  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - Synology 2.3 frigivet
Emne lukketSynology 2.3 frigivet
rhsin Se dropdown menu
recordere.dk teamet
Oprettet: 19-Januar-2007
Point: 5990
Direkte link til dette indlæg Emne: Synology 2.3 frigivet
    Sendt: 13-Marts-2010 kl. 20:17
Til dem der ikke har set det, er den nye Synology software klar på deres site http://www.synology.com/support/download.php?lang=enu
Synology DiskStation DS409+ Release Notes
Version: DSM 2.3-1139
(2010/03/08)
New Features
This firmware can only be applied to DiskStation with DSM 2.1 or DSM 2.2 firmware. Download DSM 2.2-0942 at: Americas/Europe, Asia
  1. New Volume Manager:
    • The Synology Hybrid RAID (SHR) simplifies the RAID setup, allowing the DiskStation to maximize the available storage of varying disk capacities yet with data protection. Experienced administrators may still use a manual option of creating a storage volume.
    • RAID10, 3-way RAID 1 and 4-way RAID 1 volume types are supported.
    • Block-based iSCSI target is supported and providing faster performance of file transfer.
    • The Volume Manager User Interface has been updated with additional graphics and illustrations.
    • RAID 5 to RAID 6 migration is supported.
  2. EZ-Internet: The EZ-Internet Wizard is now available for guiding through the steps to establish access to DiskStation from the Internet, including firewall settings, PPPoE setup, DDNS registration, and router port forwarding configuration*. The "Router Configuration" feature is also available on the management UI under "Internet Connection" category, which accomplishes the port forwarding tasks on the router for you. View the supported router list here.
  3. Shared Folder Encryption: AES 256-bit shared folder encryption is supported with the DiskStation. The encrypted shared folder cannot be accessed until it is mounted by entering the encryption key.
  4. Backup Enhancements:
    • In addition to the existing "shared folder" level backup, "sub folder" level backup is now supported.
    • NetBackup shared folder is supported to act as the backup source. This allows backing up the data sets from DiskStation A to DiskStation B, and from DiskStation B to DiskStation C, and so on.
    • Amazon S3 is now supported as a backup target.
    • The Backup Wizard now allows backing up Surveillance Station event recordings with all the settings, including notifications, privileges and licenses.
  5. File Station 3:
    • Local file browsing is supported (Java Runtime Environment is required) for easy browse and upload the local folders or files to DiskStation with drag-n-drop actions.
    • Multiple tasks are now supported. Upload tasks are performed in the background and with the upload queue listed at the bottom of the File Station.
    • Files and folders on the DiskStation can be compressed directly from the File Station.
    • .7z and .iso compressed files extraction is supported.
  6. Surveillance Station 4:
    • 162 more IP camera models from Sony, Mobotix, JVC, IQeye, Edimax, Siemens and other brands are now supported. View the complete list here.
    • H.264 video format is now supported.
    • Intelligent PTZ now supports preset positions, patrol paths, and guard schedules on each camera.
    • Manual recording is supported during camera live view.
    • E-Map is supported, which allows assigning an uploaded image to each live view layout, and deploy corresponding cameras or sub-maps to the image.
    • Enhanced user accounts privilege allows deciding not only the privilege of each user (manager vs. spectator), but also which IP cameras each user can access.
    • Event export function is supported to allow archiving the recorded events to an external storage device or another shared folder. At a later time the events can be mounted back for review on Surveillance Station.
    • More advanced camera settings are supported, including direct live-view streaming from the IP cameras, different image resolutions and frame rates settings for recording and live view, along with pre- and post-recording time and more flexible recording schedule configuration.
    • The sync-event player is improved with better time accuracy.
    • Motion detection setting is improved with threshold testing utility.
  7. iPhone Support: A new iPhone app, DS cam, is available on Apple® App Store for free. DS cam allows users who own an iPhone/iPod touch to live view the IP cameras (in MJPEG format), take snapshots, and view recorded events on your Surveillance Station whenever network connection is available.
  8. Photo Station 4:
    • Browsing photos with a photo wall or an image flow view is now supported.
    • Adjusting photo thumbnail size with a sliding bar when browsing photos is now supported.
    • Uploading photos and creating sub-folders through Photo Station UI is supported (Flash 9 is required). Enhanced privilege control allows customizing which albums each user accounts can access or upload photos.
    • Virtual albums are now supported, including albums of recent photos or videos.
