  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Ny afspiller med Sigma’s 8655 Chip
Emne lukketNy afspiller med Sigma’s 8655 Chip
daskino Se dropdown menu
Oprettet: 08-Februar-2007
Point: 783
Direkte link til dette indlæg Emne: Ny afspiller med Sigma’s 8655 Chip
    Sendt: 28-August-2009 kl. 14:50
Eminent EM7075 er en digital medie afspiller som har samme chip som popcorn C-200.
Den er bygget op ligesom WDTV , dvs at den ikke har nogen mulighed for intern harddisk.
Til gengæld er det en rendyrket netværks streamer som har den nye kraftige chipset fra Sigma.
Eminiment regner med at udgive denne nye afspiller i september.
her et udklip fra deres hjemmeside
EM7075 hdMEDIA STREAM
Expected: August, 2009.
Access your files stored on your network
The internal 10/100 LAN port allows you to quickly connect your home network and play files directly from your PC or other devices. Featuring full DLNA, UPnP and SAMBA support you will never have a dull moment in your home.
Ultimate sound experience
Easy to choose your movies
The powerful Sigma Designs 8655 chips ensures crisp and fluid display of all your media, and even supports the upscaling of standard-definition video files so you can enjoy them on your HD or HD-Ready television.
Network: Ethernet 10/100
Video Outputs: HDMI 1.3, Composite
Audio Outputs: Stereo Analog, Optical Digital
Video Formats (Codecs): XviD (SD/HD), MPEG-1, MPEG-1/2(MP@HL), MPEG-4.2 (ASP@L5, 720P, 1Pt. GMC) WMV9 (MP@HL), H.264 (BP@L3, MP@L4.0, HP@L4.0 & L4.1), VC-1 (MP@HL, AP@L3), MKV, AVI, VOB, ISO, IFO, DVR-MS, ASF (WMV), MOV (MP4 codec)
Video Extensions (Containers):
Audio Formats (Codecs): WMA, WMA Pro, AAC (MPEG 4), AC3 (Dolby), MP1, MP2, MP3, WAV, PCM, LPCM, FLAC. Playlists: PLS, WPL, M3U
Audio Extensions (Containers) :
Image Formats: GIF (without animation), BMP (no CMYK), JPEG, TIF/TIFF (only single page file), PNG
Other Formats:
Subtitle Formats: SRT, SUB (VobSub, Subviewer), SMI, SSA, ASS, DivX Subtitle, MKV (VobSub, SRT) subtitle
Supports external USB harddisk up to 1.5 Terrabyte
Optical output for Dolby AC3 and DTS
5-Year warranty
Redigeret af daskino - 28-August-2009 kl. 14:57
Sony 46HX823 Samsung H5505
Roku LT, Google nexus player, Sidewinder 4 Xtreamer,
WD TV HD, Live Mini og Ryan Mini2, SB 3, Wii,
spawn Se dropdown menu
Oprettet: 30-November-2005
Point: 6822
Direkte link til dette indlæg Sendt: 28-August-2009 kl. 17:41
Det er nu altså ikke samme chip som C-200
C-200 benytter en 8643 som modsat hvad man skulle tro udfra nummeret er det kraftigste chipset de har, og væsentligt kraftigere end 8655 som Eminenten benytter
Du kan se nogle tekniske sammenligninger her
http://www.sigmadesigns.com/Products/selection_guide/selecti on_guide.html
Products
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  Available Products
SMP8652
SMP8653
SMP8654
SMP8655
SMP8642
SMP8643
SMP8644
SMP8645
SMP8634
SMP8635
EM8620L
EM8621L
EM8622L
EM8623L
EM8624L
EM8625L
EM8626L
EM8627L
EM8628L
EM8629L
EM8510
EM8511
EM8560
EM8561
Market Segment
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  IPTV
  Blu-ray
  HDTV
  Network Players
  Portable Media Players
Video Decoding
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  MPEG-1
SD SD SD SD SD
  MPEG-2
1.25x HD 2 HD 2 HD HD SD
  MPEG-4.2
  MPEG-4.10 (H.264, AVC)
