  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Squeezecenter problem 2
Emne lukketSqueezecenter problem 2
swax Se dropdown menu
Oprettet: 28-Juni-2006
Point: 23
Direkte link til dette indlæg Emne: Squeezecenter problem 2
    Sendt: 30-Juni-2009 kl. 20:07
Hej igen.
Jeg kan ikke få lov til at skrive i min gammel tråd. Squeezecenter problem så nu opretter jeg lige en ny. Squeezecenter problem 2
min Logfil for SqueezeCenter
BEGIN failed--compilation aborted at /share/HDA_DATA/SqueezeCenter/scanner.pl line 41.
JSON::XS object version 2.232 does not match bootstrap parameter 1.5 at /volume1/SSODS/lib/perl5/5.8.8/armv5tejl-linux-thread-multi/ DynaLoader.pm line 253.
Compilation failed in require at /share/HDA_DATA/SqueezeCenter/CPAN/JSON/XS/VersionOneAndTwo. pm line 5.
BEGIN failed--compilation aborted at /share/HDA_DATA/SqueezeCenter/CPAN/JSON/XS/VersionOneAndTwo. pm line 5.
Compilation failed in require at /share/HDA_DATA/SqueezeCenter/Slim/Utils/Prefs/Base.pm line 23.
BEGIN failed--compilation aborted at /share/HDA_DATA/SqueezeCenter/Slim/Utils/Prefs/Base.pm line 23.
Compilation failed in require at (eval 32) line 3.
...propagated at /volume1/SSODS/lib/perl5/5.8.8/base.pm line 85.
BEGIN failed--compilation aborted at /share/HDA_DATA/SqueezeCenter/Slim/Utils/Prefs/Namespace.pm line 23.
Compilation failed in require at /share/HDA_DATA/SqueezeCenter/Slim/Utils/Prefs.pm line 81.
BEGIN failed--compilation aborted at /share/HDA_DATA/SqueezeCenter/Slim/Utils/Prefs.pm line 81.
Compilation failed in require at /share/HDA_DATA/SqueezeCenter/scanner.pl line 41.
Point: 23
Direkte link til dette indlæg Sendt: 30-Juni-2009 kl. 20:09
Status for SqueezeCenter
Version: 7.3.3 - 27044 @ Mon Jun 15 15:03:29 PDT 2009
Værtsnavn: Riconas
Serverens IP-adresse: 10.0.0.2
Serverens HTTP-portnummer: 9001
Styresystem: Linux - DA - iso-8859-1
Platformarkitektur: armv5tejl-linux
Perl-version: 5.8.8 - armv5tejl-linux-thread-multi
MySQL-version: 5.0.67
Samlet antal kendte afspillere: 0
tipsen Se dropdown menu
Oprettet: 29-August-2005
Point: 3722
Direkte link til dette indlæg Sendt: 01-Juli-2009 kl. 00:04
Sendt: 29-Juni-2009 kl. 23:44 | IP-adresse registreret       Svar med citat af: tipsen
Hvilken version af SSODS kører du med?
Hvilken version af SqueezeCenter kører du med?
Har du prøvet at genstarte boksen?
Point: 23
Direkte link til dette indlæg Sendt: 01-Juli-2009 kl. 16:16
Hej igen.
version af SSODS 317
version af SqueezeCenter 7.3.3
jeg har prøvet at genstarte boksen mange gange.
Kunne denne fejl være problemet.
Hjælp jeg er snart helt skaldet
Point: 3722
Direkte link til dette indlæg Sendt: 01-Juli-2009 kl. 22:09
Jeg har læst flere steder, at der er issues med de nye versioner af SSODS - dvs. > 3.15 - prøv at hente 3.15 udgaven og se hvordan det går med den! Henter du også den rigtige udgave i forhold til cpu'en i din NAS?
Point: 23
Direkte link til dette indlæg Sendt: 05-Juli-2009 kl. 14:08
Lige en opdate..
Jeg har fået det til at virke.
Jeg skiftede til ssods 318. og så virket alt som det skal...