    • Google map function is integrated, allowing browsing the location where the photo is taken if the geo-information is available in the photo, or manually edit the Google map location.
    • Enhanced album access permission allows easily setting the public/private attribute of all albums.
    • 1024X768 blog layout is supported and 10 new banners are newly provided.
    • Photo Uploader utility is available in the new Synology Assistant to allow uploading photos and videos to the DiskStation which photo thumbnails and H.264 films pre-generated with the client computer.
    • RAW image files are supported including *.arw, *.srf, *.sr2, *.dcr, *.k25, *.kdc, *.cr2, *.crw, *.nef, *.mrw, *.ptx, *.pef, *.raf, *.3fr, *.erf, *.mef, *.mos, *.orf, *.rw2, *.dng and *.x3f.
  9. Audio Station 2:
    • Audio Station 2 now also utilizes AJAX technology. It allows browsing the music library by folder, album, artist or genre, browsing the albums in thumbnail view or cover flow view, and managing the playlist and the now-playing queue with right-clicks.
    • M4A music is now supported in streaming mode.
    • Streaming music from other UPnP/DLNA media servers within LAN is supported.
    • Internet radio (MP3 only) is now supported in streaming mode.
    • SHOUTcast and RadioIO Internet Radio are supported with automatic updates.
    • iTunes Server Smart Playlist is supported to be played on Audio Station.
    • In addition to USB mode and web-streaming mode, Audio Station 2 now supports streaming music, stored on DiskStation or other UPnP/DLNA media servers, to an UPnP compatible digital media renderer (DMR). View the supported DMR list here. Streaming music simultaneously in the 3 modes is allowed.
  10. Download Station Enhancements: MegaUpload download with a premium account is supported.
  11. Management UI Enhancements:
    • A thin UI header option is available for maximizing the operation area of all applications.
    • Directly entering a specific application after login is supported.
    • Left-hand menu items are now customizable where menu options which are infrequently used can be hidden from view.
    • Items in the My Favorites are now also available as a list on the top of the left-hand menu for quick access.
  12. Wireless Support: With the supported wireless dongles, the DiskStation will be accessible via 802.11b/g/n wireless connectivity. Both the infrastructure and Ad-Hoc modes are supported. View the supported USB wireless dongle list here.
  13. Added PHP Modules: FreeType, PDO, dba, dbase, pdo_sqlite, SQLite, shmop, wddx, xmlrpc and zip
  14. Enhanced Mac Compatibility: Mac Decomposed Unicode character sets handling is enhanced.
Major Changes of Synology Data Replicator 3 (v.142)
  1. (780) Enhanced Windows Live Mail backup on Windows 7.
  2. (782) Enhanced My Documents backup on Windows 7.
* Some routers and ISPs may not be supported.
Special Notes
  1. Browser Support:
    • Internet Explorer 7, 8
    • Firefox 3, 3.5
    • Safari 3, 4 (Mac)
  2. Surveillance Station 4 newly supports the following IP cameras:
    • [Sony] SNC-CM120, SNC-CS10, SNC-CS11, SNC-CS20, SNC-CS50N, SNC-CS50P, SNC-DF40N, SNC-DF40P, SNC-DF50N, SNC-DF50P, SNC-DF70N, SNC-DF70P, SNC-DF80N, SNC-DF80P, SNC-DF85N, SNC-DF85P, SNC-DM110, SNC-DM160, SNC-DS10, SNC-DS60, SNC-P1, SNC-P5, SNC-RX530N, SNC-RX530P, SNC-RX550N, SNC-RX550P, SNC-RX570N, SNC-RX570P, SNC-RZ25N, SNC-RZ25P, SNC-RZ30N, SNC-RZ30P, SNC-RZ50N, SNC-RZ50P, SNC-Z20N, SNC-Z20P