  SMPTE 421M (VC-1)
  AVS
1.25x HD 2 HD
  WMV9
  OpenType acceleration
  JPEG acceleration
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
Audio DSP
333 MHz (3) 333 MHz (2) 300 MHz 200 MHz 200 MHz
Video Outputs
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  CVBS, S-video, YPbPr
  Digital YCbCr or RGB
  HDMI with audio
v1.3a
CEC
deep color
xvYCC
v1.3a
CEC
deep color
xvYCC
v1.2
xvYCC
  Simultaneous outputs
HD
CIT-HD
SD
HD
CIT-HD
SD
HD
SD
Audio Outputs
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  I2S
5.1
(2) 9.1
(2) 9.1
5.1
5.1
  S/PDIF
2
2
  HDMI
Video Processing
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  Motion adaptive
  deinterlacing
  Programmable scaling
  Chromaticity correction
  OSD
32-bit
32-bit
32-bit
32-bit
8-bit
  OSD gamma control
  RGB output gamma
  control
  Color temperature
  control
  Graphics acceleration
2D
2D
2D
2D
Host CPU
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  Speed / type
500 + 333
MHz MIPS
667 + 333
MHz MIPS
300 MHz
MIPS
200 MHz
ARM
200 MHz
ARM
Security CPU
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  Speed
333 MHz
333 MHz
200 MHz
Peripheral Interfaces
SMP8650
Series
SMP8640
Series
SMP8630
Series
EM8620L
Series
EM8510
Series
  Digital video input
8-bit
8-bit
8-/16-/24-bit
8-/16-bit
EM8560
  Peripheral bus
  Transport stream inputs
2 SPI, 3 SSI
2 SPI, 3 SSI
2 SPI, 3 SSI
1 SPI, 2 SSI
  IR input
  IDE / SATA
(2) SATA
(2) SATA
IDE
IDE
IDE
  Ethernet
(2)
10/100
(2)
10/100
10/100
10/100
  USB
2.0 host
2.0 host
2.0 host
  SD Card
  Smartcard
  Flash memory support
NAND
NAND
NOR
NOR
NOR
NOR
  DRAM support
DDR-2
DDR-2
DDR-1
DDR-1
DDR-1
  PCI
Philips 65OLED705/12 - ATV4K
Point: 783
Direkte link til dette indlæg Sendt: 28-August-2009 kl. 18:18
anyways det er stadig en hurtigere processor end den gamle 863xx serie .
Point: 6822
Direkte link til dette indlæg Sendt: 28-August-2009 kl. 18:40
Det er den, og det var heller ment som noget negativt om den nye Eminent, den ser skam yderst spændende ud. Og pænt design.
tobiasl Se dropdown menu
Oprettet: 08-Oktober-2005
Point: 820
Direkte link til dette indlæg Sendt: 29-August-2009 kl. 05:23
den er flot  men ingen blu ray soport  så holer fast ved den komne C-200
Point: 6822
Direkte link til dette indlæg Sendt: 29-August-2009 kl. 13:34
Her er en lille youtube video af interfacet (work in progress)
http://www.youtube.com/watch?v=a8fcbQ4AtfI
Der er lidt WDTV agtig interface over den og coverart for musik og video
Meget nydeligt
Point: 783
Direkte link til dette indlæg Sendt: 22-September-2009 kl. 22:44
første billeder af afspiller
http://4.bp.blogspot.com/_q4Fu6tvHesQ/SqpHoImrVJI/AAAAAAAAEp A/ODWLCDE292c/s400/SigmaDesigns-SMP8655A.jpg
http://1.bp.blogspot.com/_q4Fu6tvHesQ/SqpLYAu0lDI/AAAAAAAAEp Y/RdSznjlh8iw/s400/Eminent-EM7075-inside.jpg
http://1.bp.blogspot.com/_q4Fu6tvHesQ/SqpLu5Ep3WI/AAAAAAAAEp g/zGb9JgZx48Y/s400/Eminent-EM7075-remote.jpg
youtube af menu sysytem
Point: 820
Direkte link til dette indlæg Sendt: 22-September-2009 kl. 23:27
den ser flot ud
tipsen Se dropdown menu
Oprettet: 29-August-2005
Point: 3722
Direkte link til dette indlæg Sendt: 23-September-2009 kl. 00:57
Kan ikke få ovenstående links til at virke - kan de gøres klikbare og korrekte eller kan billederne evt. smides direkte i tråden?
