S: LG 32LB1R 32" TV "Billigt" |
Besvar
| Forfatter | |
symbol
Oprettet: 28-Juni-2011 Sted: Næstved Status: Offline Point: 349 |
Citér Svar
Emne: S: LG 32LB1R 32" TV "Billigt"Sendt: 02-September-2013 kl. 15:12 |
Har dette udemærkede,velfungerende, men ældre TV i overskud.
super til værelset eller sommerhuset. http://www.flatpanels.dk/flatforum/viewtopic.php?t=896 http://www.lg.com/dk/support-produkt/lg-32LB1R http://peecee.dk/upload/view/420459 http://peecee.dk/upload/view/420458 der medfølger desuden bord. befinder sig i Næstved. hbo 200.- kører flere steder. specs: e (inch) 32 tum System Analog Terrestrial Yes Module Display S-IPS LCD with EEFL Backlight Picture Format 16:9 WideScreen Resolution 1366x768p Response time (ms) 8 ms (GTG) Contrast Ratio 1600:1 (Al) Brightness (Cd/m²) 600 cd/m² Picture XD Engine New XD engine 3 DCDi Yes Digital Comb Filter 3D NR / MPEG NR Cinema 3:2 mode (natural motion) Yes Color reproduction 14 bit (1023 grades) Picture Control Dynamic, Standard,Mild,User Color temperature Control Normal,Cool,Warm,User Aspect Ratio Correction Orginal,Spectacle,Full,4:3,16:9,Zoom Supported Signal NTSC,PAL,HD,VGA~SXGA Sound Speaker System 2Ch 6 units (37LB1) 2Ch 2 units (32LB1) Sound Type NICAM A2 Audio Output 15W x 2 AVL (Automatic Volume Leveller) Yes Surround System SRS TXT, BBE Sound Control Flat,Music,Movie,Sports, User Function Auto / Manual Programing Yes Text TV Memory 1500 pages AV Input Navigation Yes Flashback / Quick View Yes Index Display Yes Intelligent Eye Yes PIP (picture in Picture) Yes (Two Tuners) Split Screen (Double Window) Yes (Two Tuners) POP (1+3 Pictures) Yes Clock Yes On/Off Timer Yes Sleep Timer Yes Auto Off Yes Key Lock Yes Connections (Side) Headphone Yes Component (Y/Pb/Pr) 1 (480i/p,576i/p,720p,1080i) Connections (Back) Tuner 2 Tuner Scart (Full) 1 / Tv Out Scart (Half) 1 / MNT Out AV In (Composite) 1 + Audio S-Video 1 + Audio HDMI Input 1 RGB In (D-sub 15pin) 1 PC Audio in 1 Control RS-232c |
symbol
Citér Svar
Sendt: 02-September-2013 kl. 16:23 |
Det gik så stærkt....solgt.
Besvar