    • [Mobotix] D12Di-IT, D12Di-IT-Dnight, D12Di-Sec, D12Di-Sec-180, D12Di-Sec-Dnight, D24M-IT-D22, D24M-IT-Night, D24M-Sec, D24M-Sec-Night, M12-DevKit-Board, M12D-IT-DNight, M12D-Sec, M12D-Sec-DNight, M22M-IT, M22M-IT-Night, M22M-Sec, M22M-Sec-Night, M22-Sec-CSVario, Q24M-Sec, V12D-Sec, V12M-Sec
    • [JVC] VN-V225U, VN-V25U, VN-V26U
    • [IQeye] IQ040SI, IQ041SI, IQ042S, IQ510, IQ511, IQ540SI, IQ541SI, IQ542SI, IQ702, IQ703, IQ705, IQ711, IQ732N, IQ732S, IQ751, IQ752, IQ753, IQ755, IQ802, IQ803, IQ805, IQ811, IQ851, IQ852, IQ853, IQ855, IQA10N, IQA10S, IQA11N, IQA11S, IQA12N, IQA12S, IQA13N, IQA13S, IQA15N, IQA15S, IQA20N, IQA20S, IQA21N, IQA21S, IQA22N, IQA22S, IQA23N, IQA23S, IQA25N, IQA25S, IQD40SI, IQD41SI, IQD42SI
    • [Edimax] IC-1500, IC-1500Wg, IC-1510, IC-1510Wg, IC-1520DP, IC-1520DPg, IC-1520POE, IC-3010, IC-3010Wg, IC-7000, IC-7000PT, IC-7000PTn, IC-7000PTn-V2, IC-7000PT-V2
    • [Siemens] CCIC-1410-L, CCIC-1410-LA, CCIC-1410-LAW
    • [Axis]
      • IP camera: M1011, M1011-W, M1031-W, M3011, P1311, P3301, Q1755, Q6032-E, P3343, P3343-V, P3343-VE, P3344, P3344-V, P3344-VE
      • Video server: 240Q, 241Q, 241QA, 241S, 243Q, 243SA, 247S, M7001, Q7401, Q7404, Q7406
    • [ACTi] TCM-4301, TCM-5311, TCM-5311E
    • [AVIPC] M9030
    • [D-Link] DCS-920
    • [Vivotek] FD7130, FD7160, FD8161, FD8361, IP7361, IP8161
  3. After firmware upgrade, the system will automatically create additional thumbnails for all photos stored in "photo" shared folder. Photo Station service will not be affected.
Limitation & Known Issues
  1. Axis video server "quad image" feature is not supported on Surveillance Station.
  2. Refer to "Limitation & Known Issues for all versions" for other limitations.
René
Bruger udmeldt 31 Se dropdown menu
Oprettet: 20-April-2006
Point: 2601
Direkte link til dette indlæg Sendt: 14-Marts-2010 kl. 00:57
Yeps, har kørt med beta'en et stykke tid. Meget stabil og fuld af gode funktioner Smile
recordere.dk teamet
Point: 5990
Direkte link til dette indlæg Sendt: 14-Marts-2010 kl. 10:42
havde godt set betatesten, og overvejede også om jeg skulle melde mig til... men omvendt... så gad jeg ikke være forsøgskanin Wink
René
Bimsen Se dropdown menu
Oprettet: 12-November-2004
Point: 511
Direkte link til dette indlæg Sendt: 14-Marts-2010 kl. 11:01
Betaversionen virkede ikke problemfrit på min 209, men nu körer det fint. Om end der stadig er plads til forbedringer Wink
Damhus Se dropdown menu
Oprettet: 24-Juli-2007
Point: 503
Direkte link til dette indlæg Sendt: 14-Marts-2010 kl. 14:57
Kan man opdatere uden at Squeezeserver ryger, eller er det forfra med den?
recordere.dk teamet
Point: 5990
Direkte link til dette indlæg Sendt: 14-Marts-2010 kl. 15:53
altså jeg har aldrig mistet noget ved mine opdateringer... men som synology siger hav altid backup Wink
jeg har ikke squeezeserver, men dog en del andre ekstra pakker som fint overlevede updaten
René
Point: 503
Direkte link til dette indlæg Sendt: 14-Marts-2010 kl. 15:59
Ja, det er jo heller ingen ulykke hvis Squeezeserver skal installeres igen.
Men der er jo lidt der skal organiseres og indstilles bagefter, det kræver lige en eftermiddag.LOL
edske Se dropdown menu
Oprettet: 13-December-2007
Point: 2
Direkte link til dette indlæg Sendt: 24-April-2010 kl. 11:06
Hey
Jeg har også lige opgraderet til version 2.3, især audiostation 2 ser rigtig lækker ud... Det eneste som ikke virker længere på min DS209J er USB mode. Det er som om at den ikke finder mit lydkort længere. Det virkede ellers perfekt under version 2.2
Er der nogle af jer som har oplevet lignende problemer vil jeg gerne høre det..
Claus
