LØST: Hvordan nulstillers en Denon AVR-2312? |
KlausDM ![]() Platin medlem ![]() ![]() Oprettet: 12-Marts-2010 Sted: Hammel, Jylland Status: Offline Point: 19844 |
![]() ![]() ![]() ![]() ![]() Sendt: 12-Marts-2014 kl. 19:12 |
http://usa.denon.com/us/product/pages/productdetail.aspx?catid=avreceivers%28denonna%29&pid=avr2312ci%28denonna%29
Side 144 Resetting the microprocessor Perform this procedure if the display is abnormal or if operations cannot be performed. When the microprocessor is reset, all the settings are reset to their default values. ON/STANDBY PRESET CHANNEL 3 PRESET CHANNEL 2 1 Turn off the power using ON/STANDBY. 2 Press ON/STANDBY while simultaneously pressing PRESET CHANNEL 2 and PRESET CHANNEL 3. 3 Once the display starts flashing at intervals of about 1 second, release the two buttons. If in step 3 the display does not flash at intervals of about 1 second, start over from step 1. Edit: Nå, du var hurtigere selv...... Klaus Redigeret af KlausDM - 12-Marts-2014 kl. 19:12 |
