Bedste stereo forstærker+højtalere til max 16.000? |
Besvar | Side <1 345 |
Forfatter | ||
RuzzFrog
Bruger Oprettet: 11-September-2007 Sted: Søborg Status: Offline Point: 230 |
Sendt: 04-Maj-2010 kl. 22:01 | |
Hej Firebird, fik lige en del for hånden. Jeg tager i sommerhus i morgen og kommer først hjem i weekenden, men jeg tager forbi butikken en af dagene i næste uge. Jeg skal prøve at se hvad der kan lade sig gøre nede i butikken, jeg synes ikke jeg så noget fjernsyn da jeg kiggede ind af vinduerne sidst..
Firebird
Guld medlem Oprettet: 14-Marts-2009 Sted: Denmark Status: Offline Point: 2195 |
Sendt: 04-Maj-2010 kl. 23:47 | |
http://forum.audiogon.com/cgi-bin/fr.pl?ddgtl&1260573454&read&keyw&zzrega My friend took the unit "out shopping" for a pair of speakers. We listened to it with Rega RS-3's, a $2k pair of Avalon floor standers, Vandersteen 1's (all new) and used Triangle Celius and Audio Physic Yara floor standers. It had problems driving the Regas and the Avalons - which was a bit surprising, I thought the Regas would have been a great match. Sounded pretty nice with all the other three. The Triangles were punchy, dynamic, but slightly sybalent. The Audio Physics had a really nice tuneful bass, not as midrange forward or quite as dynamic as the Triangles, but did a nice job dissappearing. He ultimately chose the Audio Physics, and I think that was a good decision. En Xitel Ground Loop Isolator kunne måske løse støjproblemet med HT Bypass. Mener at Hi-Fi klubben har sådan en fætter. Der er ikke en eneste Peachtree Audio Nova i Esbjerg og omegn, så jeg er glad for at du tager en lytter. Redigeret af Firebird - 05-Maj-2010 kl. 00:23 |
Venlig hilsen Firebird {;-)
Lytter til en del til 3 Doors Down, AC/DC, Billy Idol, Bruce Springsteen, Daughtry, Dire Straits, Evanescence, ZZ Top, og Within Temptation. JVC X3 ? ? ? ? |
Firebird
Sendt: 24-Maj-2010 kl. 18:24 | |
RuzzFrog! Har du testet Novaen?
Otto J
Platin medlem Branchemedlem Oprettet: 04-Marts-2007 Sted: Denmark Status: Offline Point: 11218 |
Sendt: 25-Maj-2010 kl. 09:01 | |
Hvordan en forstærker skulle kunne have problemer med at drive et sæt Rega RS3 går over min forstand. De er designet til at blive trukket af en Rega Brio, som er en vældigt vellydende men ikke særligt kraftig forstærker. De er med andre ord meget nemme at trække. Spørgsmålet er nok mere hvor meget vægt man skal lægge i hvad en mere eller mindre tilfældig bruger i et forum man måske ikke lige frekventerer normalt, siger om et produkt. Hvad mener han f.eks. med "problems driving the Regas", slog den fra, var der bare mindre bas end han var vant til, eller? Har han hørt samme højttalere med en anden forstærker og konstateret at det lød bedre, eller kunne han bare tilfældigvis ikke lide lyden af den kombination? Der er en væsentlig forskel på om forstærker og højttalere er et lydmæssigt velfungerende match, og på om forstærkeren kan trække højttalerne. Hvis den har bare lidt mere strøm end en walkman, så kan den sagtens trække et sæt RS3 (men ikke dermed sagt at det nødvendigvis lyder godt). |
Bruger udmeldt 38
-- Oprettet: 21-Maj-2006 Status: Offline Point: 5 |
Sendt: 25-Maj-2010 kl. 09:20 | |
Otto.
Du véd udemærket godt, at der kan være højttalere, som let kan drives af en lille (stabil*) forstærker, hvor en større forstærker måske kan gå i knæ....!
Behøver jeg nævne DLS R55 - som jeg også vil betegne som en forholdsvis let højttaler at drive.
*) Ampere mæssigt.
Otto J
Sendt: 25-Maj-2010 kl. 09:33 | |
Det synes jeg bare er et halvskidt eksempel, da dét at R55 driver nogle forstærkere i knæ formentligt skyldes svære fasedrej osv. Uden at have set en måling på RS3, så vil jeg påstå at den netop er mindre problematisk på det punkt. Jeg er villig til at sætte en kasse øl på at hvis du tager én af de forstærkere der har det med at slå fra efter en halv times høj musik på R55, og sætter på en RS3, så er der ingen problemer.
Jeg tror det drejer sig om formulering: R55 er ikke let at drive, men den har en relativt god følsomhed. Så hvis forstærkeren er stabil nok, så spiller højttaleren relativt højt per watt.
Jeg kan også sige det på en anden måde: Hvis en RS3 er en svær belastning, så er ALLE højttalere en svær belastning.
Bruger udmeldt 38
Sendt: 25-Maj-2010 kl. 10:17 | |
Det understreger vel egentlig mit udsagn.
