Her er en smart lysning for dem der gerne ville havde 7.1 analog ud fra en PS3, nemlig
octavainc 4 x 2 HDMI Distribution Amp with 7.1 Audio Routing, som modtager op til 7.1 LPCM fra PS3 og sender op til 7.1 analog ud
http://www.octavainc.com/HDMI%20switch%204x2_7_1audio.html
Description: Simplify your HD connections.
Are you looking to route HDMI and 5.1/7.1 LPCM Audio to your existing Surround Sound System? This unique 4x2 HDMI switch routes both HDMI and 5.1/7.1 LPCM ( 8ch) Analog Audio. Perfect for systems using PS3 which has internal LPCM decoding on HDMI. The 4x2 can take the decoded LPCM from the PS3 and convert to 5.1/7.1 ( 8ch) Analog Audio
for easy integration with your high end 5.1/7.1 audio receiver/amp. In
addition, an Auxillary 5.1/7.1 ( 8ch) audio Input allows you to connect
a second Analog 5.1/7.1 source to your surround system.
4 HDMI inputs available and can output to 2 HDMI HDTV displays. RS-232 control port available for easy integration with 3rd party control systems.
Now available with V1.3 Full HD and Deep color support.
Our proprietary Clear EYETM transmission line and ISI reduction design will IMPROVE the digital video signals. Smart ScanTM algorithm
intelligently selects the correct HDMI source so you can enjoy the
program instead of fumbling with the remote. Approved by Wives and Kids!
