  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - What is the differance between an LED TV and LED m
VitoAdjei Se dropdown menu
Oprettet: 04-September-2012
Point: 1
Funktioner Funktioner   Tak (0) Tak(0)   Citér VitoAdjei Citér  BesvarSvar Direkte link til dette indlæg Emne: What is the differance between an LED TV and LED m
    Sendt: 04-September-2012 kl. 07:55
Acctully we are planning to purchase a LED TV and my budget is 15000
And i have laptop also so want to know the differance between led tv and monitor.
my first priority is TV i mean i use it as a TV less as a monitor.
Kasper_J Se dropdown menu
Oprettet: 30-Marts-2007
Point: 2859
Funktioner Funktioner   Tak (0) Tak(0)   Citér Kasper_J Citér  BesvarSvar Direkte link til dette indlæg Sendt: 04-September-2012 kl. 08:05
A TV has a tuner and speakers. A monitor does not have a tuner, but may include speakers. So to use a monitor as a TV, you would need to use some kind of external tuner.
