philips Support
Question
What you need to know about USB Memory Device
Answer
  • Devices connected to the USB port of your TV must be “Mass Storage Class” compliant. If your
    device (digital camera. MP3 player, portable harddisk, …) is not “Mass Storage Class” compliant it will
    not be detected by the content browser of the TV.
  • The following subsets of the Mass Storage Class specification are supported:
    • The implementation of the TV is based on the “Universal Serial Bus Mass Storage Class
      Specification Overview” (v1.2, June 23, 2003) including all documents referenced by the document.
      The document can be found on the USB standardisation website (
      http://www.usb.org/ - www.usb.org ).
    • Full support of the USB Mass Storage Class Bulk-Only Transport (bInterfaceProtocol = 50h).
    • Partial support of SubClass Code = 01h; Reduced Block Commands (RBC) T10, Project 1240-D.
    • Full support of SubClass Code = 02h; SFF-8020i spec, MMC-2 (ATAPI)
    • Full support of SubClass Code = 04h; UFI, typically used by floppy disk drive devices.
    • Full support of SubClass Code = 05h; SFF-8070i spec.
    • Full support of SubClass Code = 06h; SCSI transparent command set.
  • For large USB memory devices, when you are in the Content Browser, it may take a long time before
    you can access your files if you select Pictures or Music. However, you can access the content
    immediately if you select All Files in the Content Browser menu.
  • When using a USB portable harddisk: Due to the high power consumption of the harddisk, it is
    advised to use the external power supply of the portable harddisk to guarantee proper working
    under all conditions.
Ansvarshavende redaktør.
Webmaster, recordere.dk
Skrevet af: agger
Skrevet den: 17-Februar-2006 kl. 15:56
hej lars
tak for svaret, havde håbet jeg kunne se film direkte fra usb, men det ser ud til at det er billeder og musik den virker med, det er også bare fint kobler den bare direkte til min pc så kan jeg gøre hvad jeg vil.
hilsen agger
Skrevet af: lahan
Skrevet den: 17-Februar-2006 kl. 16:00
Jeg mener også du kan se divx film via din USB eller også er det fra kort læseren i skærmen.
Check evt at læse den mega lange tråd om 37pf9830 på Hifi4all.dk
Skrevet af: Thorvald
Skrevet den: 17-Februar-2006 kl. 16:11
Jeg har undret mig over hvad man kan bruge en USB-port til i sin fladskærm? Til USB flash-memory eller hvad?
Med de venligste hilsener
Thorvald.
Skrevet af: lahan
Skrevet den: 17-Februar-2006 kl. 16:15
Ja netop til USB-memory hvor du kan have billeder, film, musik med mere på.
Lidt genialt hvis man vil se sine billeder fra sit digicam.
Den bliver vist også brugt til firmware opdateringer.
Skrevet den: 17-Februar-2006 kl. 16:37
Ok, smart nok - på JVC LT-37M60 er der kortlæser i stedet for.
Thorvald.
Skrevet af: Lars
Skrevet den: 17-Februar-2006 kl. 16:53
Jeg mener at have læst, at en af de mindre Philips LCD skærme fik understøttelse for MPEG4 video efter en firmware upgrade.
Så du kan da prøve at lægge den nyeste firmware i TV'et
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=37PF9830/10&scy=GB&slg=en - Philips 37PF9830 Support
  /Lars
Skrevet af: agger
Skrevet den: 17-Februar-2006 kl. 18:39
hej igen
synes ikke jeg kan finde noget på http://www.hifi4all.dk - www.hifi4all.dk   er der måske en link.
hilsen og tak agger
Skrevet af: Lars
Skrevet den: 17-Februar-2006 kl. 19:04
Det er ellers på det link jeg sendte dig ( http://www2.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=37PF9830/10&scy=GB&slg=en - se link igen ).
Åben det, og vælg "Software og drivers" i menuen til venstre.
Så får du download til nyeste firmware, samt en vejledning hvordan det installeres.
  /Lars
