  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Oppo tråden
Emne lukketOppo tråden
Startrek Se dropdown menu
Oprettet: 02-Marts-2008
Point: 5740
Direkte link til dette indlæg Emne: Oppo tråden
    Sendt: 10-September-2008 kl. 23:24
For at for alt debat om Oppo væk fra div. tråde, syndes jeg at det er på
tide med en særskilt tråd kun om Oppo´s prod
Eller kan jeg sige at Oppo DV-983H, kan gøres let region-free:
"Anyone that has tried to play a DVD from another continent can attest to
what a pain region coding is on DVDs. Region coding restricts people
from playing DVDs from another part of the world on their locally
purchased DVD player. Luckily, you can strip away region-coding
restrictions on your Oppo DV-983H with a simple remote sequence. To
make your Oppo DV-983H region-free, follow these instructions on the
remote:
1. Press setup
2. Enter the numbers 9210
3. A new menu will pop up. Press 0 to make it region-free.
4. Press setup again to exit.
That's all. Now you can enjoy DVDs encoded in any region"
Kilde: http://reviews.cnet.com/9602-12576_7-0.html?
messageID=2510683&tag=mncol;txt
Eller er der en god teste af Oppo DV-983H i reviews.cnet.com
http://reviews.cnet.com/video-players-and-recorders/oppo-dv-
983h/4505-6463_7-32896592.html
Redigeret af Startrek - 11-September-2008 kl. 00:16
Point: 12430
Direkte link til dette indlæg Sendt: 10-September-2008 kl. 23:27
Oprindeligt skrevet af Startrek Startrek skrev:
Eller kan jeg sige at Oppo DV-983H, kan gørre let region-free:
Dette gælder i øvrigt for samtlige af Oppos dvd-afspillere...
