  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Hvad kan en Yamaha RX-V2600 være værd?
DanielPT Se dropdown menu
Oprettet: 04-Marts-2007
Point: 752
Funktioner Funktioner   Tak (0) Tak(0)   Citér DanielPT Citér  BesvarSvar Direkte link til dette indlæg Emne: Hvad kan en Yamaha RX-V2600 være værd?
    Sendt: 08-Juni-2025 kl. 16:56
Hej alle
Jeg har fået sådan en forstærker her.
Jeg aner virkelig ikke hvad den skal koste? Har i nogen ideer?
Yamaha RX-V2600
130 watts x 7 into 8 ohms (20-20,000 Hz) at 0.04% THD
Dolby® Digital EX, DTS-ES®, DTS Neo:6, Pro Logic® IIx, and DTS 96/24 processing
THX Select2 certification and THX Surround EX™ processing
HDMI switching (2 in, 1 out)
HDMI version 1.1
selectable 720p/1080i video upconversion for all non-HD sources
(upconverted video available through HDMI output only)
triple-room/triple-source capability (powered and line-level stereo audio output for 2nd and 3rd rooms, composite video output for 2nd room)
back surround speaker channels re-assignable for bi-amping front left and right speakers
YPAO sound optimization for automatic speaker setup (microphone included)
XM Satellite Radio Ready (requires XM subscription and optional XM Mini-Tuner package)
Digital ToP-ART design
high-current, low-impedance amplifier construction
192kHz/24-bit Burr-Brown DACs for all channels
audio delay helps align out-of-sync audio and video for digital sources
Silent Cinema for simulated surround sound via standard stereo headphones
Pure Direct mode for better sound from stereo sources
component video switching: 3 in, 1 out (100MHz)
component video conversion
digital audio inputs: 5 optical (including 1 front-panel), 3 coaxial
digital audio outputs: 2 optical
4 audio inputs (including phono)
6 audio/video (including 6 S-video and 1 front-panel) inputs
7.1-channel audio input
7.1-channel preamp output for connecting optional external amplifiers
on-screen display (requires TV with direct video input)
illuminated learning/multibrand remote
basic remote for 2nd or 3rd listening room (requires remote control extender system, not included)
2 sets of main speaker outputs
selectable subwoofer crossover frequencies and phase switching
40 AM/FM presets
17-1/8"W x 6-3/4"H x 18"D
60-day returns
MFR # RX-V2600
Item # 022RXV2600
Mange tak!
Min bio: http://forum.recordere.dk/forum_posts.asp?TID=117177
Status: Online
Point: 19864
Funktioner Funktioner   Tak (1) Tak(1)   Citér KlausDM Citér  BesvarSvar Direkte link til dette indlæg Sendt: 08-Juni-2025 kl. 17:14
200-300 kroner som symbolsk betaling.
Den er snart 20 år gammel.
Alle features i den er forældede, 2 hdmi ind og 1 hdmi ud (hdmi version 1.1).
Point: 752
Funktioner Funktioner   Tak (0) Tak(0)   Citér DanielPT Citér  BesvarSvar Direkte link til dette indlæg Sendt: 08-Juni-2025 kl. 17:26
Ja det har du nok ret i :)
Mange tak!
hansie Se dropdown menu
Oprettet: 01-Juli-2004
Point: 7255
Funktioner Funktioner   Tak (0) Tak(0)   Citér hansie Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 06:01
Vil mene den er tæt på 0.- værd
Der er ikke efterspørgsel på sådanne gamle enheder mere.
Hvis man kikke i containeren på genbrugspladsen er der meget af sådanne smidt ud.
jake51 Se dropdown menu
Oprettet: 02-Januar-2005
Point: 6415
Funktioner Funktioner   Tak (0) Tak(0)   Citér jake51 Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 11:52
Måske kan nogen bruge den til TV-lyd i stereo med subwoofer
Mikael Simpson
Munch Se dropdown menu
Oprettet: 23-Juni-2018
Point: 5287
Funktioner Funktioner   Tak (0) Tak(0)   Citér Munch Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 12:29
Hvis den er 20 år gammel og stadigvæk virker, så er den da noget mere værd end nul kr. Det AV udstyr der fremstilles i dag, holder dæleme ikke lige så længe Censored
Status: Online
Point: 19864
Funktioner Funktioner   Tak (0) Tak(0)   Citér KlausDM Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 14:51
Tjah, det kan også være at den går i stykker 3 timer efter man har købt den....
Men, jeg er da sikker på at du godt må købe den for 4000 kroner :-)
Point: 7255
Funktioner Funktioner   Tak (0) Tak(0)   Citér hansie Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 15:12
20 år gammelt elektronik må formodes at være på det sidste
Man kan være heldig at den lever længere.
fltk Se dropdown menu
Oprettet: 04-Februar-2004
Point: 10612
Funktioner Funktioner   Tak (0) Tak(0)   Citér fltk Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 17:10
Ja, mine B&W højttalere fra 1982 lever i bedste velgående.
Dune HD Realbox 4K
Thomson THA100
Status: Online
Point: 19864
Funktioner Funktioner   Tak (0) Tak(0)   Citér KlausDM Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 17:23
Der er kæmpe forskel på passive komponenter og aktive komponenter med masser af varmeudvikling.
Desuden kan kondensatorerne i dine 40+ år gamle B&W sagtens være delvist udtørrede, så højttalerne lyder anderledes i dag end dengang de var nye.
Det lægger du bare ikke mærke til, da forandringen er sket laaangsomt over de sidste 20 år.
Klaus (som selv lige har kasseret en 35+ år gammel stereoforstærker)
Point: 5287
Funktioner Funktioner   Tak (0) Tak(0)   Citér Munch Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 19:40
Nej tak! Jeg køber selv nyt og håber det holder…
Point: 5287
Funktioner Funktioner   Tak (0) Tak(0)   Citér Munch Citér  BesvarSvar Direkte link til dette indlæg Sendt: 09-Juni-2025 kl. 19:41
Ja og mine B&W DM 7 fra 1981 har aldrig spillet bedre end nu og de fejler intet.
